Question about Braun Series 7 720 Shaver Electric Shaver
Braun Series 7 Pulsonic Shaver will not switch on. Battery is fully charged, but the power switch does not respond.
SOURCE: Braun 6520 shaver stops working after one use on batteries
dear sir, i have one like yours,your shaver need to change the battery.
Posted on Aug 12, 2007
Cytherian
  • 109 Answers
SOURCE: Braun electric shaver will not charge.
Batteries can be replaced in most Braun shavers, while leaving the current circuit board intact. Braun didn't intend for this to be done, and as such does not sell the batteries alone (they include them on the circuit board). There are some aftermarket Braun shaver parts sellers that can supply just the batteries, but they charge a rather high price. Go to a website like "onlybatteries.com" and you can get AA NiMh flat top batteries that will fit your Braun for less than half the market price.
As for disassembly, it varies depending upon your shaver. Visit "http://web.archive.org/web/20041025223715/63.230.9.155/braun/Srv_Man/SHAVER/" for the older service manuals. More modern day ones can be found by Google searching.
Of course, if you're not comfortable doing soldering, then you'll have to replace the batteries along with the circuit board. Suppliers like "shaveroutlet.com" provide these parts, as VtToolMan mentioned.
Posted on Oct 22, 2009
Cytherian
  • 109 Answers
SOURCE: Battery replacement for Braun 8585
If the "reset" described didn't work all that well, as a last resort you can replace the batteries. You have two choices: put in a battery/circuit-board part replacement (drop in), or solder in new batteries. If you've got some soldering experience, I recommend replacing just the batteries. You can buy new NiMH AA 1.2v flat top batteries rather cheaply (less than $4 per cell) and using a soldering iron, take out the old ones and secure the new ones. Look for batteries with at least a 1650mAh rating. Good luck!
Testimonial: "I believe this is a more viable solution. I will try your advice this weekend. Thanks,."
SOURCE: My Shaver battery doesn't fully charged
Hi... I have the same problem, I got my shaver 2 days ago, and it is written that you need to charge it for 4 hrs in the first time and then the light willl start blinking as an indication that the batery is ful !!! I noticed the following :
1- After 15 Mintues the light simply turn off without any blinking !!!
2- The shaver is charged and runs for almost 1 hrs !!!!
Is this is a fault ??? shall I bring back ...
Please answer me what was your case ??
Posted on Apr 29, 2010
SOURCE: Braun Series 7 760cc dead after 2 months
I had the same problem with my Braun Pulsonic and managed by luck to fix it without having to take it apart. All I did was to leave it out of the charger for a couple of days. The blue light was on constantly which drained the power. Once the light had gone off I recharged the shaver and all was fixed!
Posted on Jul 31, 2010
Reset light has appeared.What action is required ?
There is no Reset Light as far as I know and the manual seems to indicate the same. I have a series 5. The green light shines when you are using it. The red light flashes when the power in the battery is less than 20%. Put it on to charge and the light will flash green until it is fully charged and then the light will be solid green.
All of the manuals are here from Braun
http://www.service.braun.com/product/search.asp?rg=NA&c=US&l=GB&typ=ui&frmTyp=subgrp&sgrp=subgrp&grp=SH01%3C%7C%3ESH02%3C%7C%3ESH03%3C%7C%3ESH04%3C%7C%3ESH08%3C%7C%3E&s=&subgrp=Series+7%2C+9000+series+-+Pulsonic%2FProsonic%2CActive+P
This manual page is showing the light indicators.
http://www.manualslib.com/manual/20437/Braun-Series-7-720.html?page=8#manual
Braun SERIES 7 720 User Manual Page 8
Apr 01, 2016 | Braun Series 7 720 Electric Rechargeable...
How to fix a Braun series 7 razor that will not charge in cleaning stand
Try plugging the cord directly into the shaver. If it charges this way, your clean and charge unit is bad. A replacement can be ordered from the link below
http://shaveroutlet.com/braun-pulsonic-clean-charge-base.html
May 27, 2014 | Braun 7000 Series Foil and Cutterblock
What does the yellow light mean on a braun series 7 shaver?
It is a light to tell you to replace your cutter cassette and foil. It will reset after 7 shaves. It usually comes on after 18 months or the cutter is worn. Page 11 in your manual.
Nov 18, 2012 | Braun Series 7 790 Pulsonic Shaver System...
Braun dosent charge
Hi, Replace the battery it is faulty. After many charges the battery will not charge any more its called internal discharge Repace it and you are good to go.
Dec 20, 2011 | Braun Series 7 790cc Pulsonic Electronic...
Braun Series 7 790cc: Battery is fully charged. Turn on the razor and it runs for about 1 minute and will just stop. Push the on button and it will run for 3-5 seconds and stop again. But, if you take off...
Hi, My guess is that the battery needs to be replaced with a new one. After many uses the battery will not charge properly any more. (internal discharge) Replace ,Replace ,Replace.
Aug 20, 2011 | Braun Series 7 790cc Pulsonic Electronic...
Need braun series 7 blades
The blades come mounted in the screen assembly. You will find this cartridge available at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/braun-9000-series-pulsonic-foil-and-cutter-cartridge-p-365.html
Aug 15, 2011 | Braun Series 7 9585 Hair Trimmer
I got a Braun Series 7 790 cc-4 shaver with Clean & Renew station from Amazon yesterday. All worked great trying it out last night. I left the shaver in the station, and last night I noticed the blue...
pit back in the charge station for at least 4 hours and switch the power on for the charger
many small battery chargers will flatten the battery if the power is switched off
if that fails , contact amazon for a return letter to get you warranty refund
Jun 05, 2017 | Braun Series 7 790 Pulsonic Shaver System...
My braun shaver does not run although the battery is good.
You can buy the motor drive unit here: http://www.electricshaverstore.com/get_item_7030621_braun-motor-drive-assembly-pulsonic-5671-790cc-959.htm but it needs to be calibrated to the circuit board according to everything I have read. Unfortunately, I do not know the procedure for the calibration.
Jun 27, 2010 | Braun 9595CC Electric Shaver
Braun Series 7 720 Shaver Electric Shaver Logo
100 people viewed this question
Top Braun Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
