Question about Whirlpool ET1FTKXK Top Freezer Refrigerator
The freezer is cool and the fridge is warm. Light comes on when I open door. Fridge about 6 yrs old. Condensation turns into frost on back wall of freezer. I clean it out and it comes right back. My food in fridge will have to be thrown out in a day or two. This happened about 2 days ago. I've turned it off for 8 hrs, then on again -- same thing - cool in freezer, warm in fridge
  • patmcneil38 Sep 16, 2010
    Thank you for your very useful comments. Please tell me what size refrigerator this model is. Much apporeciation.
  • 375 Answers
Your fridge likely has a defrost system problem. Either defrost heater, defrost thermostat, defrost timer is faulty or a connection is bad somewhere in the defrost circuit. Leave refrigerator running for a couple of hours before testing components, then unplug it.
  • remove back panel in the freezer section. There should be quite some frost built up if it's been running for a few days. Find the 2-prong connector for the defrost heater. check the defrost heater for continuity. Replace heater if no continuity. Part number 2315530.
  • find the defrost thermostat while it's cold check the continuity. if no continuity and the thermostat is cold (below 30F) - replace. Part number 4387503
  • if both components are ok, and no loose connections found, find the defrost timer, located in the control box (on the ceiling of the refrigerator section). You can test it also, but I'd say just replace it if other components are ok. Part number 482493.
Either leave the fridge off for 24 hours or use hair dryer to clean frost buildup on evaporator coil.
You can find the parts' pictures at repairclinic.com (just type the part numbers in search box), check ebay for prices.
Good luck,
Vlad
First Choice Appliance
Posted on Sep 15, 2010
Too warm both freezer and fridge recently ice cubes melted when opened a lot.
5 reasons for fridge and/or freezer getting warm: 1- the evaporator coils are icing up and won?t let air circulate. 2- the evaporator fan is not working to circulate air. 3- there is no refrigerant in the system. 4- no power to fridge or compressor. 5- the condenser coils have no air circulation check under the fridge behind the vent. if it is too dusty or the fan isn?t working, it is not getting enough airflow to cool down. replace fan and/or vacuum out the dust. if there is no power to the fridge, the light will be off. if the compressor is not running, there is a defrost timer that cuts the power temporarily to the compressor to melt ice on the coils. it?s located under the fridge behind the bottom vent. If the timer is off and the compressor is not going, the compressor or the main board is bad and needs replacing. there is also a temperature sensor on the evaporator coils that tells the defrost coil to turn on and when to turn off. if the defrost timer is on but the coil is not heating up, replace the sensor. if it still won?t heat up, it?s the timer or the coil. the easiest way to tell if there is no refrigerant- the freezer wall is warm and the compressor is loud. if there is no refrigerant, it may be more cost effective to replace the fridge. if you feel no air coming from the freezer vent, the fan needs replacing. If you feel air moving in the freezer but not the fridge, the channel from freezer to fridge is blocked. if the freezer has air and the rear freezer wall has frost on it, the evaporator coils are iced up and need defrosting. causes: 1. low refrigerant 2. no fan 3. too much humid air in fridge/freezer due to door open or bad door seals 4. the condensate drain tube is clogged if the seal around the door is ripped or not completely sealing, or there is condensation at the bottom or the walls of the fridge, replace the seal(s). no air, no fan. Replace if the refrigerant is low, it just needs a top off. but you need to be certified by the epa to move refrigerant, so get a professional. defrost solutions: unplug the fridge. remove the wall of the freezer that is frosted/icing up. use a hair dryer to melt the ice. do not get too close. you will see a drain under the evaporator coil. make sure it is not blocked. the water should run freely to a condensate pan under the fridge that evaporates the condensation with the hot line from the compressor. once the coil is free of ice, frost, and water, replace the panel and repair any of the problems that caused the icing up. plug the fridge in and turn it on. If it frosts up within a week, there is still an issue that not been taken care of.
Aug 28, 2009 | Admiral Refrigerators
Refrig temp not cold enough..drinks are almost warm
Aug 27, 2009 | Frigidaire FRS26H5AS Side by Side...
Kenmore refrigerator will not cool. Freezer works
Aug 27, 2009 | Kenmore Refrigerators
My Daewoo FRS2021IAL has a warm fridge
Aug 26, 2009 | Daewoo Refrigerators
Cooling system of my LG frostfree refrigerator is not working for the last two days .No one is attending the complaint from service center , Panvel Navi mumbai . Need immediate help/
Aug 25, 2009 | LG Refrigerators
Whirlpool Side By SIde Refrigerator Freezer stopped cooling
Aug 24, 2009 | Whirlpool GS6NBEXRQ Side by Side...
Lights on Freezer and Fridge not working
Aug 21, 2009 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
Dometic RM763. Freezer=Yes,Fridge=No
Aug 21, 2009 | Refrigerators
42'' monogram getting very hot between doors and in unit above
This is typical for frost-free refridgerators/freezers. In order to keep ice from buiding up on the interior walls of the freezer section, the manufacturer installs electric defrosting elements and extra "warming" elements in the outer edges of the cabinet, normally around the door openings to help mitigate any frost/ice build up and surface condensation that typically occurs on the exterior surfaces as the doors are opened and closed frequently.
These edge warmers stay very warm to keep ice and condensation from accumulating and will become VERY very warm (hot) when the fridge/freezer is in the once a day defrost cycle.
Unless you have an energy saver switch (GE trademark) inside the fridge section, which you can turn off, there is no way to disable these added elements. If you find that you're getting ice building up in the freezer, you'll need to turn off the energy saver switch to resolve that issue.
Energy Saver switch "ON" means these elements are off, while having the ES switch "OFF" means those heaters are running all the time and costing you more in energy consumption
Jul 13, 2009 | GE Refrigerators
GE Profile French Door Bottom Freezer not cooling
I am experiencing the same problem with my GE fridge. We have already tried the Turbo Cool, but nothing seems to help.
Thanks
Carol
Nov 13, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Whirlpool ET1FTKXK Top Freezer Refrigerator Logo
158 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
