Question about Maytag Dryers
MAytag dryer pyet344ayw will not turn on no interior light
  • krishutson
    krishutson Sep 13, 2012
    I'm having the same issue with my PYET344AYW Dryer
  • 3 Answers
I pulled out all the resisters, fuses, timers, and door switches and found that the problem mine was having was the thermal fuse had blown. While tearing apart the whole dryer I found a dryer sheet had somehow worked its way past the lint trap clogging up the exhaust tube which is what caused the fuse to blow, I'm thinking. I found this fuse on amazon for like 3 bucks, better than buying a $500 new dryer. Here is what you'll need:
LA-1053 Fuse Kit for Dryer
Posted on Sep 15, 2012
  • Maytag Master
  • 43,501 Answers
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Sep 16, 2010
Maytag performance dryer model PYE2300AYW won't stay running after releasing the start button
Maytag Dryer Won't Start - Testing the Start Button - YouTube
? 1:26
https://www.youtube.com/watch?v=gJwYV8HkTbk
Oct 7, 2013 - Uploaded by Bill Newberry
This video shows you how to test the start button on a MaytagDryer. ... dryer medc200xw0 will not keep running after releasing the start button.
GE Dryer won't stay on after turnin
Dryer won't continue running when start button released ...
forum.appliancepartspros.com > Appliance Repair Help > Dryer Repair
Jul 25, 2014 - 3 posts - ‎2 authors
When I push and hold the start button the dryer motor starts and heats. It will not continue to run when I release the button. All thermostats ... button released. Model Number: PYET344AYW Brand: Maytag Age: 5 - 10 years .... Check for 120vac on the purple wire at motor after releasing start button. If it goes ... GE Dryer will not stay running when start button released ...
Jul 26, 2014
Starts but won't stay running
Sep 12, 2013
Dryer won't stay running
Apr 23, 2011
Jan 11, 2011
More results from forum.appliancepartspros.com
Jan 01, 2016 | Maytag Dryers
Maytag performa dryer model #PYET344AYW wont stay running
Yes, I suspect the motor is at fault. The motor you need is available below!
Motor <----- CLICK HERE FOR THE CORRECT PART FOR YOUR MODEL
Aug 23, 2012 | Dryers
Need to know cu ft capacity of maytag performa dryer model pyet344ayw
Go to support on the Maytag website. Enter your model number, click on downloads, and select an owners manual.
murf427
Aug 04, 2012 | Maytag Dryers
My maytag pyet344ayw dryer will turn on but no heat comes out
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
Oct 24, 2009 | Dryers
Maytag Performa Dryer won't start.
I would suggest checking and probly replacing especially if you cant hear the timer motor.
Mar 28, 2009 | Zanussi TD4112W Electric Dryer
Maytag dryer quit working
check your braker turn off then back on
Dec 12, 2008 | Dryers
Maytag performa dryer assistance
Hello, My name is Juan. I will need help to find the problem with some suggestions. My dryer won't start at all, even when I open the door the light bulb inside the drum did not turn on. I check the power source it is ok. Please help with alternatives for a solution. Maytag electric dryer Mod # PYET344AYW
Thanks,
Juan J.
Jun 07, 2008 | Dryers
Dryers Logo
237 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
