Question about Whirlpool Dishwashers
Whirlpool adp8540 - goes throught the wash cycle without the soap door opening, the water gets into the soap box, and the powder or tablet (I've tried all the brands) are wet but remain in the soap box. When I flick the level on the soap box, works just fine, just doesn't happen during the wash cycle.
  • mara901 Sep 16, 2010
    checked the racks, gave them a good shake and push, dishwasher worked perfectly, there was a part of the cup holder sticking just a bit, didn't notice it could have blocked the soap box door, but it was. thanks very much.
  • 375 Answers
Normally, the dispenser is waterproof when closed, so the detergent should not get wet. Most likely the actuator of the dispenser works and does open the door, but something is blocking it from opening all the way. Look for stuff not it its place, ie a dish behind the rack, silverware basket placed incorrect, or (most likely) reversed lower rack.
Posted on Sep 16, 2010
  • gazzaz Oct 10, 2010
    I have the same model and the tablet is dropping out of the dispenser into the cutlery tray and is not dissolving. The dishwasher is 7 years old, and has been working Ok until just recently. Any advice you can give would be helpful.
  • First Choice Appliance
    First Choice Appliance Oct 12, 2010
    You have no water in the dishwasher during wash cycle. Check water valve, faucet, and water level switch (float)
I have a whirlpool Adp8540 that seems to go through the wash cycle completely but when we open it up the water has not gone through the spraying arms and the soap is a solid mass at the bottom of the...
It is likely the water circulation system is faulty. This dishwasher uses a single motor to run the water pump and the drain pump. If you hear the wash pump operate during wash cycle then it is likely there is a blockage in the water circulation manifold which distributes the water through the arms.
If you do not hear the pump operate during wash cycle then the sensor is faulty. The sensor tells dishwasher to switch to drain cycle from wash cycle.
Try following the diagrams at top of this website to get idea of parts.
Oct 13, 2011 | Dishwashers
My soap doesn't dispense out of the dispenser of my Whirlpool ADP8540. Can someone assist?? I have checked the draws are in correctly and there are no obstructions. It goes through the whole cycle...
Hi and welcome to FixYa, I am Kelly
There are several things you need to check.
1. The Upper and lower wash arms for internal debris. NOTE how they are installed... The lower wash arm it would be wise to take a picture first before removal. Take them off one at a time. Flush and clean them making sure there are no clogged spray jets.
2. While the lower wash arm is removed inspect arond the lower wash arm support for any clogged passages. Clean as necessary.
3. Use a flashlight and look around the lower wash arm support especially from the top and sides.
You may have to remove the support to clear any obstructions. Make sure to ONLY remove the support screws and not the pump motor screws.
4. The last thing to look for are things like a damaged sump housing or pump motor impeller.
5. Pause a cycle and check the water level. If the water level is too low due to a damaged float switch actuation arm this could also cause the symptom your dishwasher is presenting. It can cause the unit to cycle on with very little internal water. Time the fill cycle... and let me know how long it takes to fill and start.
Thanks for choosing FixYa,
Kelly
Jul 26, 2011 | Whirlpool Dishwashers
Washing machine drum always smells of stale water. Have tried hot washes, washing machine cleaner kits, cleaning filters, leaving door open, have also checked machine is correctly plumbed in but cannot get...
This will potentially sound odd, but run the 90 degree cycle with 3 dishwasher tablets in the drum. The smell is bacterial and probably the result of a build up of residue from biological soap powder (Which is simply bacteria that eat your stains). Dishwasher tablets are anti-bacterial and will kill the bugs making the smell
Jul 12, 2011 | Whirlpool Washing Machines
I have a WD1 12C Smeg washing machine - when I open the door there is an awful smell reminiscent of stagnant water - the machine it self seems to be running OK I've put it on 90degress empty but still...
This will potentially sound odd, but run the 90 degree cycle again with 3 dishwasher tablets in the drum. The smell is bacterial and probably the result of a build up of residue from biological soap powder (Which is simply bacteria that eat your stains). Dishwasher tablets are anti-bacterial and will kill the bugs making the smell
Jul 07, 2011 | Smeg WDI12 Front Load Washer / Dryer
The dispenser door is stuck in the closed position. No matter how much I try to jiggle it open the door will not slide out. How do I get the door to open without breaking something?
