Question about IBM Lenovo ThinkPad T61 6466 Notebook
Just purchased a new Lenovo battery, and it has never charged to more than 33%, and now is at 0. One icon shows it is charging, another icon says it is plugged in (AC adapter), but not charging...Tried to reset battery gauge, changed power settings, don't know what else to try. Any suggestions?
  • 2,567 Answers
First, you need to make sure your power adapter is providing enough power to both run the laptop & charge the battery. A very good way to do this is to compare your laptop voltage & ampere requirements (written on a sticker on the bottom of the laptop) with the voltage & ampere ratings of the power adapter. Voltages should be the same, or the power adapter's voltage about up to 0.5 volts more than the laptop's voltage rating. Amperage of the power adapter should be at least equal to or greater than the laptop's rating. It should never be less than the laptop's rating, or else the power adapter will be providing insufficient amperes to charge the battery. Of course, the power adapter's nominal amperage might be ok, but it degraded on usage. You can verify this by testing using a good or new power adapter.
If the battery did not charge using the new power adapter, take the battery off the laptop, & using a dry tooth brush, scrub in between the fins of the battery connector on the motherboard & on the battery it self, then put the battery back into the laptop & try again.
If this still did not resolve the problem, then the battery itself could be bad. Try it on another laptop, or try a good or new battery in your laptop.
If this did not work, there might be a possibility that the charging circuitry on the laptop's motherboard is defective & needs servicing. In order to do this, the laptop needs to be disassembled & the motherboard checked for defective/burned out components in the area near the DC jack. Any defective/burned out components found should be replaced, or you might need to replace the laptop's motherboard altogether.
Posted on Sep 17, 2010
Testimonial: "Thanks so much, will try the suggestions..already had purchased a new adapter, shows as charging, but battery remains at 0 after 10 hours of recharge"
Hi Friend My Laptop Lenovo G580,last week m y battery is not charge and Power light and Battery light frequently blinking.Can plz suggest.I am so Afraid about this issue.battery is still good
Price on battery $33-90. Will he laptop work OK RUNNING ON THE BATTERY ?? u can buy a new charger on E/BAY COST AU ,$18.05... Cheer's
Jun 28, 2016 | Lenovo G580 Laptop
ThinkPad T400 Battery problem
I would replace the battery with a genuine Thinkpad replacement. If a battery is altered in some way it MAY be a fire hazard.
Mar 06, 2013 | Lenovo ThinkPad Computers & Internet
Battery light flashing amber
Is the battery a exact spec.? Some aftermarket batterys, inexpensive replacements, do not play-well with your laptop. If you purchased from a computer store, return for a replacement. That said, It may be that it's not fully charged or need to be drained and charged, cycle it a few times. Some batteries have to go through a "learning" process. It says fully charged in windows software, right? again, some replacement batteries don't play-well with windows.Its a "pins" thing in the battery connector.
Nov 19, 2012 | Lenovo Computers & Internet
Omnia HD not charging
"I once drop my phone into the toilet but I did some proper drying and is back to stock condition".
The motherboard was damaged. Time to buy a new phone.
Apr 27, 2017 | Samsung i8910 OMNIA HD 16 GB Black Cell...
The laptop is not charging...i don't know if i need a new battery.it's been a year only since i bought my lenovo..
there is an icon beside the clock in the corner of your screen it's an battery just click on it and it will show small box for power saving down the lines there is small box just click in that box if you see an X over your battery icon then you need to replace the battery if not just get back to me
Aug 05, 2011 | Lenovo Computers & Internet
Lenovo Z560 laptop battery charge drops from 50% down to 7% suddenly. And after that, i need to charge the laptop where it gets charged till 99% only. What is the problem i am facing now?. I purchased the...
A sudden drop from 50% to 7% means that the battery is faulty, it is simply a case where it is not holding any charge. I would suggest you contact the seller and check if the battery is under warranty. Hope this helps and good luck.Any question please feel free to ask.
Dec 30, 2010 | Lenovo IdeaPad Z560 Notebook
Flashing icons while charging... am I really charging?
If the iPod is showing the "Sad iPod face" icon, this means that the hard drive inside the iPod (located on the logic/circuit board) has died/failed and needs to be replaced. If you plan on replacing this part, you may also need to purchase and solder a new battery to the iPod logic board if you were to do it yourself.
May 26, 2009 | Apple iPod nano
Battery problem-plugged in, not charging. Lenovo 3000 N100.Type:0768.Model:24U.S.no:L3LA215. Please offer a solution.
Had the same problem with a manufactured refurb, would go to 79 %, if you go to power options, change plan settings, change advance power settings, then to the Lenovo energy management tab, press the big enable Lenovo energy management, click on the blue gear to the left of the question mark, if "Optimize for Battery lifespan" is selected it will only charge the battery to 80%, change this to "Optimize for Battery Runtime" and it will charge to 100%
Feb 26, 2009 | Lenovo 3000 N100 0768 - Pentium Dual Core...
IBM Lenovo ThinkPad T61 6466 Notebook Logo
75 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
