Question about Frigidaire FEQ1442ES Electric Dryer
Dosent get hot, says cooling down. - Frigidaire FEQ1442ES Electric Dryer
  • Frigidaire Master
  • 43,501 Answers
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Posted on Sep 21, 2010
Hi, i just bought a second hand amcor air conditioner but it dosent send hot air, what can be the problem?
Air conditioners normally blow cold air, unless it has a built in heat pump. You should post the model with your questions.
Jan 08, 2017 | Amcor Heating & Cooling
I have an 97 corolla and when i try to start the car it only cranks and dosent start?
This sounds like a "heat soak"issue(something is failing on a hot engine shutoff).The low tech solution I used to use often was a can of brake cleaner.Get the car hot,shut it off,and try to restart.If it wont,try spraying a quick burst of cleaner at various sensors(to cool them off) and trying to start it again.The most common sensor I would find as the cause was the crankshaft position sensor.(Sometimes a little tough to get at).
May 27, 2012 | 1997 Toyota Corolla
I have a 1996 toyota corolla 1.8 the cooling fans come on when the air is on but it dosent see to come on when the car is running hot
you need to put a new cooling fan relay on, sorry i dont know the exact location on your particular vehicle but when you go buy it the parts store can surely tell you
Jan 15, 2011 | Toyota Corolla Cars & Trucks
Need to wire thermostat
one wire to R the other to W (or W1). Dosent matter which is which
Oct 17, 2009 | Honeywell Electronic Programmable...
Cub cadet 2135 blows fuses, it was fine until I changed the coil, could the voltage regulator be bad? what if I put the wrong coil on? I made jumpers and it gets real hot real fast but when i unhook...
Let me answer each of your questions 1 at a time, why did you change the coil? Was it because it didn't run or for some other reason. What fuse is it blowing? The voltage regulator is only used for your charging system, generally stator is in the flywheel and the armature is bolted to the block under the flywheel. Your voltage regulator is mounted on the engine shroud. Your regulator will get hot / warm to the touch only with the key on it will get hot with the engine not running because there is no cooling air going over the voltage regulator. Your coil is in the ignition circuit it sounds like you have a wire croosed from when you changed out your coil. If this is not the case then you may have a bad coil.
Sep 15, 2009 | Mtd Garden
Ac dosent cool down checked psi is really high if
need to replace dryer and the orifce tube vachum down and recharge, you have contamination in your system.
Jun 28, 2009 | 2002 Dodge Grand Caravan
A/c cooling fine but not heating
The fan generally does not come on until the unit has achieved some high head pressure so that it can produce hot air. If it is low on gas it will not get to this stage.
Jun 26, 2009 | Heating & Cooling
Cooling fan dosent come on when temperture rises(1996 pontiac bonneville se) cooling fan relay where is it located..
You seem to have a bad cooling fan switch...it's connected to the side if the engine and when it gets too hot it turns on your cooling fans. The switch doesn't cost that much, $10 to $15 and takes all of about 15 minutes to replace.
Apr 18, 2009 | 1996 Pontiac Bonneville SE CA Value
1997 chevy 4/4 k 1500 158,000 ml truck stuck in 2nd only when hot
1st check tranny fluid level if good tranny needs to be rebuilt it will go into failsafe mode when the computer sences to much slippage
Mar 03, 2009 | 1997 Chevrolet K1500
Frigidaire FEQ1442ES Electric Dryer Logo
32 people viewed this question
Top Frigidaire Dryers Experts
Tim Whalen
Sal De
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