Hi stuwstark, you could try running a quick wash cyle without any clothes in the tub once cycle is activated you will hear water flowing through the dispencer holder from there you can try riggling the dispencer to see if it will loosen up, in some cases the dispencer holder can become stuck due to dry soap powder clogging up the sliding rails also the dispencer holder can become stuck due to the liquid detergent box "insert" becoming loose and jamming it self up against the top casing of the dispencer holder so by applying the cycle when the water flushes thru the holder could ease the hard powder or could float the insert making it easier to open,try it and see how you go, thumbs up if it helps thanks.
May 06, 2011 | LG WM-2277HW Front Load Washer
My whirlpool dishwasher soap dispenser is apparently not opening during cleaning. I find dirty dishes and clumps of soap in the hopper. Whirlpool quiet partner II
I bet your clumps of soap began with the beginning of the use of a different DW detergent powder.
Try this (trust me) Go buy a box of brand name Dishwasher powder (e.g. Electrosol or Cascade) Use it for two loads of dishes and report your results back here. OK?
Apr 17, 2009 | Dishwashers
Soap not being used
We learned from our new Duet that when washing with Tide soap powder, there is an adjustment inside the pull out drawer where the soap powder goes. You will see a grey plastic slider that goes to the right for liquid soap & to the left for powder soap.
Moving this slider to the left corrected this problem - not using all of the soap powder needed - for us.
Good luck !
Marilyn in FL
Jan 23, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Dishwasher problem
Symptoms:
Dispenser lid is open. Caked powder at (what would be during normal operation) bottom edge of soap dispenser or caked powder fallen onto dishes or dishwasher bottom. There may be loose powder in rest of dispenser or spilled down inside door or onto dishes underneath dispenser.
Solution:
Keep the area around the soap dispenser lid clear when loading the top tray.
Explanation:
The soap dispenser needs to swing open during the wash cycle. In many dishwashers the top tray has an indentation as wide as the lid of the dispenser. This allows the top tray to be as large deep as possible while still allowing space for the dispenser lid to open. People often pack their dishwasher with things overhanging this gap.
During the wash cycle the catch will release but the overhanging cutlery or crockery prevents the lid from opening all but a few degrees. Some water will splash in but not enough to wash out the soap powder. The soap powder at the bottom of the dispenser will then cake.
When the front door is opened the spring loaded lid, which is partly open, will of course swing fully open and you'll be convinced that the lid opened normally during operation. If this is the problem then if you're very careful and open the door very slowly you can actually hear the lid flip open. Also, depending on when the lid opens, how far it opened during operation and how fast you open the door you may find soap powder spilled down to cover the dishes at the front or down the inside of the door. This happens when you first open the door and obviously there couldn't be loose powder there if the powder had emerged while there was water washing around. Seeing the lid open as you open the door is a lot harder but can be done on some machines.
Oct 24, 2008 | Whirlpool 24 in. DU1100XTP Built-in...
Dishwasher
If you are you using a liquid soap or packets that will be the main problem.If your unit fills with water circulates the water and drains the water,and also heaters are working then you probally need to change to cascade powder soap.The film on the dishes is soap.The unit has so much build up in it that when it gets to the rinse cycle it is rinsing dishes with soapy water.You need to get 2 medium bowls fill both 2/3 up with white vinager,place one in upper rack and one in lower rack and run unit on longest cycle letting the vinager splash out during wash.do this with no soap and no dishes.Having soft water will allow you to use less soap.
Apr 23, 2008 | Dishwashers
Dishwasher not cleaning well
clean the dispensor assy around the spring door hinge witha vinegar water solution . liquid detergent has a tendency to not fully break if your water is not hot enough, causes doors to stick, reccomend running hot water before starting d/w, and using a quailty powder( not tabs) detergent
Feb 20, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Dishwashers Logo
171 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
