Question about D-Link AirPlus DI-524 Wireless Router
Just purchased new xbox. Xbox live was working fine when hardwired, but computer and xbox will not work thru wireless. It finds the router, but when I try to open the internet or connect to xbox live it won't work. My router is older: D LINK DI-524
    Filmmaker:
    Uploaded 5 video answers.
    Scholar:
  • 82 Answers
I had a similar problem a while back with a netgear gateway. All four ethernet ports on the back worked but it wouldn't work with wifi. I had taken it apart and found that the antenna solder point had came loose. If the antenna isn't hooked up it won't send out a signal. Mine broke because it fell off of the back of my tv
Posted on Oct 23, 2010
We recently got an Arris TM722 modem and a netgear wireless-N 150 router WNR 1000 after getting a new ISP. My problem is that every time I turn on my xbox to connect to xbox live, my xbox doesn't connect...
Recheck your settings on the xbox.
If using wifi on the xbox, you'll have to setup a new connection to the new router.
If the xbox is wired via cable to the router, you may need to add a router password or other settings .
Jun 21, 2017 | Computers & Internet
Im programing my x box 360 it needs me to program the wpa net work to get this new x bow to work. im new at this expain things very clear , thanks
Follow these instructions to set up the Xbox or Xbox 360 connections to a wireless home network. These instructions assume the wireless router is already installed with a working Internet connection. If after following these instructions you are unable to network your Xbox with the wireless router, see - Connecting Xbox to Wireless Networks - Why Things Go Wrong
Here's How:
  1. Connect the appropriate wireless network adapter to the console. On the Xbox, a Wi-Fi adapter that connects to the Ethernet port (sometimes also called a wireless network bridge) must be used. Alternatively, the Xbox 360 is also designed to work with certain Wi-Fi game adapters that connect to a USB port.
  2. Turn on the console and navigate to the wireless settings screen. On the Xbox, the menu path is "Settings -> Network Settings -> Advanced -> Wireless -> Settings" On the Xbox 360, the menu path is "System -> Network Settings -> Edit Settings."
  3. Set the SSID (network name) on the Xbox to match that of the wireless router. If your wireless router has enabled SSID broadcast, the SSID name should appear pre-selected on the Xbox display. Otherwise, select the "Specify Unlisted Network" option and enter the SSID there.
  4. Specify "Infrastructure" as the Network Mode. (Infrastructure is the mode used by wireless routers.)
  5. Set the Security Type to match that of the wireless router. If your router uses WPA encryption and the type of adapter connected to the Xbox does not support WPA, you will need to change your router settings to use WEP encryption instead. Note that the standard Microsoft Xbox 360 Wireless Network Adapter supports WPA while the standard Microsoft Xbox Wireless Adapter (MN-740) only supports WEP.
  6. Save your settings and verify the network is functional.
    On the Xbox, the Wireless Status screen displays whether a connection has successfully been made with the wireless router, and the Connect Status screen displays whether a connection has successfully been made through the Internet to Xbox Live.
    On the Xbox 360, use the "Test Xbox Live Connection" option instead.
Tips:
  1. Even when your wireless connection between the Xbox and the router is working perfectly, you may still experience difficulty connecting to Xbox Live. These issues can be caused by the quality of your Internet connection or the firewall and Network Address Translation (NAT) settings of your wireless router. Additional troubleshooting may be required in these areas to achieve reliable Xbox Live connections.
Feb 27, 2011 | Computers & Internet
Is the gt704wgb compatible with xbox live?
Yes this wireless router will work with your XBOX wirelessly ad everything will be fine just make sure you have the wireless settings from your router to manually configure it to your XBOX...
Jan 04, 2010 | Actiontec GT704WG Wireless Router...
Can't connect to xbox live, connected to network and internet, but as soon as test goes to xbox live connection comes up with updates needed, click continue to update, the green bar goes so far after about...
Try plugging the xbox straight into the modem and not the router, if it still happens, reset your modem and router and try again. Xbox live can be sketchy at times. Also the traffic to xbox live because of the holidays can sometimes screw with the updating and such.
Dec 27, 2009 | Microsoft Xbox 360 Console
Xbox live cannot connect to network
I would suggest power cycling it, both the xbox and the router, sometimes routers can be funny with there connections.
Jun 30, 2009 | Linksys Wireless-G WRT54G Router
Xbox 360 connection troubles
I can tell you that you are not alone. I cannot tell you the exact reason why but I am hardwired in myself and experience the exact symptoms you have scribed. I believe that it is simple a Xbox Live service problem. I work for a cable internet provider and have tried everything that can possibly be done to tweak and tune a connection and it still occurs.
I am not sure what the use as the communication protocol but if it is "SIP" based that would explain alot about why we are constantly being booted from party's.
I would definatally recommend hardwiring your xbox to a router though. You could be having wireless channel overlap from a neighbor that could me dropping the connection. Another possibility is if you have any file sharing utilities "bit torrent" ect. running, that will cause inconsistancies. You may also have someone else mooching on your wifi.
These are just suggestions, Hope this helps..
PLease Rate
Apr 10, 2009 | Microsoft Xbox 360 Pro System Console
Two xbox 360's in my house but only one will connect to live
Do you and your brother use the same gamer tag? If so, the problem might be as simple as creating a new gamer tag account.
Jan 16, 2009 | Microsoft Wireless Network Adapter Xbox...
My wireless adaptor for my brothers xbox won't work for mine, why
If it is green, then it should be working. Go to system or console settings and test the connection to see what is failing then call xbox live tech support to help with the specific issue.
Jan 10, 2009 | Microsoft Wireless Network Adapter Xbox...
My Belkin N1 and my xbox 360
I just got it and yes latest firmware as of end of mai has been downloaded
Jun 02, 2008 | Belkin (F5D8231-4) Wireless Router...
Hooking up xbox live
Well, it's very possible if you are using a wireless router that your connection may not be strong enough. XBOX Live and most online gaming requires a steady. strong, high bandwith connection. A weak singnal, OR someone else using up the bandwith (i.e. someone downloading music on another computer connected to your router) can cause the problem.
If you're using a wireless connection, try moving the router and wireless game adapter closer to each other.
If you're using a hardwire connection from one of the routers outgong ports then make sure other's aren't on the internet (Or at least aren't using alot of bandwith) while XBOX Live is being used.
Please remember also that if you have a wireless network and you haven't implimented wireless secruity (i.e. WEP or WPA encryption) then your network is "Open" and anyone within range can connect and use up your bandwith,
Feb 24, 2008 | Belkin (F5D7230-4) Router (587009)
D-Link AirPlus DI-524 Wireless Router Logo
74 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
