Question about Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV
My lamp cover melted and now i get the 3 blinks of the red light...i have searched and searched but can not find a replacement cover anywhere...the model is a KDF-42WE655 and the number on the cover is 4-094-747...please help.
  • Sony Master
  • 5,138 Answers
Google to this website Encompass Parts Distribution and type in your model # they will list parts and prices with PNumber
they have what you are looking for.1-800-638-3328.
Mats Electronics Has Lamps for 99.00 1-800-628-1118
Posted on Sep 16, 2010
  • 1 more comment
  • JPR Sep 16, 2010
    thanks ladywinn but i called them and they do not have one....???? any other suggestions ?
  • JPR Sep 16, 2010
    called again more helpful individual, said my part number show they dont make it anymore but further checking he gave me a part number of x-2048-503-3 and is shipping one out.....will be interesting to see if its the same because i got the part number of 4-094-747 off the inside of the melted cover...thanks for your help.
  • ladywinn
    ladywinn Sep 16, 2010
    This is very important that you Clean Cooling Fans of all dust and Dirt, Make sure the Exhaust Fan is Free of Dust and dirt if you are unable to clean Fans ,you must replace them this is the Main reason you had a melt down on Lamp cover.
    Also Sony is offering Deal on replace TV if your Light Engine is defective, you need to go to Sony.com and look up your model number Here is 2 Phone# you can try 1-888-649-7669
    1-239-768-7547
What does the yellow blinking light mean on Mitsubishi WD65837
Here is a whole list for you :
Mitsubishi Blinking Codes :
Constant Green - TV is Powered On
Constant Red - Lamp Failure
Constant Yellow - DMD temp is very high
Blinking Yellow - Lamp cover is open
1 Red Blink, 6 Yellow Blinks - Color Wheel Failure
3 Red Blinks, 4 Yellow Blinks - Lamp Failure
3 Red Blinks, 6 Yellow Blinks - Exhaust Fan Not Working
3 Red Blinks, 7 Yellow Blinks - DMD Fan is not rotating
5 Red Blinks, 7 Yellow Blinks - Ballast Problem
6 Red Blinks, 6 Yellow Blinks - Lamp Missing, Bad Cable between lamp and ballast
And the Lamp cover must be here somewhere in your TV :
For more you can refer to the below link :
Mitsubishi DLP TV Blinking Code Errors Explained Overview of Each...
Jul 07, 2014 | Mitsubishi WD 65837 65 in. HDTV
Sony Grand WEGA KDF-60XBR950 60 green orange green red flashing light
3 blinks is a lamp cover error, did you make sure that the lamp cover is screwed in tight? Also check the lamp cover for deformity, there is a problem with your model where the set over heats and melts the lamp cover a little causing it not to make connection with the lamp cover switch. Let me know if you find either of these problems? If not we can troubleshoot a little further.
Tim Nolan
Sep 14, 2008 | Sony Grand WEGA KDF-60XBR950 60" Rear...
I HAVE A SONY KDS-60A2000 WONT TURN ON. RED LIGHT BLINKS THREE TIMES. TRIED NEW BULB. NO DIFFERENCE
3 times red light blinking indicates that Lamp Cover has not been fixed in its location properly after lamp replacement.
Please make sure lamp cover (its first thing that was removed to replace lamp) is installed securely.
Thanks.
Mar 11, 2011 | Sony KDS-60A2000 60" HDTV
Tv light standby red just keeps blinking after replacing bulb
If red light was not blinking before lamp replacement and after that it start blinking 3 times then pause for three seconds and again blink, check lamp cover that has not been fixed on tv or it is not fixed/ seated correctly there.
Lamp cover is first thing that you removed from tv to replace lamp.
Hope these info will help. If red light is blinking other than 3 times, let me know how many times it is blinking along with tv model number written at rear to provide you helpful info.
Thanks.
Jan 27, 2011 | Sony Grand WEGA KF50WE610 50" Rear...
Power ligth blinks three times then starts blinking red tv wont start
Lamp cover error, lamp cover is not attached securely. Please check the lamp cover if deformed. If the lamp cover has been deformed due to excessive heat exposure, replace it with a new one. Sometimes the lamp cover melts due to overheating caused by poor air ventilation. Clean the fan and lamp compartment to avoid overheating....
Nov 30, 2010 | Sony KDS-60A2000 60" HDTV
I have replaced the lamp block and now the power stand by red light is going on and of (this was a new lamp block). Do I need to reset some how?
If standby red light is blinking 3 times after three second pause then check lamp cover that has no been fixed in its place correctly, it is first thing that you removed from tv cabinet to replace lamp, make sure lamp cover is back in place properly and tight.
If standby red light is blinking more or less then 3 times, let me know to diagnose problem.
Thanks.
Sep 04, 2010 | Sony KDF-E42A10 42 in. LCD Television
Changed lamp and TV won't turn on, power light flashes 3 times
Red light blinking 3 times shows problem with lamp cover.
Lamp cover is not fixed securely in your tv after lamp replacement. Lamp cover is first thing that was removed to replace lamp, check lamp cover and make sure its back in place properly.
Thanks.
Jul 17, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
KDF-50a12U Powers off then standby light blinks 3 times
Please recheck Lamp Cover and make sure it is fixed in its space securely as 3 times red blink shows lamp cover error.
There is small safety switch in TV cabinet under lamp cover that has to be pushed by lamp cover if it is fixed in its position properly. That switch is not being pressed by lamp cover and causing this error.
Thanks.
Oct 19, 2009 | Sony BRAVIA KDL-40V3000 Television
Power light blinks red 3 times and it won't power on. Replaced lamp. What do I do now?
Recheck Lamp cover and fix / place it properly. 3 times red blink shows lamp cover is not seated well.
Jun 03, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Kdf-60xbr950 - red light blinks 3 times for a minute and tv turns off
same problem as others 3 blinking green lights then orangey colors then 3 red blinking lights afterwards shuts down fan runs for about 2 mins solution check your door cover for warpage or deformed just a bit under set screw there is a push in switch try and push it in with q tip while holding turn on tv if it works then that door is deformed and defective change it
thanks for solving my issue tv works again very helpfull thanks
Feb 13, 2008 | Sony Grand WEGA KDF-60XBR950 60" Rear...
Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV Logo
247 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
