Question about HP Office Equipment & Supplies
Hp color laserjet cp3505n hangs during initialization at 5/6 D/F.
doc_delphi
  • 11 Answers
SOURCE: hp color laserjet 2605dtn not printing
I would suggest a test page, too
If it is printed normally then check the connection plugs.
On a network: make sure the right IP for the printer is set, you have the possibility to check that via browser, adress is http://PrinterIPAdress, e.g. http://192.168.178.20
Third option: a wrong printer is chosen in print menu
Posted on Sep 17, 2008
713printech
  • 32 Answers
SOURCE: HP color LaserJet 2600n stucked on Initialzing
Well we can check and see if the printer is able to run an engine test. This is how you can run this test;
  1. Turn the printer around so the back of the machine is facing you.
  2. Remove the Engine etest button acess door. This is located in the bottom center of the back.
  3. Push the botton once while the printer is on. The printer should print a page with colored horizontal lines.
If the printer is able to print this page there is a very good indication the problem revolves around the PCA formatter board.
The Firmware might be outdated and causing this problem. Worst case scenario the board might be faulty, in that case your better off buying a new machine, since the cost to replace the board will be higher than that to replace this machine.
Posted on Nov 19, 2008
  • 77 Answers
SOURCE: What is a inflate failure on an HP Laserjet
Sounds like an "initiation" failure; can be caused by many things, but usually by storage, e.g., a flash DIMM. Try powering off, then removing any add-in cards, then restarting.
Posted on Feb 04, 2010
SOURCE: Print Quality Issue In magenta
Problem cause: the magenta cartridge is the lower one, so as the lens for magenta in laser assembly, which causes all the dirt and dust is covering these lens mostly (more than lens for other 3 colors). The solution: you have to remove the laser assembly (it's not very easy to get to it, if needed, I can explain how), open it and clean all the glass parts, lens and mirrors. Be very careful and gentle, especially with the rotating mirror. Use cotton stick and alcohol. Suggestion: since you opened laser assembly, clean lenses for all colors, there's always some dirt on them. hope this was helpful.
Posted on Nov 02, 2010
puertobori
  • 7733 Answers
SOURCE: We have a HP Color Laserjet CP3505n that is
Try Using the HP Print Diagnostic Utility in Windows - HP Customer Care (United States - English)
Posted on Nov 03, 2010
Why is black printing dull/light?
Probably using COLOR to print Black images. Check your printer settings Set to BLACK only.
Also could be from generic copy paper.
Feb 23, 2016 | HP Color Laserjet Cp3505n Color Laser...
59 co error
An error occurred with the developing
separation-drive assembly.
1. Check that the following connectors on
the driver PCA are seated correctly:
J403, J405, J213.
2. Check that connector J1020 on the DC
controller is seated correctly.
3. Check that connector J5008 on the
fuser motor is seated correctly.
4. Replace the developing separationdrive assembly.
5. Replace the memory-controller PCA.
6. Replace the fuser.
reseat fuser - something may be binding causing error
Oct 08, 2013 | HP COLOR LASERJET CP 3505 N PRINTER
You can download the HP printer drivers from their support WEB site. Please click on this link and select your model printer to download :- http://welcome.hp.com/country/us/en/support.html
Sep 30, 2012 | HP LaserJet 5550 Printer
I JUST NEED ORDER NUMBERS FOR ALL THE COLOR LASERJET CARTRIDGES FOR CP4525 PLS. THANKS,
You can find the user's guide here which lists all the parts and supplies. Here's the cartridge information from the manual:
  • HP Color LaserJet black print cartridge Standard black cartridge CE260A
  • HP Color LaserJet black print cartridge High-capacity black cartridge for CLJ4525 models only CE260X
  • HP Color LaserJet cyan print cartridge Cyan cartridge CE261A
  • HP Color LaserJet yellow print cartridge Yellow cartridge CE262A
  • HP Color LaserJet magenta print cartridge Magenta cartridge CE263A
You can use the HP numbers to look for original or after-market replacements.
Apr 29, 2011 | Office Equipment & Supplies
I am getting the error code 13.05.00 on an HP laserjet CP3505n printer. The manual says that it is a front door jam. The jam is occurring every other time I try to print a document. The document is being...
13.05.00 HP CP3505N
Problem Solve. Same error. Generally either a real or phanton jam from the paper tray or manual feed tray.
SOMETIMES the manual feed would work but always one corner on the paper turned down when printed.
Remove toner cartridges and bottom paper tray
Turn printer on its back. The black plastic flap (about 9" long) that hangs down a small amount (near the white main feed roller) had one end most likely the wrong side of the small metal rollers above it.
This flap should hang about vertical. One end of it is most likely the wrong side of the small mostly metal roller above it. Each End of this flap should be about mid way between the two smaller metal rollers.
WITH CARE take a timber skewer and carefully encourage this flap back so that both ends are in the correct place
Sep 02, 2010 | HP COLOR LASERJET CP 3505 N PRINTER
What is a inflate failure on an HP Laserjet CP3505n?
Feb 04, 2010 | HP LaserJet CP3505n Printer
Need a install and user manual for hp cp3505n
HP's website will have any documentation ever made for your printer. It may take a while to find it but it it isn't that difficult.
Oct 24, 2009 | HP COLOR LASERJET CP 3505 N PRINTER
1,699 people viewed this question
Seeker5211
Seeker5211
