Question about Logitech Cordless Mouse
Logitech wireless mouse
It might just be batteries but I have new batteries in the mouse and I am recharging others. When I put the usb connection to an ION cheap digital camera that my neice gave me into the computer the mouse stopped working. Even after removing the camera and restarting the computer.
Do you think it is batteries or has the digital camera erased something? I no longer have the logitech manual...that I know of but maybe it is a simple solution without searching for the manual? Any thoughts experts?
p.s. I have real difficulty with the keyboard pad
  • Anonymous Jun 13, 2008
    for some reason the mouse keeps turning off and not staying connected having to push the connect button on bottom every 5 seconds please help.
  • 8,637 Answers
First I'd reinstall the CD software that came with the Keyboard and mouse. Then I'd try the following.
Normal 0 Press the Receiver button (and the lights will start flashing.
Then if the Keyboard isn't working, press the small RESET/CONNECT button on the back of the board to connect the keyboard to the receiver.
If the MOUSE isn’t working, push the small RESET/CONNECT button on the back of the mouse to connect to the receiver. Then they should work okay.
Also check to see if you have enough memory to run all these functions.
Hope this helps. Bud
Posted on Jan 20, 2009
Clicking issues on logitech wireless mouse
  • 1 Use the mouse on the same side of the computer where the Logitech USB transmitter is attached so there is a clear signal between the transmitter and the mouse.
  • 2 Check the USB transmitter that comes with the Logitech mouse to be sure it is correctly plugged into the computer. The red LED should be illuminated on the transmitter if it is connected properly. If not, the signal cannot reach the wireless mouse.
  • 3 Turn the mouse upside down to check the on/off switch. Be sure it is switched on.
  • 4 Check the battery compartment by sliding the top housing off the mouse to confirm the rechargeable batteries are installed correctly.
  • 5 Charge the batteries if the mouse LED does not illuminate. The charger cord plugs into the front end of the mouse and the other end connects to a free USB port on the computer.
  • 6 Clean the desk surface or other flat area if the mouse is not tracking. The problem could be dirt or grease interfering with the tracking ability of the device.
  • 7 Open the Logitech software called SetPoint, which manages the mouse, to troubleshoot button functions. Open the program by double-clicking SetPoint from the list of software on the computer, then click "Mouse Settings." Click the "My Mouse" tab and check (or uncheck) all the task boxes that are desired for operating different mouse functions, then click "Apply" and "OK."
  • Mar 17, 2012 | Logitech Cordless Mouse
    My logitech mouse M215 is not working, at first i taught that it was just the battery but when i replace it instead of having a yellow light in the led it appears to be orange, i just want to know what is...
    This problem is likely to be a lost connection. The connection between the mouse and the USB receiver can be lost due to several reasons such as:
    • Low battery
    • Moving the USB receiver from one USB port to another
    • Moving the USB receiver to another computer
    • Plugging the USB receiver into a USB hub or other unsupported device such as a KVM switch (your Unifying USB receiver must be plugged directly into your computer)
    • Using your cordless mouse on metal surfaces
    • Radio frequency (RF) interference of more powerful wireless devices such as:
      • Wireless speakers
      • Computer power supplies
      • Monitors
      • Cellular telephones
      • Garage door openers
    Eliminate any problem sources mentioned above that might be affecting your device.
    May 11, 2011 | Logitech Computers & Internet
    My logitech wireless mouse is not working. the s/n is lzb34356296
    1. Try putting in new batteries to the mouse.
    2. Connect the mouse to the computer by pressing the button on the bottom of the mouse AND the mouse USB connector at the same time.
    3. Try another mouse to see if the logitech mouse is the issue.
    3a. If the other mouse works, then the logitech mouse is dead. You can usually send eWaste to a nearby computer store or general recycling center.
    Apr 25, 2011 | Logitech Cordless Mouse
    The wireless keyboard and mouse are not working.
    • Check to ensure that the wireless receiver is plugged into your computer. Press the "Connect" button on the bottom of the receiver to attempt reconnecting your mouse and keyboard to the computer. If your mouse and keyboard use Bluetooth, ensure that your computer's Bluetooth is active and detects the mouse and keyboard.
