Question about Vizio L32 32 in. LCD HDTV
VIZIO 32 in HDTV color issues
People are red, back ground is washed out and the info band is green. No amount of adjustment seems to help. Any suggestions?
    New Friend:
  • 129 Answers
CLEAN LVDS CABLE CONNECTOR THE END SIDE ATTACHED TO THE CONTROL BOARD, THIS IS THE BOARD WHO IS ATACHED TO THE LCD PANEL .
LCD PANELS FOR VIZIO ARE NOT AVAILABLE ,UNLESS THE TV IS COVERED UNDER WARRANTY ,IF THIS DOESNT HELP YOU HAVE TO REPLACE THE CONTROL PANEL BOARD, TRY EBAY TO GET THE BOARD .IF NEEDED
Posted on May 16, 2008
My Vizio 32 inch HDTV picture colors are all off. I have tried to adjust the tint/colors but the overall picture colors are all off. It is as if some of the primary colors are missing.
Maybe if you are using component input wires, one is not inserted fully. Set color to max and put tint in the center, then flip channels and look for known solid colors items of red, blue and green. You can see when one is missing, as a mixed color will just look odd, but a true r,b or g will just not be there so to speak. Hopefully is might just be a feed wire in, but be careful, as too much pressure on insertion can crack a solder joint inside the set.
Nov 26, 2010 | Vizio L32 32 in. LCD HDTV
All of a sudden the color on the tv is off cant seem to get reds or green at true color
You can fix this yourself all you need to do is to open this the back cover of the television to check for dry soldering and also check the inverter board in the television..
I hope this will help in solving the problem .....
Nov 04, 2010 | Vizio L32 32 in. LCD HDTV
HDTV LCD 32 inch is all green. Good definition but all green. Have tried all color adjustments but even turning down the green all the way still leaves a green screen with some red and blue colors in the...
THe most likely cause for this problem is bad connection of the cable connecting the main TV board with the LCD controller. It's called LVDS cable and is hard to miss, usually fat round and black, connecting a board from the chasis with a little board in the top center of the LCD assembly.
I'd open the TV and gently try and reattach the cable to see if that yields any results. You can try it a few times, in fact I'd do it while the TV is open and working so I can better see if adjusting it makes a difference.
There's also a chance that the LCD logic itself got burned and misses on one of the colors. But I don't remember ever seeing that.
Nov 02, 2009 | Vizio VW32L 32 in. LCD HDTV
My Vizio has no green color. Other color are very
What type of connection are you using? if you're using component, make sure all the red, blue and green matches. If all is correct, go to menu, picture and all your color setting is there
Jun 10, 2009 | Vizio L32 32 in. LCD HDTV
Color distortion
go to your menu select color, select user, and adjust RGB from user. same level R-60, G-60, B-60.
May 29, 2009 | Vizio L32 32 in. LCD HDTV
My vizio hdtv color is off and i need help adjusting it
We had the same problem (for about a week) and finallly realized that the kids had played with the cords in the back of the TV and one connection was loose.
Mar 26, 2009 | Vizio VW32L 32 in. LCD HDTV
Vizio 32 inch now shows mostly only green and red colors
Please try to reset all setting and then to see if the problem is solved. 1. Press the Menu on your Remote Control;
2. choose Set up on the OSD;
3. then choose Reset All settings;
4. Press the Exit on your Remote Control to remove the OSD
Nov 30, 2008 | Vizio L32 32 in. LCD HDTV
Color
Your component cable is switched, check the cable.
Aug 12, 2008 | Vizio L32 32 in. LCD HDTV
Color on vizio 37" lcd
I would recommend a Main board replacement.
Mar 04, 2008 | Vizio L32 32 in. LCD HDTV
Vizio L32 32 in. LCD HDTV Logo
307 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
