Question about Crown CE2000 2-Channel Amplifier
What kind of cord do you use for the output on ce2000a
What type of audio cable do i need to use my casio pt-20 outputted to my speakers
It wouldn't go straight to a speaker on output, unless you disconnect the wires of the speaker and run them to another speaker. You will have to go through an amp of some kind with an instrument or guitar cord. It only has 1 speaker so it is not in stereo.
Mar 05, 2013 | Music
My hp pavillion dv5t-1000 power cord not working
Test your voltage on your power supply...There should be a voltage amount on the sticker on your power supply telling the output.Make sure yours is putting out the right amount.If this test good,your probally looking at a bad dc jack.Jacks need to be checked by a certified repair person.....Goodluck......If this is helpful ...Be so kind as to give a testimonial.....Thank you
Apr 09, 2010 | HP Pavillion DV6227 Notebook
Adapter/power supply cord missing emachine model SP 30A speakers
AC/DC Adapter
Model MA-9200
Input 120 VAC 60 Hz
Output 9 VAC 200 Ma
Class 2 Transformer
Oct 17, 2009 | Audio Players & Recorders
What kind of power cord should i use for Fargo Persona c30 printer
For your fargo persona C30 you need a power adopter of folowing rating description:
input: 100-240V -2A, 50-60Hz AC
output: 24V/2.5A, 60Watt max DC
Aug 21, 2009 | Fargo Persona C30 Thermal Card Printer
I need a power cord for this Maxtor 3200 - please advise Thom167@embarqmail.com
wath kind of power connetions ?
round 6 mm outsite negative insite positive (12 volts)
if yes you buy power suply wit at minimum output over 1000 mA how more are better
Aug 16, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
How should I connect my accer pc to sony bravia lcd hdtv
That depends on what kind of output you have on your computer. If you have the VGA output which is for normal monitors as well as LCD then you can connect it that way. if you have a DVI output from your computer which is a round port much like a mouse port then you can connect it to the DVI input on the LCD.
Jan 01, 2009 | Acer Aspireā„¢ T180 PC Desktop
I have a dell latitude d520
If the adaptor has failed, then the battery has not been receiving any charge current meaning that neither would be able to start your system.
You need a cheap meter of some kind to see if the adaptor is putting anything out in the way of voltage and the ratings on it will specify in- output voltage and current.
If you are in the US, you can buy a usable multimeter for <$20 US at Radio Shack.
If the output voltage is there at all, it may read much higher than is printed on the case but this is a normal condition with no load current being drawn. These devices may not have any regulation at all and be wholly dependent on a regulator inside the notebook itself.
Aug 23, 2008 | Dell Latitude D600 Notebook
Crown CE2000 2-Channel Amplifier Logo
15 people viewed this question
Top Crown Audio Players & Recorders Experts
 Grubhead
Grubhead
Paul Bade
Are you a Crown Audio Player and Recorder Expert? Answer questions, earn points and help others