    • Check to see if the keyboard and mouse are turned on. If the power indicator lights on the keyboard and mouse are not green, press the "Power" button to turn the keyboard and mouse on.
    • Check the batteries of the mouse and keyboard. If the batteries are dead, replace them with fresh batteries and reconnect the mouse and keyboard to the computer by pressing the "Connect" button on the bottom of the wireless receiver attached to the computer. If your mouse and keyboard use rechargeable batteries, let the batteries recharge before using the device again.
    • Uninstall and reinstall your wireless keyboard and mouse drivers. Sometimes, the Logitech drivers are at fault for a bad connection. Use the Control Panel to uninstall the old drivers, then visit the Logitech website and install the latest drivers for your keyboard and mouse.
    • Search the Logitech Support Database. If your keyboard and mouse are still failing to function properly, visit the Logitech Support website and browse the support page for your product for specific solutions.
    Feb 04, 2011 | Logitech Computers & Internet
    Why does my logitech wireless mouse stop working, and then when i take out the batteries and put them back in it works again for about a min or less?
    did you try new ALKALINE batteries not RECHARGABLE some times rechargable batteries seams to be charged but they are actually not when they get old
    hope this helps!
    Dec 31, 2010 | Logitech Cordless Mouse
    My Logitech mouse is wireless # CE0682 and the red light on the mouse is always flashing, even when on the receiver. I also have some problems when I want to use the mouse to hilight a block of text, as I...
    Gina, I've had my Logitech ce 0682 for years and have had some similar problems. The mouse is supposed to rest in the cradle and recharge the batteries, but I've noticed that it rarely works for me. The connectors on the mouse seem to scuff and corrode easily and I'm sure that degrades its ability to charge batteries. So my solution was to buy a 4 pack of rayovac rechargable batteries(AA) and a usb battery charger. I never put my mouse in the cradle now and keep 2 batteries recharging at all times so I always have fresh batteries when that pesky red light comes up telling me the batteries are dying. As far as your highlighting text problem. Sorry don't have a solution on that one.
    Sep 03, 2010 | Logitech Cordless Mouse
    Wireless mouse worked fine until I put in a new battery; not now
    check the transceiver which is usually attached to one of your usb ports.
    you can try installing it to another port.
    May 31, 2010 | Logitech 9311570403 Mouse
    Logitech mouse frozen up we changed batterys in
    If the mouse is freezing up though the batteries are fully charged, here's what you need to do:
    1. Try to use different batteries just to make sure that it's not a power issue.
    2. Connect the wireless USB dongle into different USB ports of the computer.
    3. Try to connect the USB dongle in different computer and try to use the mouse (to make sure that it's not a computer issue).
    4. Make sure that there's no cordless phone, cell phone and other wireless devices that might interfere the wireless signal.
    The Logitech wireless mouse is running on 2.4MHz frequency, same frequency as the other wireless devices. Any wireless device might cause the mouse to freeze.
    If same problem occur, then it's a hardware problem. Contact Logitech and RMA the mouse.
    Thank you and good luck!
    Apr 18, 2010 | Logitech Cordless Mouse
    I replaced the rechargable batteries in my logictech wireless mouse and put on the charger for 8+ hours - my mouse still does not work. what else can be wrong? It is frozen in the middle of my screen.
    You may want to try with normal batteries instead of the rechargeable ones.
    You have not provided the model no of your mouse. Is it connected to PC or laptop?
    Are you able to go to the logitec mouse setup in control panel and check if the diagnostic works.
    Some wireless mouse devides have a reset button which you sync with the base unit that goes to the USB port. If this one has it, then try to resync.
    Waiting for your responses so that we can diagnose the problem further.
    Jan 18, 2010 | Logitech Cordless Mouse
    The battery is dead
    what happens if you put the mouse on the charger and leave it there for 2-4 hours?
    Does it recharge?
    I supose you could replace the recharable battery yourself by opening the mouse and so on, but finding the right type of a battery for it might not be as easy as that. Id recommend takeing it to warranty repairs if it still has such.
    Other options would be to buy a new mouse.
    Mar 09, 2008 | Logitech Cordless Mouse
    Logitech Cordless Mouse Logo
    108 people viewed this question
    Top Logitech Computers & Internet Experts
    micky dee
    Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
