Question about Cycling
My wife rides her Trek WSD 7.5FX and she has problems with the left shifter. Her hands/fingers are quite small and she has a problem pushing the shifter with her thumb all the way to change cog. Please help. Thank you.
    Genius:
  • 1,788 Answers
Take it to your Trek dealer, they know how to adjust the shifters that she will have no problems.
Posted on Sep 16, 2010
2000 vw beetle stuck in park with a yellow light illuminated next to park
THERE IS USUALLY an over ride location you push a small pocket scredriver in there by the shifter on the consol so you can still shift the car until you get it checked out.
Nov 09, 2014 | 2000 Volkswagen Beetle
Trek 7300 effort pedaling
If the wheels spin free then I would look at the bottom bracket. All of the force you use for pedaling relies on the bearings in the bottom bracket being good. Are the pedals hard to turn by hand? Do the pedals themselves spin freely? If the wheels turn, this really only leaves these two rotating points as possible suspects.
Sep 17, 2014 | Trek 7300
John Deere L110 riding mower automatic won't start
have you checked the micro switch under the seat
May 31, 2013 | Garden
Which shifter should I change while riding?
Well, the basic principle is this: If you want a big change use your left shifter and if you want a small change use the right shifter. The right shifter is more for nuances and the left one will make a big difference in your riding speed and difficulty.
Jan 17, 2013 | Cycling
Key stuck in ignition of 2005 volvo XC90 and won't move out of neutral
same thing happened with my wifes xc. the shifter button was the problem. pull out on the button a little. if it pulls outward then it should be the same thing i experienced. at first i was able to correct this by pulling out on the button and inserting my finger under it. there is a thin metal rod in there that controls the shift cable. try pushing it back up a lil and keep the button as close to your inserted finger as you pull your finger back out. this worked well enough to get the vehicle back in gear so i could get the car home. i then pulled the button out of the shifter by inserting my finger again and carefully pulling on it. once that is out you can use your finger to pull the top of the shift cable upward and shift like you normally would. only way to fix is to replace the shift knob.
Oct 19, 2011 | 2005 Volvo XC90
My foot hits the front wheel when turning
Without much to go on, it sounds like the bike may be a bit too small for you. If it's too late to take it back for a large size, there are a couple of options for you.
1. Buy a set of pedals with toe clips. These will position the pedal under the ball of your foot and keep your feet from sliding forward into the wheel. 2. You may also be able to buy a set of shorter cranks, which are the arms your pedals attach to. Your Trek dealer can advise you as whether these are available for your bike and how much it will cost. Crank length has an effect on the effort required to pedal, though, so make sure you've tried everything else first.
Jan 10, 2011 | Trek 7100 WSD
First time driving a 1967 Triumph motorcycle coming up. Would like advice on where stuff is like clutch, brake, shifter and how to shift -- where the gears are. Thanks. Art asanfelici@verizon.net
Hi Art! First of all, congratulations on your 1967 Triumph... that's a beauty!!!
Basic things to know before riding a bike is it's parts.
Clutch is the lever you press on the left side of the handle bar.
Front disc brake is the lever on the right side of the handle bar.
Shifter is the one you're stepping on when shifting gears and is located on the left side of the engine if you're on it.
Now, you must first know if the gear is on Neutral by pushing the bike before starting the bike. If it's hard to push then the shifter is not in neutral. Press the shifter by your left foot until you are able to push the bike with ease.
Hop on the bike and start the engine. Most bikes have ignition starters but if your bike doesn't have one, then you have to turn keys to on position and use the kick starter. Rev the engine by pressing the throttle grip on the right side of the handle bar.
Engine is running and in idle position. Press the Clutch lever (left hand) and press the shifter once (left foot) DO NOT RELEASE THE CLUTCH YET!!!
Slowly press the throttle with your right hand until you hear or feel the engine purr...
Slowly release the clutch (left hand) until you fell the bike move forward.
If I am not mistaken, shifting the gears of the triumph is 1-down and 4 up...
Every time you shift gears, you need to press the clutch to release the gears.
Hope you'll have fun!!!
Ride safe my friend!!!
Don't forget your riding gears!!!
^_^
Jun 22, 2010 | 1993 Triumph Tiger
Same Problem-My 2006 GX470 won't start -Key won't turn.
Had the same issue with my wife's 2005 Lexus GX470. The issue is that the shifter is not in park (even though it seems it is). The other issue is that without the key turned, you can not move the shifter to neutral. If you look closely at the gear shift, on the left above the P (Park Symbol) there is a small rectangular box that has a **** on one side. _862.jpgTake a small screwdriver and lift the plastic cover which will reveal a button. With your foot on the brake, push the button with one hand and now you will be able to move the shifter to neutral with the other hand. Now, put it back in park and you should now be able to turn your key and start your car. Put the little piece of plastic you removed over the button and go on your way.
Dec 01, 2009 | 2005 Lexus GX470
Gear shift
there is a shift lock over ride button located just to the left of the shifter u have to remove a small piece of plastic to pop out then push a ball point pen through the hole and push down this will unlock the shifter. check to see if your brake kights are working as these cars have a issue with the brake switches which will cause this problem if there is no brake lights replace the brake light switch
Jul 21, 2008 | 2000 Hyundai Accent
Cycling Logo
82 people viewed this question
Top Cycling Experts
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
