Question about Ingersoll Rand 1/2" Titanium Duty Air Impact Wrench Combo Kit 2135TIKC
I broke the splined shaft that drives the twin hammers in my wrench. it is a ir 2135ti. can you help? harley
    Habit-Forming:
    Scholar:
  • 102 Answers
FOLLOW THIS LINK TO VIEW THE PARTS SCHEMATIC
Part Listing Order Page
Posted on Nov 28, 2014
3 Suggested Answers
  • 12 Answers
SOURCE: have an IR 2135ti can't get reverse valve part #24
you need special tools to disassemble the air inlet - and i have it
Posted on Feb 19, 2010
  • 12 Answers
SOURCE: need repair diagram ir 2135ti
www.ohiopowertool.com then click on repair then ir then air tools
Posted on Feb 04, 2011
Replace reverse valve ir 2135
Did you ever get the 2135 reversal valve installed?
Jan 24, 2014 | Ingersoll Rand 2135Ti Air Impact Wrench
YOU NEED TO COMPLETELY DISASSEMBLE THE WHOLE TOOL.
START BY REMOVING THE 4 MOTOR HOUSING SCREWS, SLIDE THE HAMMER CASE, HAMMER ASSEMBLY AND MOTOR ASSEMBLY FROM THE MOTOR HOUSING.
THE REVERSE VALVE WILL BE VISIBLE NOTE THE ORIENTATION ON THE AIR OPENING IT LOOKS LIKE A HALF MOON, THE VALVE WITH EITHER BUTTON PRESSED IN SHOULD AT A 45 DEGREE ANGLE.
NEXT YOU WILL NEED TO REMOVE THE INLET BUSHING ASSEMBLY THAT IS HELD IN BY A CLIP THE IS VISIBLE THROUGH 2 SLOTS LOCATED ON THE LOWER SIDES OF THE GRIP, THEY NEED TO BE PRESSED IN TO SLIDE THE INLET BUSHING OUT THE BOTTOM OF THE TOOL. THERE IS A SPECIAL TOOL THAT SIMULTANEOUSLY PRESSES BOTH SIDES OF THE CLIP BUT CAN BE SUBSTITUTED WITH 2 SMALL FLAT HEAD SCREWDRIVERS.
ONCE THE INLET IS REMOVED, THE TRIGGER CAN SLIDE OUT THE FRONT OF THE TOOL
NEXT USE A SMALL FLAT HEAD SCREW DRIVER TO PRY THE REVERSE BUTTON OUT OF THE HOUSING, INSERT THE SCREW DRIVER INSIDE THE INNER EDGE TO PRY OUT,
ROTATE THE VALVE 45 DEGREES IN THE OTHER DIRECTION TO REMOVE THE SECOND BUTTON.
NEXT PUSH DOWN ON THE REVERSE VALVE IT WILL COME OUT THE BOTTOM.
FOLLOW THIS LINK TO VIEW THE PARTS SCHEMATIC.
http://manualarchive.ingersollrandproducts.com/ir_pdfs/Tools/IR%20Industrial%20Tools/Impact%20Tools/04584033_ed2.pdf
Trouble putting axle in
If you are talking front drive shaft then there should be a spring circlip on the end of the splines of the shaft. This circlip has to be compressed to get the shaft out and compressed to go back in. Place the shaft back in the splines and push hard and fast to compress the clip or hold the shaft straight and hit on the end hard with a soft faced hammer
Nov 20, 2013 | 1990 Acura Legend
Need diagram to put on starter drive clutch ***.for 1985 1340cc harley
To replace the starter drive clutch on your 1985 model Big Twin, first disconnect the battery. Drain the primary and remove the primary cover. Remove the starter drive shaft that has the clutch on it. Clamp the drive shaft in a vise equipped with soft jaws and remove the nut from the end of the shaft. The nut is the round piece on the end that has two flats for a wrench to fit. It has LEFT HANDED THREADS. Remove the starter drive and replace it with a new unit. Replace the nut using Loctite 271 red and put the starter drive shaft back in. Make sure you purchase a good starter drive clutch. Avoid the Chinese units as they don't hold up very well. If you need a diagram, go to this site. http://www.bikebandit.com/1985-harley-davidson-fxst/o/m1502#sch209973
Good Luck
steve
Apr 13, 2011 | 2000 Harley Davidson FLSTC Heritage...
I have no problems in reverse but gun seems to stop when trying to tighten. Had the same problem with my 1st 2135ti
Sounds as though you have broken or worn hammers. Try KCTool 715 445 7700. They can and will help you.
Oct 26, 2010 | Ingersoll Rand 2135Ti Air Impact Wrench
Have an IR 2135ti can't get reverse valve part #24 out of handle
Jan 25, 2010 | Ingersoll Rand 2135Ti Air Impact Wrench
Need repair diagram ir 2135ti want to reassemble trigger for 1/2" 2135ti
try going to irtechpubs.com nd under industrial tools you will find your model number and can download a breakdown for it. Let me know if you have trouble, I went thru about 15 sites before I found it.
Nov 02, 2009 | Ingersoll Rand 2135Ti Air Impact Wrench
Cant get the inner hub off the spline shaft (front passenger side)
i assume you removed the nut that holds the spline shaft on the hub? try wd40 and put the nut back on a few turns and beat it with a hammer
Apr 27, 2009 | Saturn Vue Cars & Trucks
IR 2135TI repair manual
Go to: http://www.irtools.com/contact/?pro=&cat=&sbu=&formType=ussales
make a Request for schematic, they have always given me great assistance.
Dec 30, 2008 | Air Tools & Compressors
Ingersoll Rand 1/2" Titanium Duty Air Impact Wrench Combo Kit 2135TIKC Logo
152 people viewed this question
Top Ingersoll Rand Air Tools & Compressors Experts
elunsford
Joe Garcia
Joe Garcia
Eddie Tucker
Level 1 Expert
Are you an Ingersoll Rand Air Tool and Compressor Expert? Answer questions, earn points and help others
