Question about GE Refrigerators
Ice maker doesn't make ice. Not an auger issue, not making ice
    Genius:
  • 1,073 Answers
What is the model number
Posted on May 17, 2008
Frigidaire frs6lf7fm. Ice maker dispenser, the auger won't turn (tested with ttay out). It makes ice and dumps it into the bin no problem. And the water side is fine.
[FIXED] Icemaker auger motor won't turn - ApplianceBlog
www.applianceblog.com/.../18196-FIXED-Icemaker-auger-motor-won-t...
Apr 16, 2010 - 9 posts - ‎2 authors Does the auger motor need to be re-set or something? I wonder if it shut itself down to prevent burnout (because it had been unable to turn the ... FIXED Auger won't turn to dispense ice.
Jun 1, 2014
Ice maker auger will not turn
Mar 17, 2013
FIXED Ice Auger won't turn
Sep 3, 2012
GE Icemaker: Makes Ice, Doesn't Dispense In Door?
Apr 19, 2005
More results from www.applianceblog.com
Oct 01, 2015 | Frigidaire Refrigerators
Ice maker does not dispense ice through the door
Hello. I had the same problem. I replaced the auger motor(around$95) 3 times and would only last about a little longer than a year. I bought the 4th one but this time, I wanted to diagnose the issue. So it turns out that the auger motor goes installed with the impeller upwards. What was happening was that if a piece of ice would stay in the dispenser chamber and melt, the water would go into the auger motor eventually causing the auger casing to get full of water and slow it down or short it out. I took the casing apart and noticed that there was a small space between the motor and the casing. I drilled 2 nice sized holes in the dimple of the new motor very gently as to not drill into the impeller motor and installed the auger. To this day, 3 years later, no more having to buy new auger motors. Hope this helps!
Mar 10, 2015 | Refrigerators
I have a clear view ice maker and it fills fine and makes ice but it don't empty
Its issue with icemaker auger or dispenser assembly.Ice maker assembly has to be replaced.If any auger or auger motor is faulty.
Replacement parts can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
partsselect.com
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 23, 2012 | Refrigerators
Makes ice fine but ice doesn't come out of dispenser or make noise trying to intermittently.
Hello there,
When there is a problem with the motor that opens and closes the dispenser is when you will be experiencing such problem as having the ice maker making ice but not dispensing them
Most likely frozen up auger motor. Try removing the auger motor and thawing it to see if it will then run.Your auger motor may be frozen, use a hair dryer on it and see if it starts turning again.
The best, if not easiest way to access the auger motor is pull it out. It's just four screws, two on each side of the fork assembly. The white plate and auger motor will come out together. There is a quick disconnect for the wires.there are boot kits to install over the motors to prevent this or just put it into a plastic zip lock bag with the shaft poking thru a hole in the front.
Hope this helped. All the best Elect_Comp
Sep 26, 2011 | GE Adora DSS25KSTSS Stainless Steel Side...
My ice maker makes ice but will not dispense it
When you push the lever to dispense ice, can you hear the motor running? If not, that motor might be dead and not turning the auger, which would be your problem.
If you can hear the motor and auger turning, the chute or the opening in the ice maker might be clogged up with ice. Clean the entrance to the ice maker and the chute in the freezer door and that should fix your problem.
Dec 13, 2010 | GE Monogram ZDI15C Automatic Icemaker
GE refrigerator model GSS22 WGMD ice maker motor
If you cant manually turn your auger motor, it may be bad. Does it dispense solid ice or no ice at all? Another thing may be your control panel. That could be bad too, it's the one sending juice to both your solenoid and auger motor.
Jul 09, 2009 | GE Profile PSW26P Stainless Steel Side by...
Ice will not come out of the door. The auger is not turning
take the ice bin completely out and run water in it until all the ice is clear from the auger
Mar 28, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker auger not turning
ICE MAKER NOT MAKING ICE ON MY GE SIDE BY SIDE FRIDGE.
Jan 20, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Replacing Auger in ice maker
Kim There are two Screws Holding the Complete Ice unit in Place,After Removing it it unpluggs inside the freezer,It would be advised to Replace the whole Unit ttech
Jul 20, 2007 | Hotpoint HSS25GFP Side by Side...
Refrigerators Logo
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
