Question about Pc America Restaurant Pro Express
Unable to recall invoice. Click on the recall invoice button - the screen flashes like it wants to open, then returns to the previous screen. This just started.
    Sergeant:
  • Pc America Expert
  • 310 Answers
If this is an isolated instance of just one invoice, void it and move on. If this is occurring more than once, you may need to reload RPE or SQL to correct it.
B Mattern
sysadmin@ccybernet.com
Posted on Sep 16, 2010
How do i recall invoice in pc america system
go to OPTIONS, then RECALL INVOICE. highlight the invoice you want and click SELECT.
May 10, 2014 | Pc America Computers & Internet
I'm trying to settle and its telling me that there are still open invoice and there is nothing currently on hold. Any suggestions??
Sounds like you have a corrupt invoice in your database. If you have a service contract with PCAmerica, contact them for a fix. If not, I can take a look.
Please return and give me a favorable rating if this helps or is of value to you.
Feel free to email me with more details if need be.
Aug 15, 2012 | Pc America Restaurant Pro Express
Turn cruise switch on and nothing
2 things prior to running the cruise control self Test
1. Do you have operational brake lamps ?
2. Have you had the recall done ?
recall 05S28. Description: Speed Control Deactivation Switch.
1L1Z-9F924-AA 14 supplements in the recall series
Self-Test Diagnostics
WARNING:
This test is a key on engine off (KOEO) test only that is conducted in park only with emergency brake fully engaged.
1. Enter self-test diagnostics by depressing the speed control OFF switch while turning the ignition key ON, making sure the engine does not start and is not running. The speed control indicator on the instrument panel will flash once to indicate that speed control module entered the diagnostic mode. Five additional flashes at this point indicate a defective speed control servo. Release the OFF switch.
2. Press the remaining switches in this sequence: ON, RESUME, COAST and SET/ACCEL.
If the ON switch is not depressed within five seconds after entering the diagnostics mode, the module times out and the procedure must be started over.
The speed control indicator lamp will flash as each switch is depressed. Press each switch in the sequence immediately after the indicator light goes out for the previous switch.
Note:
There will be a slight delay when the last button is pressed and the lamp flashes.
3. A lamp flash with the last button (SET/ACCEL) indicates that the static test passed. If the lamp does not flash with the last button and there are no additional flashes of the lamp, the switch is defective.
If the lamp does not flash with the last button, and additional flashes occur, follow the chart below for trouble codes:
- 2 flashes - BPP defective, circuit is defective, brake applied, CPP switch or jumper (if equipped).
- 3 flashes - deactivator switch is open or circuit defective.
- 4 flashes - vehicle speed signal is out of range or circuit is defective
4. Immediately (.25 second delay) after the static test, the speed control servo does a dynamic test by automatically actuating the throttle lever from 8 mm (0.315 in) to 12 mm (0.472 in) of travel from the idle position. During the dynamic throttle pull, observe throttle movement to witness any binding or sticking of the speed control cable and correct connection of speed control cable to throttle lever. Make sure the throttle returns to the idle position.
5. Return the ignition switch to the OFF position and proceed to the Symptom Chart.
Jun 01, 2011 | 2003 Ford F150 Regular Cab
How do you change VAT rate on Quicken 2002
You cannot do this on the normal account register, as you might have done in earlier versions of Quicken. You have to use two special registers, by creating a BUSINESS BILLS and a CUSTOMER INVOICES register. To do this tap the CREATE NEW ACCOUNT button, in the MY FINANCES screen, and select these registers from the dialogue box. When you receive a payment from a customer, open the CUSTOMER INVOICES register. Then... 1. Tap the TYPE box, and choose INVOICE from the drop down list. This will enter INVC into the box. 2. Look at the button under the BALANCE column. Instead of the usual SPLIT button, this is now labelled FORM. Click on this, and a Customer Invoice Form will appear. Fill in the details from the invoice you have received. Under AMOUNT enter the amount received, less VAT. In the V column, enter the symbol for the appropriate VAT RATE, and Quicken will calculate and enter the VAT amount. 3. When you have completed all the required boxes on the form, click the SAVE AND DONE button, and The form will close. 4. You will see that Quicken has entered the details in the correct Registers. I 5. When you produce your VAT REPORT your item will appear with its details in the correct places. The process for entering a payment is similar, but you will then be using the Business Bills register. Problem solved ! John Cunliffe
Feb 13, 2011 | Intuit Quicken 2002 Home and Business Full...
QuickBooks Pro 2007 Full Version (299116): Quickbooks Pro 2007 A client overpaid an invoic...
Open the apply payments window and choose the customers name at the top. Click next to the invoice that you want to pay and then at the bottom of the screen look for the button that says discounts and credits. Click on it and then choose credits. The credit should be listed there to apply to the invoice. If you have tried these steps
May 05, 2010 | Intuit QuickBooks Pro 2007 Full Version...
Cruise control will not turn on. light on dash use to come on. cruise will not work. checked fuse it is ok
Did you have the recall for the cruise control done ?
It could be the fuse in the recall harness is blown.
Try the Cruise Control Self test :
WARNING:
Note:
— 2 flashes - BPP defective, circuit is defective, brake applied, CPP switch or jumper (if equipped).
— 3 flashes - deactivator switch is open or circuit defective.
— 4 flashes - vehicle speed signal is out of range or circuit is defective
If the Cruise Control does not enter self test, the fuse in the recall harness ( if done ) is most likely blown and needs to be replaced.
Feb 02, 2010 | 2002 Ford F150 Regular Cab
Deleting recalled invoices
Hi heafra,
go to options recall invoices , when it is on display click on void. and you are ready to go .
Jun 01, 2008 | Pc America Restaurant Pro Express
Problem with macally icecam
1. You can open only one video application at a time, therefore, you need to quit ALL the application first, then open the one application you want to use. such as YIM or Skype.
2. Please open the iceCam Monitor, go to Monitor tab, check the "Record Video" and select "Record Until MouseClick".
A new Save window will pop up, set up the filename and location and click SAVE button.
Once you click the mouse button, it will save the recorded video as QuickTime Movie clip format file on the selected location.
If you want a picture, you could run the video and pause it and make a screen shot to grab the picture from the video.
Dec 25, 2007 | Macally IceCam Personal Web Camera
Computers & Internet Logo
91 people viewed this question
Top Pc America Computers & Internet Experts
Sunil Pratap Singh
Sunil Pratap Singh
sunil dixit
pravintechno
Level 1 Expert
Are you a Pc America Computer and Internet Expert? Answer questions, earn points and help others
