Please tell me in E-Z words how to set the clock and calendar on the Canon MP11DX calculator? Manual instructions, which I cannot locate anyway, are absolutely unclear. Please HELP!
  • 5,218 Answers
To set the calender: Press the Calender/Time button. Press and hold the Time Set button for 3 seconds; the first digit of the date will start blinking. Then type in the date as two digit number for the month and date and a 4 digit number for the year. Add a zero in front of the month or day if under 10. Then press Time Set again. Press the CE/C button to return to the Calculation mode
(hold for 3 seconds)
Thus for today [Cal/Time] [Time Set] 0 9 1 5 2 0 1 0 [Time Set] [CE/C]
For December 1, 2010 [Cal/Time] [Time Set] 1 2 0 1 2 0 1 0 [Time Set] [CE/C]
To set the Time from the Calculator mode, you press the Calender/Time button twice before pressing and holding the Time Set button for 3 seconds; again the first digit of the current time will blink. Then type in the time as a 4 digit number followed by the AM/PM button to switch from AM to PM or PM to AM. Then press the Time Set button again and then the CE/C button to return to the calculator mode. You will see an A (AM) or P (PM) to the right of the time as you set it.
So for 5:06 PM you type
[Cal/Time] [Cal/Time] [Time Set] 0 5 0 6 [AM/PM] [Time Set] [CE/C]
I hope this helps. You can find the manual here: http://www.usa.canon.com/cusa/consumer/products/calculators/printing_calculators/mp11dx#BrochuresAndManuals as a pdf.
(I'm using Cal/Time for the button that has an icon that looks like a 1 month calender on the left and a clock on the left.)
Posted on Sep 16, 2010
How to change ribbon on canon mp11dx calculator
See Page 3, top right column for ribbon change instructions and images.
https://www.manualslib.com/manual/355934/Canon-Mp11dx.html
Apr 15, 2014 | Canon MP-11DX Calculator
How do I set the date for this Canon MP11dx? I
Start by pressing down on the clock/calendar button for about 3 seconds. Then press the equal ( = ) sign to input the correct date. Same process for setting the time. then press the ce/c button to clear the data on the screen. When u want to print the date, press the calendar button. this will automatically print it. then press the ce/c button again so u can start calculating.
Enjoy!
Apr 09, 2010 | Canon MP-11DX Calculator
Canon P170-DH Calculator
CLOCK & CALENDAR FUNCTION
Look for the key with the cal/clock pic on it. Use to switch between calendar or clock mode. It is next to the feed key.
(12/24) Key used to switch between 12 or 24 hour at clock mode.
(Time Set) Key used to set the date and time in calendar & clock mode.
(AM/PM) Key used to switch between AM or PM at clock mode time setting.
(Format) Key used to select date format between "YYYY/MM/DD",
"DD/MM/YYYY" or "MM/DD/YYYY" at calendar mode.
Hope this helps, play with it I figured it out with instruction sheet.
Jan 10, 2009 | Canon P170-DH Calculator
Setting the Canon MP25DV clock and calendar
press clock/calendar once to set date
1) press equal numbers will flash then use number keys to current time then the X to set am and pm. press = again to set time
2)press clock/calendar until date flashes. use number keys to current date. Press = to set
Nov 02, 2008 | Canon MP-25DV Calculator
Canon P23-DH
I don't think the P23-DH has a calendar/clock mode. I have found the instructions for setting date and time for the P23-DH V. If your calculator does not have [Calendar/Clock], [Time Set], and [AM/PM] keys, you cannot set the date and time.
To set date:
1. Press the [Calendar/Clock] key once
2. Press and hold the [Time Set] key for three seconds
3. Enter the date in MMDDYYYY format
4. Press the [Time Set] key
5. Press the [C/CE] key
To set time:
1. Press the [Calendar/Clock] key twice
3. Enter the date in HHMM format, press [AM/PM] key if necessary
Aug 27, 2008 | Canon P23-DH Calculator
I have the same problem I can not change date and time
Setting the date:
1. Press the CALENDAR/CLOCK Key. The default date will appear.
2. Hold the TIME SET key down for 3 seconds or until you see the first
digit begin to blink in the display.
3. Input the correct date.
4. Firmly press and release the TIME SET key. The first digit should
stop blinking and the date is then set.
Setting the time:
1. Press the CALENDAR/CLOCK key. The default time will appear.
NOTE: The seconds will disappear.
3. Input the correct time. If you need to adjust to AM or PM, press
the AM/PM accordingly.
stop blinking and the time is then set. The seconds will again be
displayed.
Follow by pressing the CLEAR key to return to the calculator mode. To
return to either the TIME or DATE, press the CALENDAR/CLOCK key to
toggle between them.
NOTE: If unsuccessful attempts to set the date and time have been made,
please first confirm that the piece of paper/plastic in the battery
compartment on the bottom of the unit has been removed. Then reset the
unit by inserting the tip of a ball point pen into the "RESET" hole on
the bottom of the calculator. The calculator should be on and in the
"Print" mode so that you can hear the calculator reset.
Aug 09, 2008 | Canon MP-25DV Calculator
Canon P100-DH Calculator manual
How to change the roller ribbon on my Canon P100-dh calculator?
Jan 10, 2008 | Canon P100-DHII Calculator
How do you set the clock/calendar on the Canon MP25DV?
on the bottom of your calculator is a reset button, with a paperclip or a pen press that button. Then, press the calendar, clock key. next, press the equal sign key until the date is flashing type in the date using 11172006. press the equal sign again and the date is set. Next press the calendar, clock key again the time should show up (12-00-00)press the equal sign again until the time starts to flash. enter in the time using 0903 (9:03) press the equal sign again. Time is set. to display the date and time when not using the calculator, press the calculator, clock key 2x's. to go to compute mode press the red CE/C button.
Nov 04, 2006 | Canon MP-25DV Calculator
435 people viewed this question
jasbo
jasbo
