Question about Kenmore 25512/ 25513 Progressive Canister Vacuum
Model # 116 28614801 no suction, better bar works,
Model # 116 28614801 no suction, better bar works, hose not clogged, all filters clean and clear, new bag
reddevil6
  • 1673 Answers
SOURCE: Sudden loss of suction.
Check the inlet down by the brush roll to see if it is clogged. Also check the belt to be sure it is ok. Is there suction at the hose? If not then it is still clogged.
Posted on Feb 13, 2008
SOURCE: model 116 hose clog?
http://geeksquad.fixya.com/ThreadView.aspx?prdid=109459&thid=699656
Model 116 hose clog?
Posted by rfrazelle on Jun 23, 2008
My old canister model 116 followed with numbers 2839580 marked Kenmore 3.9 with power-mate, worked fine until the bag got overly full. I have changed the bag, cleaned the filter, and removed a nasty hair/fur/dust clog :-p from the lower metal tube of the power mate. It now has very weak suction and won't pick up anything. I suspect a clog in the grey plastic flexible tubing attached to the canister but cannot get it apart. Advice?
RJ
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Kenmore 22313 Bagged Canister Vacuum. The best way to find a clog in an electric hose is to use a steel ball or a large marble to place inside the hose and to let it so threw as far as it can to determine where the hose clog is. Once you have determined where the hose clog is then you can use a small end of a broom handle of take an old wire coat hanger and place a hook on the end and try to pull the clog out of the electric hose – the electric hose is very expensive so try not to damage the hose in any way, shape or form. Or another way is that id you have another canister vacuum you can try to pull the clog apart by using two vacuums turned on and running. If you are successful then run the round marble or steel ball thru the hose again and the clog should be cleared.
http://www.sears.com/ Customer Service 1-800-4-MY-HOME 1-800-469-4663
Thanks, Don the Vac Man
Go Ahead. Use Us.
Posted on Jun 24, 2008
chris321918
  • 32 Answers
SOURCE: vacuum not picking up
At the top of your wand, do you have a plastic swivel that cover a hole in the wand? This is for when you are cleaning curtains, and if that is open, or cracked you will loose suction there... also check your hose for cracks, or breaks. If it were in the shop I would put a gauge on it... normal suction is about 80-95 inches of water lift at the end of the hose. Once you have check each section of the hose, and wand, check the housing for cracks, a missing gasket (Very Good Reason For Lack Of Suction) As to your Filter, how long have you used that one filter, you can clean them for a while, but once a paper filter gets full of FINE dust you won't get it all out, you will have to replace the filter itself at that point. I hope this was helpful.
Posted on Jan 19, 2009
  • 3 Answers
SOURCE: I bought a Kenmore canister
Okay, bear with me. Is it possible you have a suction adjustment, dial somewhere on vac. Check and see and if it does, be sure it's all the way up. Also, try removing hose and run a broom handle fr. one end to the other...BUT be careful not to stretch or break hose, they cost BIG BUCKS.
Posted on Jan 20, 2009
  • 71 Answers
SOURCE: poor suction (new bag, clean filter, clear hose)
check the impeller on the moter it may be missing a fin or two (question does it make any unusual noise or vibration ?)
Posted on May 02, 2009
Riccar 8995 no suction
I think you mean it's an 8955, Riccar has not had a 8995 model. If there is no suction in the hose it has to have something clogging it. Open the little round opening on the back of the vacuum where the hose attaches to see if you have suction there.
May 18, 2014 | Riccar Vacuums
My attachments tool has no suction. I made sure I have selected tools and I cleaned the lint filter. There is definitely suction in the machine, but it does not come through the attachments hose.
Check the attachment hose for any hindrances like clogged with dirt or object. Also a big hole cracks in hoses will cause suction to divert it outside. Clean the machine to make sure it will provide suction powerfully. Regularly clean it and you will assure it's will perform better.
Thanks for asking.
Jul 17, 2011 | Bissell 9500 ProHeat 2X CleanShot Upright...
