Question about Canon PowerShot A630 Digital Camera
Canon Powershot A630 problem
Camera shuts off automaticall when opening viewer screen. Flash is functional, new batteries, and memo card re-seeded.
  • altus1966 Jun 08, 2008
    My Canon PS A630 worked fine for a little over a year and now when I turn it on and turn the viewscreen on it will stay on then go off. It wont even allow me to take a picture. I sometimes can turn the camera off and on and take a pic then it does it again. Very irritating. Worked very well til this happened. Batteries not problem. Always used lithium energizers changed them out etc, will not fix it.
  • altus1966 Jun 13, 2008
    I found out what my problem was. I noticed a clicking sound when I shook the camera. All that was wrong was that one of the battery terminals inside the camera had flattened. This made connection to the battery irratic and this would shut the camera down. I used a tool to pull it back up and the camera works well now.
My A630 from canon is not flashing anymore. I can make fotos only without flash. The batteries are ok(Varta 2700mah rechargeable) Help,Help
Posted on Jun 12, 2008
  • Canon Master
  • 4,738 Answers
The LCD screen may be overtaxing your batteries, resulting in shutdown. Are you using alkaline batteries, or worse yet "super heavy duty" batteries? If so, some brands of regular batteries just don't have the power for more than a few pics in a digital camera. Some may even have problems just powering startup of the camera. Performance varies by brand and shelf life of the batteries (how long were they on the store shelf before you bought them? Their expiration date may be listed on the package.).
Digital cameras for the most part should only be used with rechargeable NiMH batteries. Many retailers sells these for around $7 for a package of four (about $15-19 for the batteries with charger). Keep in mind they'll save you big bucks in the long run over alkalines, AND they'll last for at least 100 pictures per charge (and probably many many more). You'll be very pleased with their performance, and may slap yourself for not buying them sooner. When at the store, look on the package for a power rating of at least 2500 mah.
Posted on May 17, 2008
What setting to take a photo? Sometimes the screen is blank or filled withsymbols if I hit Menu or Function set. That is, how do i clear the screen, or prepare to take a shot?
at the back of the camera there is a Display button (mark as DISP)
press it a few times until all symbols will dissapear on the screen
good luck
image from: http://www.cameras.co.uk/camera-reviews/canon-powershot-a630.cfm
Sep 29, 2014 | Canon PowerShot A630 Digital Camera
LCD screen Black - manual Zoom not working
Hey,
It sounds like you're having the same problem,
Here is a link
http://www.e18error.com/repair.html
It may be usefull,
good luck mate!
Jul 26, 2010 | Canon PowerShot A630 Digital Camera
Power Shot A630 says card locked, will not take or delete pics
There is a switch on the side of the SD card, slide to unlock position then go to the SETUP menu, format the card (before doing that, make sure you have saved all pictures from the SD card to your computer)
this post may help
http://www.fixya.com/support/t2167722-screen_saying_memory_card_protected
May 08, 2009 | Canon PowerShot SD550 / IXUS 750 Digital...
Flash Card says Full but 0 images.
Yes, try formatting the card within the camera and then check.
Apr 07, 2009 | Canon PowerShot A630 Digital Camera
Lost manuel to canon powershot A630 and I wanted to know how to take a black and white picture.
By pressing the center button on the four-way controller, you'll open up the Function menu. This menu has the following options:
  • ISO speed (Auto, High ISO Auto, 80, 100, 200, 400, 800) -
  • White balance (Auto, daylight, cloudy, tungsten, fluorescent, fluorescent H, underwater, custom) -
  • Drive (Single-shot, continuous, self-timer [2 or 10 sec, custom] -
  • My Colors (Off, vivid, neutral, sepia, black & white, positive film, lighter skin tone, darker skin tone, vivid blue, vivid green, vivid red, custom color) -
  • Flash exposure compensation (-2EV to +2EV in 1/3EV increments) - in manual mode you can adjust the flash strength in three steps (1/3, 2/3, full)
  • Metering (Evaluative, center-weighted, spot)
  • Compression
  • Resolution
- Lisa
http://www.dcresource.com/reviews/canon/powershot_a630_a640-review/
Feb 26, 2009 | Canon PowerShot A630 Digital Camera
Canun digital camera powershot A630 lcd screen blank
I also cracked my Canon Powershot A630 lcd screen by dropping the camera. I saw a suggestion to buy a new replacement lens and either have it professionally replaced or try it myself. I ended up doing the replacement myself following instructions I found online. Now it works. Total cost US $63.
I would not recommend trying the replacement yourself, however. There are a few very delicate plastic parts in there which I ended up damaging. Luckily the camera and lcd screen are working great now. But it is probably worth having a professional camera repair shop do the whole job or insert the screen you've purchased. Good luck!
Jul 11, 2008 | Canon PowerShot A630 Digital Camera
Blank screen
Did you accidentally hit the lower left "Display" button on the back of your camera? It manually turns the screen on or off to save batteries. Turn the camera on and press it once to check.
Jun 19, 2008 | Canon PowerShot A630 Digital Camera
Dark image....even using flash.
go to the menu & open setting file.properly check the settings of auto mode
Aug 18, 2007 | Canon PowerShot A630 Digital Camera
Canon PowerShot A630 Digital Camera Logo
215 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
