Question about Pentair Easy Touch Indoor Control Panel for 8 Function Systems
Sheer descents go on every day. We cannot change it as we have followed manual, and nothing works. Can we go back to factory settings and how?
  • 990 Answers
Yes you can. I believe (A nice way of saying I can't remember) on the face of the remote you will find a small hole you can stick a toothpick or the end of a paper clip in. If not there it may be in the face of the main box. But I believe (There it is again) it's in the remote. Simply push this button. You need the paper clip so you don't push it by mistake but that's all their is to it.
Posted on Sep 16, 2010
Tip
Learn About an Aircraft, Part 3
, ://i.fixya.nethttp://i.fixya.net25650279-w123deulyqo0pc5nhlq3ghvj-3-0.jpg">
  • Straight and Level Cruise:
Start by setting the RPM to a cruise setting of 2200 RPM, using the throttle. This should give us a cruise speed of about 108 Knots.
Use the yoke to maintain level flight by keeping the small aircraft symbol level and exactly on the "Artificial Horizon" line of the six pack . Keep scanning the rest of the six pack to help maintain level flight. Scanning the six pack will show if you are going straight or turning, climbing or descending or if the airspeed or altitude starts to change. Always use small corrections to the aircraft's attitudes and wait to see the response.
  • Climbing Phase:
We will climb by increasing the throttle to full throttle. Now you can pull back on the yoke to raise the aircraft nose to about ten degrees above the horizon. Now set your climb speed (using the yoke), by changing this 10 degree climb, until you have an airspeed of about 80 knots. meanwhile continuing to scan the six pack at all times and make sure that nothing is changing that you don't want to change. Scanning the six pack will show if you are going straight or turning. or if the airspeed starts to change.
This Aircraft will stall (in a turn) at approximately 53 knots (no flaps) so keep your turns shallow and avoid any speed below 75 knots to allow yourself a margin of safety. Always use small corrections to the aircraft's attitudes and stay well out of any limit zones that are indicated on the instruments.
  • Descent Phase:
A descent to a lower altitude is done by reducing the throttle to an engine speed of about 1500 RPM while setting the air/fuel mixture at full rich (red knob fully inward). If you intend to be descending a long time at low engine power, then you should use carburetor heat to prevent icing. At reduced RPM, the engine will not be producing as much heat so we may have to put on the carburetor heat, or you can occasionally increase the engine speed for a minute to gain some heat and clear the engine.
on Apr 16, 2015 | Sport & Outdoor - Others
Factory reset option not working
You will notice changes only if you have varied any of the settings afterwards. Look for any jammed button in remote. Try changing any setting manually and then press the factory settings. If it does not work, there must be some password or sequence to follow. Please check in the operation manual.
Jul 30, 2012 | Vizio L32 32 in. LCD HDTV
I tried to reset my Linksys Wireless Router WRT54G and nothing happened. No lights came on or nothing. I also tried to press the power button on the front and that did nothing. It is plugged up correctly...
Reset Button is at the back of the router beside the internet port
To reset your router, use the following steps:
  1. Press the reset button for 30 seconds.
  2. The settings should now be returned to the factory default settings, meaning any changes you had made would be deleted.
  3. Open up your Web browser and enter “192.168.1.1′ in the address bar.
  4. For the login, leave a blank ID and enter “admin” as the password.
If it still does not work
Try Soft Reset
Use the following steps to reset the router using this method:
  1. Open your Web browser and enter the IP address of your router. By default, the address is “192.168.1.1′.
  2. Enter your user ID And password when prompted. Hopefully this has been changed, but if it hasn’t, the default is no ID and “admin” as the password.
  3. At the top of the Web page, click “Administration” and then “Factory Defaults”.
  4. Beside “Restore Factory Defaults”, click “Yes”.
  5. Now click the “Save Settings” button at the bottom of the Web page
Jun 12, 2010 | Linksys Wireless-G WRT54G Router
Our waterfall stopped flowing - we called a pool service and they informed us the valve has a spring inside it and it requires replacement. We're trying to do the best we can and hope that it's not too...
VERY EASY TURN OFF EQUIPMENT TAKE OFF SIX SCREWS REPLACE SPRING REPLACE GASKET INSERT SCREWS BACK. ALSO YOU CAN BUY A NEW VALVE AND REPLACE THE TOP ONLY ADD SILICONE TO THE GASKET. MAKE SURE EVERY THING IS CLEAN
Sep 29, 2009 | Jandy Water Feature 18" Sheer Descent...
My PS3 was loading discs just fine, but now it doesn't
Have you tried backing up the PS3 and Factory reseting it? To back up follow this guide: http://manuals.playstation.net/document/en/ps3/current/settings/backuputility.html
To factory reset:
http://www.tech-recipes.com/rx/2265/ps3_how_to_factory_hard_reset/
Aug 12, 2009 | Sony Playstation 3 (PS3) Console
Cyberhome DVD-1600 In the settings menu I went into the A/V setup. The scanmode was switched to Progressive; however, nothing showed and after the 10 seconds it did not revert to interlace. Now I'm ge
Cyberhome DVD-1600
To set the factory default settings just do the following:
  1. Get the DVD-1600 manual
  2. Open to the page which shows you how to set the player to factory default settings
  3. Switch on the TV and click to the channel that you will watch your DVDs
  4. Switch on the DVD player and make sure there is no disc in it - this ensures the DVD is not already in a menu or any other thing
  5. Follow the instructions in the manual to the 'T' although you will be unable to see anything
  6. If you follow the instructions correctly you should get back to 'interlaced mode'. By this time you will be able to see the DVD output on the screen.
Apr 12, 2009 | Televison & Video
Looking to finish edges og sheer material & need to know settings
Try stitch length 2 (of 5) width 2 (of 5) and a zig zag stitch.
Kent
Mar 16, 2009 | Sewing Machines
Pentair Easy Touch Indoor Control Panel for 8 Function Systems Logo
52 people viewed this question
Top Pentair Pool & Spa Experts
Pj Kiley
Pj Kiley
Level 1 Expert
Jay Finke
Jay Finke
Bill Jordan
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
