Question about Omega 8005 Juicer
I have an 8002.Pulp backs up even with end off. Don
My juice is coming out with the pulp. The machine seems to be operating and sounding normal and this has never happened before. I have the omega 8005 model??
This usually is indication of pulp backing up in the machine make sure you are pre cutting the produce and also make sure the tensioner on the end is adjusted according tot he produce being used. Example: softer produce requires less tension where as leafy green vegetables you can increase the tensioner.
Feb 03, 2013 | Omega 8005 Juicer
Pulp is building up, not ejecting properly
When juicing with the champion juicer take it slow. You need to hold down the tamper for three to five seconds in-between reloading the chute. Otherwise it will begin to back up through the chute and the juicer will begin to heat up. Happy juicing! LivingaHealthyandHappyLife.com
Mar 07, 2012 | Champion G5NG853S 540 Watts Juicer
After juicing just a few fruits and vegetables the machine start jumping all over the counter and vibrating really fast.
There is no solution. These juicers do not eject the pulp and go out of balance very easily.
Don't feel bad, I've seen you tube videos where the demonstrator couldn't keep it under
control. If you are unable to master it, consider a pulp ejecting or masticating type juicer.
Mar 08, 2011 | Omega 1000 Juice Extractor
My #6001 juicer ( old!!) will make a very loud sound even after only 3 carrots.. causing me to stop and clean out pulp.. even may shake more than usual... so am thinking it should need an overhaul??? I...
No overhaul. These juicers do not eject the pulp and are subject to vibration especially if you
install a new blade. I've had one for 21 years and get by using a worn blade which I sharpen
with an electric drill using a small bit.
Mar 03, 2011 | Acme 6001 Juice Extractor
My Omega 1000 goes off balance and makes a noise like it is going to blow up so I have to end of turning it off. It doesn't do this all the time but it is getting more frequent. This happens with any...
Yours and everyone else's. Best solution is to get a pulp ejecting type juicer.
I have a 21 year old Acme and know how to maintain and adjust it. Even
then I have vibration issues.
Sep 02, 2010 | Omega 1000 Juice Extractor
Juicer works fine until slight pulp build up in
Unfortunately, since these juicers do not eject the pulp, they will tend to go out
of balance. Juice nothing softer than apples and try to feed it as evenly and as
slowly as possible.
Nov 27, 2009 | Acme 6001 Juice Extractor
Pulp splattered
Pour some water into it, at the very end.
Jan 06, 2009 | Champion G5NG853S Household Juice...
Pulp gets stuck in Champion
Feed it slower. Mix up the items, it likes things mixed up. You can add water near the end to clean it out.
Jan 20, 2008 | Champion 2000+ Household Juice Extractor
Pomegranate
Well ya can juice 'em but it's a bit labour intensive .. lol 'cause ya gotta skin 'em, and get ALL the "Seeds" out, they taste bad... then put the pulp in.. and juice away... yield is low also .. but tastes real nice in the end.. I usually do it in a plastic bag,and tip the pulp into the juicer. Ya can make great "leathers" too..
Aug 04, 2007 | Jack Lalanne Power Juicer 250 Watts
Omega 8005 Juicer Logo
Top Omega Juicers Experts
Andrew Taylor
Andrew Taylor
eyecam
Tom Chichester
Are you an Omega Juicer Expert? Answer questions, earn points and help others
