Question about RCA F31672ET TV
Analog to digital conversion
Will the RCA F31672ET television (made in 1999) require a converter box to work when the analog to digital conversion occurs next February?
  • RCA Master
  • 1,213 Answers
Yes!
Posted on Apr 29, 2010
How do I hook up Coby 5" black & white TV to my digital converter box ?
You will need a digital to analog converter which you can get at Radio Shack, Best Buy and most big box retail outlets or online. Your Coby is most likely analog and will require the digital signal to be converted to an analog signal from the digital converter box to the TV. UNLESS the digital converter box has analog (round connectors on the back) then you just need an analog RCA cable (which you can also get almost anywhere even your local CVS/Walgreens) to make the connection.
Nov 24, 2014 | Coby Televison & Video
I have an RCA F31672ET and it works perfectly on channels 51 to 98 but will not recognize the rest of the spectrum. I am on cable. Thanks.
Depends on how your cable provider is distributing the TV channels.
Channel 100 is the line into the Jumboband, and most providers don't distribute analog cable beyond channel 99 since it requires a different type of amplifier. They will generally use Digital Cable for higher number channels, which would require a converter box.
http://en.wikipedia.org/wiki/North_American_cable_television_frequencies
Who is your cable provider?
Apr 24, 2011 | RCA F31672ET TV
Do i need a converter box for my rca true flat 27 in? if not how do i connect a digatal antenna i have lost my manual
Your TV will require a Digital Converter Box to recieve over the air Digital Television Signals. You will need to hook up the antenna to the converter box and then hook your converter box to the TV. Hooking your television directly to a digital antenna will not get you Digital signals...only analog signals.
Jun 25, 2010 | RCA TruFlat 27F520T 27" TV
Converting from analog to digital
if you have cable it is digital, if not buy a converter box
Mar 28, 2009 | Sanyo Vizon LCD-15A2 Television
I HAVE A 2004 RCA MODEL 24V511T. dO i NEED A DIGITAL TUNER IN ORDER TO FOR IT TO WORK AFTER FEBRUARY 17?
Model has one NTSC RF and two NTSC composite inputs. It's compatible with analog Over The Air and non-scrambled analog cable broadcasts. After the US analog cutoff (currently scheduled for June 12) it WILL require a digital to analog converter to receive ATSC digital TV transmisions.
Jan 18, 2009 | RCA 24V511T 24" TV
Digital box for analog tv not working
if you have the coax cable connections correctly connected , coax out to tv from box and antenna hooked to antenna in on the box then you may have to connect the RCA jacks, yellow = video , red = right audio , white = left or mono audio
because on these boxes you can choose in the menu to have the coax ( channel 3 or 4 ) as the output or the rca jacks ( line out )as the output . so the menu may be set for the rca jack connections untill you change it in the menu
Dec 29, 2008 | Insignia Digital-to-Analog Converter for...
Analog to digital conversion on Aquos?
First of all, the change is actually goping from analog over-air broadcasting to a digital signal. Second, if you have cable or satelite, you don't need anything. The only time a converter is required is if you use rabbit ears or an external antenna. In your case, the TV DOES have a digital tuner so you DO NOT need a converter in either case.
Dan
Sep 23, 2008 | Sharp Aquos LC-32GD4U 32 in. LCD HDTV
Conversion box
this set is a standard 4:3 projection, so yes, to receive digital, you will need a converter.
Jun 19, 2008 | Philips 60P8341 60" Rear Projection...
Tv
no you will need the converter which will allow analog tuners to recieve digital signals
Mar 19, 2008 | Televison & Video
RCA P52939 - Can it receive HD-Only signal? Is it Analog-Only?
The P52939 RCA is a analog Standard TV you will need the Digital converter to receive digital signals
Feb 10, 2008 | RCA P52939 52" Rear Projection Television
Televison & Video Logo
80 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
