Question about Epson Stylus CX5000 InkJet Photo Printer
CX 5000 Will not power up?
    Guru:
  • 1,342 Answers
Click HERE for Epson Support and Troubleshooting help.
Posted on Jun 01, 2008
2007 Mazda cx-7 battery completely dead the engine starts on and off
Sounds like a bad power connection either on positive or negative side of battery. Could also be a bad connection from the fuseable links of fuse box in engine bay. Camshaft misaligned code is more likely on these models with the L3 engine a stretched timing chain issue. Very common but Mazda wont admit to it. Cheers
Jan 06, 2014 | Mazda CX-7 Cars & Trucks
My 2007 Mazda cx-7 completely dead for no reason on and off
hi
cam shaft sensor got nothing to do with your oil change.
Cam runs on your timing belt. it's a possibility that it may be faulty as its only a sensor.
change the sensor
Apr 29, 2017 | Mazda CX-7 Cars & Trucks
Right side breaking up at 5000 rpm
Try the cheapest route first. Have you installed new spark plugs? Spark plug caps are notorious for going bad on this model. Unscrew the caps from the end of the wires and check them with an ohm meter. If they read higher or lower than 5000 ohms, replace the spark plug caps. You might also have a bad coil wire. Unfortunately, the coil and wire are sold together. You could spray some water on the right wire, when it is dark, to see if there is arcing or shorting on the wire. If so, replace the coil and wire. New Honda part if available, a good salvage part It might be just as old or as bad as the one you take off.), or Accel makes some good aftermarket coil sets with wires.
Jul 18, 2010 | 1980 Honda CX 500 A
What type of oil do i use in a 1982 cx500 c?
Not to start a debate, but you're going to want to stay away from synthetics in your bike. It's a wet clutch system that has the potential to slip if synthetic oil is used.
I prefer to use Mobil Clean 5000 10w40 but many other respected people in the cx/gl community love Rotella of the same weight.
You can get a copy of the manual for your bike here
Jun 25, 2010 | 1982 Honda CX 500 B
After changibg the 4 ink cartridges of my epson CX 5000 it will not print from the computer
Check status monitor. Are all chip recognized? Do replacement procedure from "How to...". When asked to replace ink tank, unplu and plug again all of ink tank.
Aug 19, 2009 | Epson Office Equipment & Supplies
Wont print
you need to restart your printer once.
if still shows same then you need to take off your cartridges out and put back again that may fix this problem.
Feb 07, 2009 | Epson Stylus CX5000 InkJet Photo Printer
Power cord for Cx-Cd241
Hi
I think that the mains cord is a standard cord, so you should be able to get one from a good elecrical store.
Good Luck
Sep 02, 2008 | Coby CX-CD241 CD Boombox
INK BUTTON
  1. Power off the printer and remove it from the mains supply.
  2. Open the printer lid so that you have access to the cartridges.
  3. Pull gently on the ribbon cable connected to the carrier until the carrier is accessible.
  4. Remove the cartridges.
  5. Using a dry, clean cloth, wipe the contacts of the carrier gently from top to bottom.
  6. Repeat Step 5 on the second carrier slot (where applicable).
  7. Reinsert the cartridges and close the lid.
  8. Reconnect the printer to the mains supply and turn on the printer again.
Feb 13, 2008 | Lexmark JetPrinter X1185 All-In-One InkJet
Epson Stylus  CX5000 InkJet Photo Printer Logo
52 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
