I replaced my 2Wire 2701HG-B with a 2Wire 270HG and I can't get it to connect to the internet, can you help?
  • 27,725 Answers
Uninstall 2Wire 2701HG-B then install 2Wire 270HG
Posted on Sep 15, 2010
I have an at&t 2wire 2701hg-b but i dont have at&t internet i have charter and i am not able to figure out how to get my internet to work with this router please help
att 2 wire is a Adsl Modem (Requires a telephone line jack to get the signals) but charter communication is a cable internet service (not DSL) , Requires a TV cable service for internet .
These two jacks differs and there working differs ..
Means : Att works with the username and password type of authentication but charter requires the MAC address of modem for authentication .
Therefore for a cable internet 2wire 2701hg-b modem cant be used . But yes in case charters has username and password authentication and works with the telephone jack in house then its possible to use the same modem.
Aug 19, 2011 | 2wire (2701HG-B) Wireless Router
If I wanted to download Maplestory(PC Game) how long would it take to download if I'm getting my internet connection from my 2wire (2701HG-B) Wireless Router
It all depends on the package & line speed you choose from your ISP ( Internet Service Provider )
http://www.speedtest.net/ this site will give an idea of your connection speed to the internet
the download size is 2.1gb so u can work it out after doing the test
May 27, 2011 | 2wire (2701HG-B) Wireless Router
What steps do I take to configure my 2wire 2701 hg-b to connect directly by ethernet cable to my Directv HD DVR and pick up the dsl signal being transmitted by my primary westell router? Both are wireless...
Connect the cable at both ends and do a red button (inside card door) reset of the DVR. To test the connection, do thus: Menu -> .....setup -> system setup -> network setup -> test connection. If it shows not connected then "reset defaults" and run "connect now"
As a basic security feature the ATT DSL 2Wire 2701HG-B router/gateway requires you to enter its pre-assigned WEP key to connect beyond the unit itself and then to the internet. Since the Direct TV DVR HD24D only does a basic connection without having a place to enter the 2701HG-B WEP key it never actually reaches the internet.
The 2Wire 2701HG-B has the ability for one attached unit to "pass through" its firewall and internal security settings using a so called "DMZplus" mode. I set the HR24D DVR to such a mode within the 2Wire unit and the DVR connected with the internet flawlessly.
Dec 30, 2010 | 2wire (2701HG-B) Wireless Router
AT&T 2WIRE 2701HG-B connection problems
This is a problem with the firmware of your device so the first thing that you can do here is to do a firmware update on it to correct the problem, you can get the firmware from your ISP of the manufacturer of the device...
Sep 10, 2009 | Computers & Internet
2wire 2701HG-B gateway can't connect locally
Have you got MS CLient loaded in the network settings. If not run network wizward on each machine and then try again. hope this helps Mark
Aug 18, 2009 | Computers & Internet
2wire 2701HG-S Embarq to AT&T
that is typically a bad username in the modem, you will have to put there temp user name in for registration for the DSL. and after that you can put the username into the modem that you created during the registration process. Should be taken care of.
May 15, 2009 | 2wire Computers & Internet
Problem getting to internet through 2wire 2701hg-b router
how can I connect a 2wire 2701HG-B router to a motorola SB5101modem?
Apr 22, 2009 | 2wire Computers & Internet
Can't use 2wire router for cable internet
You probably only need to change the connection information inside the 2wire. go to the 2wire homepage using "192.168.1.254/setup" or "192.168.0.1/setup" it asks you for a keycode. Get the keycode that says its for DHCP, doesnt matter who the provider is on this page.
http://www.2wire.com/index.php?p=268
Mar 27, 2009 | 2wire 2700HG-B Router (2700HGB)
Can I use 2WIRE 2701HG-B router in COX internet connection
No. A router has 2 main interface types WAN (for the internet connection side, and LAN (for the home network side) the 'LAN' side often has up to 4 ports and wireless connectivity for the home network.
The most common routers available at electronics retail use a CAT-5 connection for the WAN ports and the LAN ports. Your DSL modem/router uses a phone line input for it's WAN port, which uses a signal type that is incompatible with the cable modem output.
If COX doesn't offer a router with the cable modem package, you can go and purchase and common brand of home networking router, and attach it to the output of the cable modem.
Feb 28, 2009 | 2wire 2700HG-B Router (2700HGB)
2wire 2701HG-B constant power loss
Hard reset the router and reflash or update the firmware.
If still wont work then it will be hardware problem (bad memory).
Oct 03, 2008 | 2wire 2700HG-B Router (2700HGB)
Computers & Internet Logo
121 people viewed this question
David Payne
David Payne
