Picture too big for screen
My picture is too big for screen and words are cut off bottom of screen. How do I shrink the picture a few percent to fit the screen and see everything across bottom?
  • nytowl420177 Apr 23, 2009
    my picture is to big for the screen.cuts off words at the bottom and half the tops of heads,I need help
  • Anonymous Mar 24, 2014
    Need to somehow shrink screen to fit.
    New Friend:
  • 129 Answers
GO TO MENU VIDEO SETTINGS AND RESET TO FULL FORMAT SETTING , GO TO JVC.COM AND DOWNLOAD THE OWNERS MANUAL GUIDE ,
Posted on May 17, 2008
Why are the movies half screen?
Movies that are created for "Wide Screen" viewing show up in letterbox on your TV. If you go to a theatre you notice it is a big rectangle. To be able to fit all of the widescreen movie on a TV it has to make the height smaller.
Because many people want to see the "complete" Movie, the "Letterbox Format" came about. I do NOT know what the word "Letterbox" actually means, or how that term was chosen. To get the complete Rectangle into that Square, they discovered that they could shrink the entire rectangle to fit that square. Meaning, what used to take 2 inches on your screen, now may only take 1.75 inches. Now a problem arrose. When you shrink the WIDTH to fit your dinky Square of a TV, the HEIGHT also has to be shrunk along with it, or else you're stretching the image as if it was on silly-putty ("Compression"). When the image was shrunk to fit the TV Screen, they were left with a gap at the top and bottom of the screen. So they simply fill it in with "Black". I guess the only alternative was to leave it snowy.
Nov 13, 2014 | Televison & Video
Toshiba CF32H40 32"TV shrinking picture with solid black on bottom. What causes this and can it be fixed?
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Aug 30, 2014 | Toshiba CF32H40 32" TV
Picture on 47
You do not worry at all, because the set is under warranty.
Launch a complaint and sit peas fully.
Jul 23, 2012 | RCA 47LA55RS 47 in. LCD TV
The picture is too big for the screen. how can i make the picture match my screen size?
Posting the model number would make a response more valid but you need to go through the main menu selection and check to see if you can alter screen resolution or geometry there.Most sets offer different views such as 'Panorama,' 'Full screen,' etc.
Nov 21, 2011 | Sanyo Televison & Video
Picture seems to big for TV.cant read bottom words on screen and words are cut off on side also. Cant see scrores on any sports or read peoples names on bottom of the screen
Using the menu or settings button on your remote, access the TV's menu and find the area for picture settings and zoom. You're likely set to a zoom mode, so cycle through the options until you find the zoom setting that sizes to your TV best. (On most widescreens, the best picture is often on the setting 'panarama.'
Mar 12, 2011 | Vizio L37 Television
How to adjust aspect ratio on Mitsubishi VS-6043 TV?
I have the same problem and the only thing I could do was to change the name of the input on your tv to pc on the menu screen and it should set it to 1080p reduced this will fit the whole picture and set your screen res on your computer to 1920x1080
hope this helps
Aug 01, 2009 | Mitsubishi VS-6043 60" Rear Projection...
New flatscreen Sanyo tv. Picture is to big for the screen
use the picture button to change the shape, Most likely you have it set to picture 3 which would cause that.
Jul 04, 2009 | Sanyo DP32648 32 in. LCD TV
BOWED IN SCREEN/PICTURE
the problem is called pincushion
usually fixable not by anyone without electronics background
guessing around $150 you have to decide
as long as it has a good clear sharp picture its worth it
Dec 20, 2008 | Sony FD Trinitron WEGA KV-24FS100 24" TV
PIONEER SD-T50W1 VERTICAL PROBLEM
Usually, when a picture collapses some but not all the way, it indicates that an electrolytic capacitor has gone bad in the verrtical circuit. If the top of the picture shrinks, suspect the pump-up capacitor, but if the bottom shrinks then the coupling cap is probably going bad. This is quite an easy thing to correct, so have a qualified tech service the set.
Sep 01, 2007 | Pioneer SD-P50A5-K 50" Rear Projection...
Picture is shrinking from the bottom
Hi you have lose solder in yor vertical section have a tech resolder it or that problem will cost you .hope you have already have it remedied.
Nov 14, 2006 | Toshiba 36A40 36" TV
Televison & Video Logo
980 people viewed this question
Top Televison & Video Experts
Electro Med Services...
