Question about Jamo Audio Players & Recorders
I have a Jamo SW-410E subwoofer and it is not powering up. Ive checked the fuse and its good. What could of caused this problem.Do I need to get another transformer or is this just a transformer?
  • mjcato1969 Sep 16, 2010
    How do you check the Amp with a meter?
  • 2,272 Answers
The unit has to be opened and checked for blown or bulged capacitor.If that is all ok then yes the transformer is to be replaced.The other possibility is blown AMP .It has to be checked with meter and confirmed.
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Posted on Sep 16, 2010
  • raj somaiya
    raj somaiya Sep 16, 2010
    In the meter there is a continuity testing.Connect the meter pins to the ampere ic pins and check.If there is continuity showing then the ampere ic is ok.But if no continuity then its faulty.If amp ic checked ok then its faulty transformer.
    Thanks for keeping updated with your query.
Jamo sub 250
Internal power? Check fuses. No fuses? Disassemble and check Power supply if it is internal. If it is external, check power supply with meter.;.
Apr 30, 2013 | Jamo SUB 250 Subwoofer
The fuse of Jamo Sub-200 gets blown off. is there anyone who might know the reason. thanks
try replace the blown fuse with ampere and check the sound if still ok.
some fuse got blown if the load current exceed. maybe high volume can cause the high current.
other cause by short circuit coming from the amplifier.
Aug 26, 2011 | Jamo SUB 200 Subwoofer
Please help! Jamo SUB 300 subwoofer still blows (0.8A) fuses after replacing a faulty thermistor, despite a high ohms reading directly across AC mains terminals on the board. What is causing the fuse to...
hi,
i have a jamo 250 sub.the blue light is working.when i connect the jack to the left line IN according to the manual it makes a sound as well.but seems not working.is it related to the fuse????i know the fuse box.but i dont know how to remove the fuse to check.pls help me out.my receiver is onkyo tx-sr 608
thank you
ron
Jan 08, 2011 | Jamo SUB300BA SUB 300 Powered Subwoofer...
Cant connect jamo sub 250 to marantz SR4001... how do i do it? any suggestions?
Use the PRE-OUT SW (subwoofer) output and connect it to the left RCA socket of your subwoofer.
Sep 27, 2009 | Jamo SUB 250 Subwoofer
Jamo Sub with no power
THE IS A FUSE INSIDE THE UNIT,YOU MAY WANT TO CHECK THAT.IF IT BLOWS AGAIN WHEN TURNED ON YOU HAVE SHORTED MOSFETS. THEY ARE LIKE TRANSISTORS.
Mar 15, 2009 | Jamo SW400E Speaker
Jamo Sub300. No power. No lights
Well it would void the warrantee, but you can take the back panel off and the power supply will only have two leads (3 if grounded) in from the plug, and out to the crossover. It sounds as if you are correct that the power supply is bad.
Charles
Jan 05, 2009 | Jamo SUB300BA SUB 300 Powered Subwoofer...
I have no amp for jamo 1060 sub
Dual Voice-Coil
The unique Dual Voice-Coil design allows both left and right channel sound from just one speaker. Simply hook up both the left and the right channels to the special terminals on the speaker. Hook up one channel only, if the speaker is to be used in a conventional stereo set-up.
I found this on jamo site hope that will help you
Mar 15, 2008 | Jamo 1060 SW Speaker
577 people viewed this question
Top Jamo Audio Players & Recorders Experts
Electro Med Services...
Tom Chichester
Steve
Are you a Jamo Audio Player and Recorder Expert? Answer questions, earn points and help others
