Question about Samsung HLR5667W 56" Rear Projection HDTV
Tv setup bought a used samsung tv model HLR5667WAX/XAA have no book, need help setting it up
    New Friend:
  • 129 Answers
GO TO SAMSUNG.COM TO DOWNLOAD THE OWNER'S MANUAL
Posted on May 16, 2008
Is there any way to buy a CPU for HLR5667WAX/XAA? How to replace it?
If you TV is 9 years old it is questionable whether further repairs are economically worthwhile.
Jun 05, 2014 | Samsung Cooling Fan Set for HLR5667WAX/XAA
I have a Samsung Hlr5667wax/xaa DLP TV and the screen has gone green/green plaid pattern.
when the color wheel stops the picture will be all over the place. and you will have lines when it starts to fail as its not going fast enough for the picture. wining sound is it wearing out.
May 29, 2017 | Samsung Hlr5667w 56-inch Dlp Hd Tv
Tv turns itself on and off
in general terms it means the microprocessor in the set is locked up, you have indicated a Samsung part number but NOT a brand and model number and those are needed to know if help can be given or not.
Dec 09, 2012 | Philips Samsung HL-N5065W1X/XAA...
I bought a used samsung tv model lnr32r5hdx/xaa and it didn't come with a remote, the controls on the tv do not respond except the power button. I have been reading about some shop mode and I have has...
Changing modes and resetting on tv internal video setting must resquire the tv original tv remote Try website like Remotes.com to buy the tv original remote.
Jul 03, 2011 | Samsung Televison & Video
Samsung hlr5667wax/xaa tv Hear sound but picture is green or blank or strips up and down,
Problem is in either power supply or the Y-Sustain board.
The Y-Sustain is a relatively large board out of which go connections to the side of the display; it's therefore closer to either the left or the right side of the display, has at least one rather large heat sink on it and fat power cables connecting it to the main power supply.
Often there are fuses on that board - one or more. Check those.
if they are blown you can try to replace them, but expect them to blow again - usually the whole board needs to be replaced.
Good luck in solving the problem....
Jun 27, 2011 | Televison & Video
SAMSUNG TV WONT TURN ON JUST CLICKS
I just fixed this very same problem. The capacitors are the problem. However, I think that if you have some minimal skills with soldering, you can fix this yourself. You just need to take out the system board, then the power supply parts are on the top right. The bad capacitor(s) will be bulging at the top and possibly have some brown stuff coming out. The ones that go bad are 1000microfarad, 10V, however you can replace them with higher voltage. I got 35V caps from radio shack for 1.59 each. You just need to solder out the bad ones and then put the new ones in and solder. Remember that the negative end goes on the side with the bold black part of the circle on the system board. Then just cut off the extra ends of the capacitors. If you are capable of doing this yourself, you will spend at most 6 dollars instead of however much a technician costs.
Sep 24, 2009 | Samsung LN-S4041D 40 in. LCD HDTV
Same problem
You have two options only. One is to pay a trained Samsung tech to replace the DMD bd which takes a Tech to properly align the DMD bd and takes some time or you can replace the entire Engine which is more expensive but quicker and easier. Wish had good news for you.
Jul 12, 2009 | Samsung HL-R6167W 61" HDTV
Dlp TV won't turn on
possible color wheel , or just a lamp. depending on what the noise sounded like. check out some videos on you tube on how to replace color wheel. Not to hard
May 27, 2009 | Samsung HLR5667W 56" Rear Projection HDTV
Samsung HLR5667W 56" Rear Projection HDTV Logo
148 people viewed this question
Henry  Thomas
Henry Thomas
