Question about Refrigerators
7 year old side-by-side Whirlpool refrigerator. A plastic box on end of wiring harness on the side of the compressor housing is literally melting down. Acrid electrical smell. Is this a relay going bad or the compressor causing the failure of the switch? I have a call in to a service person but cant get an appointment for another 24 hours.
  • 1 more comment
  • morgaj3 Sep 16, 2010
    Thanks for the comments. I reported the problem to Whirlpool.
    But- I need some direction on this.
    The wires did not appear to be the cause of the heat or the plastic on them would have been damaged. The contacts- 3 round metal posts may have deposits but it is difficult to tell with the melted plastic on them. The heat seems to have occurred in the relay or at the contacts. The face of the plastic box that contacts the 3 posts is badly melted but did come off of the relays. I did not notice the compressor running but I was pretty excited by the smoke and trying to get to the plug to get the thing unplugged before more damage or a fire could happen.
    Would replacing the relay likely be the first step in seeing if it was the problem or is there some diagnostic proceidure that can be done to see if the conpressor is shot before replacing the relay?
    Also- I cant get the mechanical fastener off that is holding the two wires on to the relay. What is the trick here. I would like to take the relay out and have a closer look without cutting the wires.
    Thanks,
    John M.
  • morgaj3 Sep 17, 2010
    Thanks to the response form tbreeze47
    I had the information I needed to research the problem. I also got a repairman to confirm that the compressor had failed. He suggested that we buy a new unit and count this one as a loss since it was 7 years old and would cost over $500 to repair.
    With the URL's that I was pointed to I found others with similar complaints and knew where to report my situation to Whirlpool. I posted a complaint on a blog adding to the outcry about the situation and copied all others that related. Including these, I believe, in my message to Whirlpool helped add weight to my assertion that there was something to my case. Whirlpool responded quickly and offered to repair the refrigerator at their cost. This renews my flagging loyalty to Whirlpool and give me soem hope that American industry and products have not sold out to increasing proffit margins.
    I hope more people find your assistance by accident as I did and come out ahead because of the decision to risk $6 on the chance that it might help.
    Sincerely,
    John Morgan
    Well it was the compressor in this case and the repairman said that it would be $500 to repair the unit. That is not something that I can do myself. Luckily- Whirlpool has agreed to pay for the repairs.
  • Refrigerators Master
  • 3,083 Answers
Unplug the unit, and see what is heating up. It could be oxidized contacts on the relay (clean with emory cloth), or it could be overheated wires from the compressor running constantly. Read what Mike of Medina, OH had to say about his unit:
http://www.consumeraffairs.com/homeowners/whirlpool_refrigerators.html
Here's a report on the fire hazard on the web:
http://blogs.consumerreports.org/home/2009/03/maytag-refrigerator-recall-cpsc-fire-hazard-amana-admiral-crosley-jennair-magic-chef-performa.html
By the way, Maytag is a subsidiary of Whirlpool. Here is a blog with more info on the recall:
http://www.appliancejournal.com/appliance-recall-information/the-frostiest-of-flames-citing-fire-hazard-maytag-recalls-16-million-refrigerators-310/
You need to contact Whirlpool Support about this- it's a dangerous issue. Here's their support page:
http://www.whirlpool.com/custserv/index.jsp
Good luck, hope this helps, and thanks for using FixYa.
Posted on Sep 15, 2010
  • 1,711 Answers
Usualy what isstarting the melting down part is the capacitor and not the relay. However both are very close together and the melting plastic will make all parts like one ball.
Also you have very big chances that your compressor is fine so you just need to remove the melting parts which is the cover, capacitor and relay and install new ones.
This a tricky situation since you must be delictated so if the cover or other parts can not be easily removed you must cut the palstics but take care not cutting the wires since this will mean a lot of time to replace the parts.
So either better leave someone who have experiance or if you try to remove them you destroy the plastics but take care all wires. Some photoes will help you later when you will put the new parts back in place.
Posted on Sep 16, 2010
Burned plastic part on refrigerator compressor
side by side refrigerator freezer, smelled melting plastic, found a plastic box connected to the compressor burned. What is this and how much does it cost to replace?
Dec 13, 2009 | KitchenAid Refrigerators
Have a whirlpool side by side refriferator estate model. Freezer won't get cold. Cleaned off underneath,fan is turning, Unplugged for awhile and plugged back in. Keep hearing clicking noise coming from...
Plastic box you're referring to contains the start components for the compressor. The clicking sound sound you hear is the protective overload shutting the compressor off because it won't start.
Two possibilities
1. The components inside the plastic box (cover) are defective and need replaced. You can remove them, by snapping off the cover and pulling them straight off. Most appliance parts houses will be happy to test them.
2. The compressor has failed internally.
Note: In my personal experience when dealing with whirlpool Estate models, 99% of the time it has been a failed compressor.
Oct 28, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
WHIRLPOOL Relay melted! PLEASE HELP! 1 of 3 Compressor Pins melted! HELP!
Hi, If the pin on the compressor is melted/broke off, the compressor is bad. If the unit is under five years old, check with whilpool and see if it still has a warrenty.
I hope this helps.
Please let me knwo if I can assist you further.
Vic
Jun 19, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
I have no power to the refrigerator light or the digital controls
your actual problem on this is the main control in the compressor compartment. unplug your refrig then remove this control unplug all connectors and reconnect. this will probably get you working temporarily In almost every case I've seen we ended up replaing the control board. thx peyton
Jan 31, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Refrigerator/freezer not working
remove the bottom panel on back of fridge. locate the compressor( round black object with copper tubing coming out of it. check where the wiring plugs into it and you will probably see a white plastic box attached to the compressor.this part can be pried off with a screwdriver and if it is white this is your problem. whirlpool had a defect in this relay and they go out quite frequently
Jan 31, 2009 | Kenmore 53642 / 53644 Side by Side...
Whirlpool side by side, blowing hot air on both sides
First, you must determine if the compressor is running. The compressor is located at the bottom of the unit in the rear. Feel for motor heat and slight vibration. If it is cool then the problem may be an inexpensive start relay. If the compressor is very hot, the start relay could also be the problem or the motor has seized. Find the wiring diagram in the rear of the unit to replace this relay which should be availible at your local refrigeration supplie house.
Ray
Jan 05, 2009 | Whirlpool Refrigerators
Freezer is defrosting; freezer/refrigerator side-by-side (9 years old, manufactured 05/99, came with the house bought in April 2004)
check if compressor is running. if it is, then you have a system or compressor fault and not worth repair on 9yr old appliance
Jun 20, 2008 | Whirlpool Refrigerators
Whirlpool side by side compressor replacement?
uk price is about £250 fitted i done one about 2 months ago. or thats what my company charge
Feb 14, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool side-by-side melted relay.
Maytag (owned by Whirlpool since 2005) has issued a recall on the compressor relay due to fires. Whirlpool brands are not listed in the recall but it looks like they should be. The problem goes back to Jan 01 according to the Consumer Product Safety Comission.
Refrigerators Logo
155 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
