Question about Honeywell Heating & Cooling
Trying to connect a honeywell rth230b to a 5 wire thermostat. unfortunately, mislabled some of the wires. can you help determine what wires go to what?
    Scholar:
  • 149 Answers
Heres a page for most thermostat combinations/colors used
http://toad.net/~jsmeenen/wiring.html
its got the most common combinations
Posted on May 17, 2008
Honeywell RTH230B works on AC not on Heat
check wiring to furnace check wire hook ups on board match letters and colors sometimes installer use what ever wiring they chose on letters
Oct 16, 2009 | Honeywell Electronic Programmable...
Help! replacing WeatherKing thermostat with Honeywell RTH230B
RC AND RH CONNECT BOTH WITH RED
Y TO THE YELLOW
G TO THE GREEN
W TO THE WHITE
Sep 18, 2009 | Heating & Cooling
Honeywell RTH230B will not call for heat.
On a call for heat an internal switch should connect Rh and W, if it does not the stat is bad. Try it with no wires connected.
May 18, 2009 | Honeywell Focus 6300B 5-2 Days...
RTH230B thermostat not working - nothing's happening
The 2nd combination is correct (w/ jumper). Wire nut or tape the blue wire. The snow flake shows it's going into cooling mode after a 5 min delay. If the AC is not coming on then the problem may not be the thermostat. If you don't have 24VAC between the red wire and the blue one the problem is at the furnace or it's supply. If you do, then check for 24VAC between the blue wire and Y on the thermostat(after the 5min delay) - if it's there the thermostat is calling for cooling. To check the heat, switch the thermostat to heat mode and use the W(instead of Y) on the thermostat(after the flame stops flashing).
Apr 02, 2009 | Honeywell Programmable Thermostat Heater
Honeywell rth230b thermostat doesn't work
On most Honeywell Digital T-stats there is a 5 min delay built in
Oct 23, 2008 | Honeywell Programmable Thermostat Heater
Honeywell RTH230B
This my situation exactly.  Changing from a 6 wire manual round Honeywell thermostat to a 5 wire Honeywell programable.  Is there a way to maintain all functions?
Sep 21, 2008 | Honeywell Programmable Thermostat Heater
Problem with Honeywell RTH230B Thermostat
I have my temp on C and I need to change back to F I have the RTH230B programable
May 30, 2008 | Honeywell Programmable Thermostat Heater
Sounds like you have it wired wrong..   Pop the top off and give me to color of the wires and tell me which letter each color wire is on.. that will tell us right away if you have it wired wrong
May 27, 2008 | Honeywell Programmable Thermostat Heater
Honeywell RTH230B
Normally, you should have 5 color wires: W-White, Y-Yellow, G-Green, R-Red and C-Blue.
The Blue wire is a common from the transformer on older systems, which is probably hooked to RC terminal.
Try this: Remove the blue wire and jump the RC to RH with the red wire and you will be fine. Blue wire should not be needed with the new thermostat.
This should also be stated in the instruction manual.
Hope this helps.
Feb 03, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
108 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
