Question about Toshiba 32A33 32" TV
My toshiba 32a33 is stuck in demo mode. we unplugged it,thenhooked it back up,and still have the problem.
  • 93 Answers
SOURCE: 35 in toshiba 35A44
unplug your television,then hold together the menu and the vol+.then press the power on,when its on release together the menu and the vol+ buttons
Posted on Nov 01, 2007
cTech1
  • 66 Answers
SOURCE: demo mode keeps popping up while watching aprogram
Press menu
Press left or Right to highlight Setup menu
Press up or down to highlight DEMO
Press Left or Right to highlight STOP
Exit the Menu.
Posted on May 15, 2008
SOURCE: 27'' TV will not turn off demo mode
My ancient TV/VCR Quasar combo had the same problem...and I don't have the original remote control. But holding down the "play" button for five seconds did the trick. Perhaps your TV is similar. I also read that holding down the "menu" button works as well. Hope this helps.
Posted on Apr 23, 2009
farr64
  • 121 Answers
SOURCE: toshiba 32a33 tv demo runs while watching tv or
sounds like a pain ..have you looked in the menu to see if you can shut it off ? try watching the tv with the batteries out of the remote to see if you have a fault with that .good luck farr64[colin]
Posted on Dec 29, 2009
gopakumarg43
  • 74136 Answers
SOURCE: Toshiba 32A33. Tv Goes into menu
Hello
Just check whether the front panel control buttons are jammed or not first. The fault you reports indicates taht. If there is no such situation, the microswitches inside it is damaged. Microswitches and one that gets in contact with the pushbutton switches you press at the front of the TV panel. These are fitted inside the front panel control. There are six of them inside your Tv. All of the are alike, and replace all the six of them at an instance. Thery are cheap to buy, and can be purchased from any electronic sparepart shops near your area. Open your TV and locate the switches, usually fitted on the front panel. Resolder it one for sample, and go for the new one.
OK.
Posted on Dec 26, 2010
Toshiba 32a33. I'll be watching tv and the volume bar shows goes down to 0 (no sound) when it is in this mode the remote control will not work on the volume, you can get up and manually up the volume...
1st check to see if your remote volume down button is stuck. 2nd do you have wireless internet (router) or any other wireless devices phones,ceiling fans, another Toshiba remote, if so try unplugging them (or remove the batteries if it's a remote) while it's changing the volume one at a time. If a different device makes it stop try changing the channel on it. Also make sure the t.v doesn't have a mind of its own and remove the batteries out of the t.v remote, let it ride for a couple days if it happens without the remote being in play then you know your t.v is acting strange, if it stops then starts back up when you start using the remote again then you know your dealing with a remote issue. Sometimes Freq.'s merge causing remotes/wireless devices to conflict with each other.
May 18, 2011 | Toshiba 32A33 32" TV
Toshiba 32a33 tv demo runs while watching tv or dvds,unpluged tv for several days no help, shut off demo on tv set no help, desolder the menu and tv/video buttons on front no help. so now what?
Dec 29, 2009 | Toshiba 32A33 32" TV
Our tv works excellent except it started to have a pop up that says "Toshiba Color TV, etc." and another pop up regarding the settings. Can't get it to stop. Can you help?
Viewing the demonstration (DEMO) mode
The DEMO mode automatically demonstrates several features of
your TV.
To start the DEMO mode:
1. Press MENU.
2. Press < or >to highlight the SET UP menu.
3. Press up or down to highlight DEMO.
4. Press < or > to highlight START.
To stop the DEMO mode:
Press RECALL, EXIT, or POWER. This should do it for you. Thanks for using fixya.
Nov 10, 2009 | Toshiba 32A33 32" TV
Toshiba 32A33 television screen is part green.
It sounds like it has magnitized sometimes you can unplug it and it will demagnatize when you turn it back on, otherwise you need a demagnitizing coil .
Aug 11, 2009 | Toshiba 32A33 32" TV
Stuck in demo mode
I had the same problem. Was told to unplug the set for 1 minute but it still was stuck in menu screen scrolling. So I was told to unplug the TV for 4 hours, it resets it I guess because it worked! Try it!
Nov 19, 2008 | Toshiba 35A44 35" TV
Toshiba 32A33
Main system control memory IC fault. This is a very small IC; have 8 solder terminals, and can be located very near to the main system control-chroma IC. Check and replace it. Be sure to replace it with the same number printed on it; in all respect. Otherwise, it won't go. http://electronicshelponline.blogspot.com/ Before replacing it, try a reset to this set, and then check.
There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here.
Jul 01, 2017 | Toshiba 32A33 32" TV
Demo mode constantly on screen
http://tacpservice.toshiba.com/ConsumerProductSupport/Manuals/TV/2004/32a33_32a43_36a43_rev219_ownman.pdf
May 15, 2008 | One For All URC-3605 Remote Control
Demo mode keeps popping up while watching aprogram
Press menu
Exit the Menu.
May 15, 2008 | Toshiba 32A33 32" TV
Demo mode wont shut off
I have this same problem, just started 2 days ago. Changed batteries in remote and everything - driving me nuts- now i cannot change channel or adjust volume! I powered off TV, took batteries out of remote, turned back on and now still stuck. I think we bought junk!
May 21, 2007 | Toshiba 32A33 32" TV
Toshiba 32A33 32" TV Logo
120 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
