Question about Airtemp B3Q06F2A Air Conditioner
What type of wall plug can I use for this air conditioner! My whole house is 110 or 220
  • 6,927 Answers
If it is a 110 unit,use a regular wall receptacle ,if it is a 220 unit,use a 220 receptacle for 220 it will be made larger and different.Draw a picture of the plug on the end of the cord and go to the hardware store and get them to help you i d the plug.some 110 units are 40 amp,and are a little different than the regular 110 house hold 20 amp receptacle.
Posted on Sep 15, 2010
040463610
How large a space are you hoping to cool? One room? One LARGE room? One SMALL room? One floor of a two-story house? A whole four-story house?
What's your climate like where you live? Very hot, dry, year-round? Cool most of the year but two weeks of hot during the summer? Just a little too warm in summer? Blazing hot all summer, including nighttime?
How's the insulation in the building you want to cool? Is it a plain steel building with no insulation? Is it a trailer? Is it a frame house with 4" walls and R13 fiberglass insulation? An old frame house with no insulation? An adobe building? A timberframe house with 8" of polyisocyanurate foam insulation?
All these are important to know when you select an air conditioner.
For most of the USA, assuming a frame house with 4" of fiberglass insulation, a 10,000BTU air conditioner will cool one large room or two small rooms pretty well, or a 5,000BTU AC will do one medium-sized room. Different places, and different house designs, and different types & amounts of insulation, will all have a profound effect on how much AC you need/want.
Jul 25, 2014 | Goodman Heating & Cooling
Where are the drain ports on a Fedders A3XO5F2E-A My unit is leaking water on the floor even though it is tilted down. ...
The drain holes are in the back corners of the pan...and they will plug with dirt...to get to them you will need to slide the unit out of the chassis if it is that type or pull the whole unit out so you can take the cover off and open the holes...
Then you will be back in business again..
Air Conditioner Trouble - Review the Possibilities
heatman101
Sep 15, 2010 | Fedders AEY12F7F Wall/Window Air...
Water is dripping into the house. I cannot locate the drain plug to clean it. Where is the drain plug located?
it should be on the outside of the unit, look towards the middle back, should be a hole
Aug 29, 2010 | Kenmore 11,700 BTU Multi-Room...
The outside unit of a whole house air conditioner
replace start run capacitor of motor fan
Aug 17, 2009 | Heating & Cooling
A6414w7b b wall unit gfi plug keep tripping problem: fedders wall unit brand new keep tripping the gfi on its power cord
GFI plugs go bad very often if you had a storm in you area. You need to replace the plug. Go to aplliance parts house and they will sell you the new cord. Feed back please.
Jun 13, 2009 | Fedders A6D24E7D Wall/Window Air...
Chemicals in house from pool when running air conditioner
There is a small possibility that the air conditioner is sucking some of the air outside. If you're using a window type a/c, there is a small fresh air intake vent you can open and close. If your using a wall type or free standing a/c, fresh air would only come from opening doors or windows. Using a centralized a/c has a fresh air intake and that could be the cause of your problem. The solution would be an anti-odor filter.
I hope this helps.
Jun 02, 2009 | Heating & Cooling
We installed a honeywell DH90 whole house dehumidifer #B08167014 4026552. Unit is removing water but the supply side is warm air. We are wondering if this is normal or if this air should be cold.
I assume you mean the exhaust side of the dehumidifier, which goes into the supply duct of the furnace.
All dehumidifiers, whether small portable types, or whole house types, exhaust warm air (which is also dry air) as they remove humidity. The whole house unit which you have is a great solution to humidity control. Since the furnace fan should be running on a call for dehumidification, the mixing of the air in the building which is circulating and the exhaust (Dry) air from the dehumidifier negates, or dissipitates the heat in the air coming from the dehumidifier.
Jul 31, 2008 | Heating & Cooling
Leaking A/C
are there some instructions on how did you install them?..it should just be the reverse. in some units, they have small screws at the sides that secures the unit from its shell.
start with the face cover, remove it if you can. some units have a scew at the middle of the face cover before you pull out the filter. if you were able to pull the face cover off, then try to pull the unit and the shell should be left behind still attached to the wall. if this is not the case, then you should pull the whole unit including the shell or casing as others called them.
look for some securing screws or bolts that hold the housing. then if you were able to bring down the whole unit, start removing all the screws all around the unit in order to remove the housing and you can see the dirt on the drainage .
i hope i was able to solve you problem..
pls rate me
tnx for using fixya.
drcool
Jul 22, 2008 | Friedrich CP12C10 Wall/Window Air...
Airtemp B3Q06F2A Air Conditioner Logo
139 people viewed this question
Top Airtemp Heating & Cooling Experts
Tim Whalen
David White
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you an Airtemp Heating and Cooling Expert? Answer questions, earn points and help others
