Question about Frigidaire Affinity ATF7000E Front Load Washer
Hi,I have just changed a doorlock/switch for a front load frigidaire washer with the door kit retrofit part #131888900 purchased at reliable parts.I followed all instructions carefully and all wires are hooked up correctly but washer will not do anything when I put it in the final spin position to test nothing happens.I checked the new switch with a small screw driver to see if it would click when pressed in and it does`nt.What do you think?
  • 375 Answers
It's not going to click, there is no clicker there, just contacts and mechanical actuator. Hope you did not damage it with a screwdriver. The lock assembly has a wax motor which needs a minute or two to lock the door after the cycle is started.
If it doesn't lock after a few minutes - replace the microcomputer.
Good luck,
Vlad
First Choice Appliance
Posted on Sep 15, 2010
  • First Choice Appliance
    First Choice Appliance Sep 16, 2010
    Additionally, make sure the detergent dispenser drawer is all the way in when testing, some of those washers have a magnetic switch in the detergent dispenser assembly, which prevents turning on the washer if the dispenser is out :)
There are four lights on front of the washer we replaced the door lock and the sensing light is on. water goes into the machine but nothing else happens. we also cleaned out the pump what do you t
I appreciate your inquiry, terri buttafuoco!
Based off the information you have provided you have replaced the door lock on your Frigidaire washer and it is still not operating properly. It sounds like a possible problem with your control panel or wiring harness. I would recommend reaching out to a professional for proper diagnosis and repair to avoid any unnecessary part purchases. I hope this is helpful. -Matt
Oct 25, 2014 | Frigidaire ATF6000ES Front Load Washer
Why want the water wont come into machine
Hi friend, thank you for your inquiry!
I understand that water will not come into your Frigidaire washer, GLTF2940ES, and you have recently changed your door lock. It could be a possible issue within your water inlet valve, switch, or control. Since it could be any one of these underlying issues I would recommend having a professional come out to properly diagnose and repair the appliance to avoid any unnecessary part purchases. Best of luck. -Matt
Aug 18, 2014 | Frigidaire GLTF2940ES Front Load Washer
I have a Affinity frigidaire front load washer and need to replace part number 131763202. The model number of the washer is ATF6000FS1 Thank you in advance
Disconnect power then open the door and remove the spring-hoop assembly that secures the door gasket. Peel off the part of the door gasket near the door lock and switch assembly. Remove the screws securing the door lock and switch assembly to the front panel then pull the door lock and switch assembly out. Transfer the wires to the new door lock and switch assembly then install into place. Put the door gasket back and secure it with the spring-hoop assembly. Click on the link below for the detailed procedure.
Replacing the Door Lock and Switch Assembly on Frigidaire Affinity and Gallery Front-Load Washing Machine
Nov 12, 2010 | Frigidaire ATF6000ES Front Load Washer
The door lock comes
doorlock switch needs replaced.adrian,,,,
Jun 28, 2010 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Front load washer will not do a final spin it hums but nothing happens
You need to purchase the door assembly. It is part #131763245. It is difficult to get to on the washer, you have to take the entire front panel off, but it should fix the problem.
Dec 11, 2008 | Frigidaire ATF6000ES Front Load Washer
Will not work
You might have to replace the doorlock switch assy. N#7 on DRAWING here you also can buy the parts you need
Jun 23, 2008 | Frigidaire FTF2140E 3.5 Cu. Ft. Front...
AEG LAVERMAT
Thank you for your inquiry with Reliable Parts. Your research is as follows.
DOOR HANDLE FOR DANBY MODEL DWM5500W-1
Part number: 660137
Price: $ 6.99
Availability: in stock
All items need to be prepaid with a visa or a master card. No returns on electrical items, factory orders or damaged parts. All other returns are subject to a 20% restock charge. No returns accepted after 90 days from the date of purchase. Please add $4.95 for special factory orders. If you would like to order the part online, please visit our website and type in the part number in the quick find box. From there you can add to a shopping cart and check out online 24/7 If you have any other questions or for phone orders you can contact us at the numbers listed below.
Thanks again Shane Lyth
Reliable Parts
206-575-1791
slyth@relparts.com
1-800-666-0313 ext 1791
Online customer has requested assistance for the following part search:
Brand Name: Danby
Item Description: WASHER DOOR HANDLE
Model & Serial Number and Full Description:
DANBY MODEL DWM5500W-1 FRONT LOAD WASHER THE DOOR HANDLE BROKE OFF . THE LOCK MECHANISM STILL GOOD. NEED ONLY THE PLASTIC PART OF THE DOOR , WHERE THE HANDLE IS ATTACHED. THE SEE THROUGH WINDOW IS GOOD.
Nov 02, 2007 | Danby DWM5500W-1 Energy Star 1.69 Cu.Ft....
Re ad for Maytags
I have a frigidaire front load washer and am experiencing the same problem. The striker has been replaced and the problem is not resolved. I am hesitant to replace the door latch, as this wiring seems not to work. I contacted Frididaire and they gave me part number 131269400 but all parts suppliers seem to only have the new one 131888900. Do you suggest I not replace it?
Aug 12, 2006 | GE WSXH208A Front Load Washer
Frigidaire Affinity ATF7000E Front Load Washer Logo
279 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