No suction using extension hose for Bissell Bagless Upright vacuum. i checked for clogs and found nothing. shannon
Check the sole plate where the beater bar is. You may have to remove the roller brush flap to get into the roller brush and then check the main dust channel beside it. Usually if there's no suction on the hose it means that:
1) The hose is blocked 2) The filters are needing cleaned / washed and dried for 24 hours or see my tips! 3) There is dust clogging after the beater bar/roller brush.
Jul 18, 2009 | Bissell CleanView II Plus Upright Bagless...
No air pressure to **** up dirt
First test suction on unit without the hose, is there suction? If yes, attach hose and test. If no go to the door to outside, attach hose to the top of unit where it blows (under handle on top), put hose out door and turn on. The stuff clogging the hose should blow out the end.
If it wasn't the hose check the wand, and then the power nozzle and using the above to clear obstruction.
FQ Master
Your Authorized Filter Queen Service & Supplies
888-637-4692 in Iowa
May 31, 2009 | Filter Queen Majestic Canister Vacuum
No suction. filter and hose clear. motor high pitch. don't know how to remove cover to check motor.
something is clogged somewhere start from bottom and foolow suction path all the way through. wht kind of vacuum?
Apr 14, 2009 | Vacuums
Dyson DC 14 lost suction to beater bar/ suction to hose/stick
My Dyson DC14 had no suction...see if this works...turn the Dyson upside down...there is a length of hose that connects the bottom of the vacuum to the top, careful remove one end of the hose and check for debris...mine was clogged. Removed the clog and voila...it works. Thanks for the above info on checking the hose for cracks.
Apr 11, 2009 | Dyson DC14 All floors Bagless Upright...
Hoover windtinnel suction problem
the intake hos at the bottom might be clogged.first take all the filters out and disconnect the hos completely from the vacuum,then check and see if you have suction.the intake hose is the clear looking one at the bottom that wrapps itself up from the base to the backside of the upright.you can use a coat hanger to push out the clog if there is one just bend the tip till its rounded.work it down into the intake hose from the back.after removing the hose and the filters you should have suction.just make sure all the filters get cleaned .you can blow out the hose with a garden hose
Apr 02, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
No suction
Check the main filter cone - if it has a rip in it, then there won't be any suction in it, also clean it gently with a paint brush to get all of the dust out and check the back of the upright after the bin is taken out as sometimes there is dirt clogged at the back. Check the front of the sole plate i.e. where the roller brush is and check the dust channel behind this as it can get clogged. Due to the nature of this vacuum with the hose being located at the front of the floor head dirt can be trapped but most of all its the paper pleated cone filter that needs a good brushing. Hope that helps.
Feb 25, 2009 | Dirt Devil Featherlight Bagless Upright...
Losing suction filter clean,hoses clear,output blower good,but very poor suction
if the blower is much stronger than the suction, you may have an air leakwhere the cover fits on tank or possibly a warped tank or cover. feel all around the unit for air being drawn in somewhere besides the hose. try it without the hose on and block the inlet for a couple seconds to see if the unit leaks air in. also replace the filter , dont try to clean it, the pores clog and reduce suction and damage motor.
Jun 11, 2008 | Craftsman 17765 Canister Wet/Dry Vacuum
Hoover eite rewind vacuum has blocked airflow, how do i fix?
Is there suction at the end of the hose, if not then the blockage is in the hose, unhook the hose and dig out the debris, if hose isn't blocked, then clean out the filters, if they get clogged, then air can;t flow thru them and you won't have suction. If you have suction at the end of the hose, then it is clogged down in the nozzle asm. there is an inlet by the brush roll and it comes up to where the hose plugs into. Clean the clog out.
Jan 03, 2008 | Hoover U5507900 Elite Rewind Bagless...
Kenmore 25512/ 25513 Progressive Canister Vacuum Logo
129 people viewed this question
Top Kenmore Vacuums Experts
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
