Question about Yard Machines 11A54MC006 21Inch 139cc MTD OHV Gas Powered Side Discharge
Engine starts well but runs only with the choke out and revs while running
  • Yard Machines Master
  • 7,482 Answers
Sounds like you will need to clean your carburetor.
Be sure to use compressed air to blow out all the fuel and air passages.
Be careful when blowing out the passages because there are sometimes small rubber type seats in the bottom of some of the passages.
Sometimes you can get by with priming the carburetor a few times, and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Keep in mind that the float for the carburetor must be level when you go to reassemble the carburetor.
If the mower/weedeater is over a couple years old, then I also recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, You will first seat the jet screws and count the number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns they were in/out.
Please rate me
Posted on Sep 15, 2010
I was using my o17 saw today it was runing Just fine I shut it off when I went to start it again it fired on choke seting after that I could not get it to do anything what is wrong with it
All 2-strokes love to run rich when cold thus full choke till it kicks, half choke to start and leave on for 5 seconds high rev's to warm & lubricate, then no choke to run. Restart when hot is 1 pull full choke (you are now flooded) & then no choke til it starts. Try it. Works every time on all of my 2-stroke engines.
Apr 22, 2015 | Garden
Briggs Stratton 5hp I/C starts ok, runs, but will not rev
My money is on a partial blockage of the main jet or the passageway to it. You're having to force it to run through the idle jet by fully choking the incoming air. There's not enough gas coming in with the choke open to allow it to run.
I'm thiniking total carb disassembly, carb cleaner and an air compressor combined with a ton of patience will take care of the issue.
Mar 31, 2015 | Briggs & Stratton Briggs Stratton...
Automatic choke will not shut off once the engine is running so engine dies. Could it be a spring is missing ?
There is a diaphram that the link connects to the choke. It is between the carb and the gas tank, and runs by the vacuum from the engine. B&S engines have to rev up for the choke to open all the way.
Sep 20, 2014 | Cub Cadet Garden
Lt1050 black smoke after 15 minutes
The black smoke and black spark plugs indicate that the engine is running very rich (ie too much fuel). This could be caused by the choke not opening fully after the engine starts and the fuel mixture is too rich OR the fuel mixture setting is opened too far.
Check the choke lever, make sure the choke is fully open when the choke is in the running position.
When the engine is running with the throttle is in the 3/4 rev position then adjust the fuel mixture to get the highest RPM.
Apr 19, 2012 | Cub Cadet Garden
Motor wont rev up when starting cold with choke on trys to run on idle but will not rev up
the motor wont rev high on choke.the motor is suppose to fire once on choke. then turn the choke off.pull the start cord and the motor should start and run.check that the throttle conrol is on full. it should run fine.
Dec 26, 2010 | Honda 8 HP Engine
Engine does not continue to run
Are you laying off the choke at any point? Full choke should only be used when starting a cold engine, it should run with no choke on full throttle. If there is not enough throttle i'd first try adjusting the tiny black screw on the carb beneath your air filter while you have it idling, letting the throttle have a little bit more room. If this doesn't work and you're running it properly than you may need to make some adjustments to the H L settings for your gas/air mix. This is also done while idling mind you and only with a clean air filter.
Apr 02, 2010 | Honda 25cc 4-cycle Mini Tiller
My 2006 yamaha v star 650 will run with choke on but will not rev . the engine will not run at all with the choke closed . if you cover the air intake it will rev
You have a vacumm hose loose look for small hose no connecter to anything - should solve it - I had a similar problem with a ZX9r the other day - same would run fine on choke not idle or start without it
Good Luck
Del
Jun 29, 2009 | 2006 Yamaha V Star Classic
1984 aspencade starts w/choke and revs up, runs smooth. Take off
My 'wing won't run unless it has been warmed up some. I would suggest that you r&r your carbs to make sure the jets in the bottom are working correctly. They tend to get plugged up, especially after sitting & the aluminum flaking off inside... Rick
Apr 05, 2009 | 1982 Honda GL 1100 Aspencade Gold Wing
When I start the engine from cold it runs on high revs too long
Hi ..... This sounds as if it's fitted with an automatic choke, as long as the revs drop when it's warm there is nothing to worry about. The indication when these start to go wrong is that the car won't start when cold ................ even then any decent mechanic can fit a normal/manual choke.
Jan 03, 2009 | 2004 Hyundai Santa Fe
Yard Machines 11A54MC006 21Inch 139cc MTD OHV Gas Powered Side Discharge Logo
148 people viewed this question
Top Yard Machines Garden Experts
dannydoesita
Phil Walker
Phil Walker
Dean Gruber
Are you a Yard Machines Garden Expert? Answer questions, earn points and help others
