Question about Amana Ovens
Amana convection. Showing a F1 code on the panel. Model ARTSC8650WW
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. F1 error indicates that the control board (ERC) has gone bad and the electronic range control (ERC) should be replaced to resolve the issue. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Sep 16, 2010
F1 error code and beeps
Hello;
My name is Peter. I am a retired field service appliance technician.
You need to proved me with the oven model number. This number is located on a metal plate, on the top front after you open the door.
The general code F1 indicates a communication problem within your control system.
The code F1 is different depending on the manufacture and model number.
Mar 17, 2015 | Ovens
AOCS 3040WW convection oven
F1 Error code for Amana indicates a failed electronic range control (ERC)... that's the main computer behind the keypad. Post back with the exact model number and I'll assist with part number and replacement procedures.
Aug 29, 2007 | Amana AEW3530DD Electric Single Oven
Amana Convection Oven - Not heating in normal bake mode, but works otherwise
I will say that is the control board that is not working properly. Have you try to unplugged for phew minutes?, this will reset the current settings. If not, I will star replacing the control board. Good Luck!.
Jan 13, 2014 | Amana Ovens
MY AMANA DROP IN OVEN IS SHOWING A F1 CODE ON THE KEYPAD. IT KEEPS ON BEEPING AT ME. WHAT DO I NEED TO CHANGE??
F1 code means a shorted keypad. Replace the membrane or control, depending how it's available
Jul 14, 2011 | Amana Ovens
Amana self cleaning oven Model ACS7270AS, Seril 10924419AT F1 And F5 code come on control panel and continuous beep. All burners and other oven controls seem to come on ok. How do we clear the beeping...
Both F1 and F5 are the code for a board failure; it would need to be replaced. What you could try is disconnect the oven for a few minutes and then turn the power back on. If that does not do the trick you would need a board
May 24, 2011 | Ovens
F1 error on SS Amana Convection wall oven
The control panel has a design problem, and it gets dirty and worn over time. I have replaced mine once, and it happened again less than 2 years later. I took the panel out, and inspected it. I found a web solution that said to shim the panel out away from the housing slightly because it rubs on the metal housing around it and damages the control board contacts. I could see little scratch marks on the plastic skin around the edge of the button area, so that made sense. I tried it, and it still did not work.....panel was still beeping. Mine seemed to be the timer control buttons that were going on and off. So, I took it out again, and actually peeled the control surface off of the control board. No going back now, I thought. I got it off and looked at the control panel. It looked fine, but there was a lot of gunk and wear marks around the edge of the plastic button area. I cleaned it up with alcohol swabs, and put the cover back on the board. It was still sticky enough to go back on. I reinstalled it, and "bingo" no more problem. It has been fine for 3 months now. Yahooo!
Oct 16, 2008 | Amana AOES3030 Electric Single Oven
F1=Electronic range control failure
It is telling you may have a fauilty control...need to replace control or EOC
Jun 03, 2008 | Amana AOCS3040 Electric Single Oven
CODE F1 AND OVEN DOES NOT WARM UP ABOVE 250
looks as if th ef1 only pertains to the erc(electric range control), the switch membrane qould be an f7 (shorted key pad, the oven sensor os diff code all together
Feb 26, 2008 | Amana AOCS3040SS Electric Single Oven
AMANA SINGLE CONVECTION OVEN CONTROL PANEL SOME KEYS INOP
Usually the keypad is separate and connected with a ribbon cable.If so, you just need to order a new keypad assembly
May 21, 2007 | Amana AEW4530DDS Electric Single Oven
Amana Convection Oven - Beeping Continuously
F1 code and continuous beeping. This is a common problem with that type of Amana control. The control panel has a design problem I think, and it gets dirty and worn over time. I have replaced mine once, and it happened again less than 2 years later. I took the control panel out, and inspected it. I found a web solution, that said to shim the control panel out away from the housing slightly because it rubs on the metal around the opening and damages the control board contacts. I could see little scratch marks on the plastic skin around the edge of the button area, so that made sense. I tried that, and it still did not work.....panel was still beeping. Mine seemed to be the timer control that was going on and off, and then eventually an F1 error. So, I took the panel out again, and actually peeled the control surface off of the control board. No going back now, I thought. I got it off....it is really sticky.......and looked at the control panel itself . It looked fine, but there was a lot of gunk and wear marks around the edge of the plastic button area. I cleaned it up with alcohol swabs, and checked to make sure none of the printed circuit paths had any wear or damage, and then put the cover back on the board. It was still sticky enough to go back on, and stay in place. I reinstalled it, and "bingo" no more problem. It has been fine for 3 months now. Yahooo! The pic below is just an example pic from the internet. My model is slighty different, but the panel looks basically the same. 1_23_2012_2_51_28_pm.jpg
Aug 22, 2006 | Amana AEW3530DD Electric Single Oven
Ovens Logo
156 people viewed this question
Top Amana Ovens Experts
Dan Webster
Dan Webster
Sal DeAngelo
Ismael Rodriguez...
Are you an Amana Oven Expert? Answer questions, earn points and help others
