Question about Roper RAB2121KW Top Load Washer
Roper top loading washing machine
The agitator won't move. The belt seems to be OK. and the water drains without a problem? What could be wrong.
  • Anonymous Jun 12, 2008
    my fathers done the same thing. The repair person found out it was the transmition. the gears are made of plastic & metal. The repair person said the machines are only built to last 1-3 yrs. ours made it to 1yr 3 weeks. Piece of JUNK!!!
  • Toby Norton
    Toby Norton May 11, 2010
    How old is the washer? Does the agitator turn freely by hand?
  • 246 Answers
We have not heard back on this in about a week. I'm presuming it's now repaired?
Posted on Jun 21, 2008
Sm8280871 is the model listed under the lid. It is a Roper by Whirlpool top load washer about 10 years old. I can hear the motor however the washer does not spin, or drain. It appears that it tries to...
I suspect the V belt is worn out try taking the side cover off you would have to tilt the machine another helper maybe needed make sure you drain the remaining water out and unplugged the cord safety first
Oct 24, 2013 | Roper RAK2751WWH Top Load Washer
Please describe a typical washing cycle to me on the RTW4440XQ Roper 3.1 Cu. Ft. Top-Load Washer, please.
The typical cycle is;
fills to selected water level
agitates wash cycle
drains wash water
spins wash cycle
fills to selected water level on rinse cycle
agitates on rinse cycle
drains rinse water
spins final time
end of cycle
Aug 08, 2011 | Roper Washing Machines
Roper top loader problem with a RTW43408q0. Washer wouldn't spin at first. I ran that cycle again. It filled with water and didn't agitate or drain the water at all.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Apr 21, 2011 | Roper Washing Machines
WASHING MACHINE FILLS WITH WATER GOES NO FURTHER
not too familiar, but just replaced my lid switch (but that worked) and thru my research I found could also be the belt, so try researching that, sorry could not be more help
Oct 07, 2009 | Roper RAS6233KQ Top Load Washer
GE Top Load Washing Machine -- Agitator will not cycle
Agitator's don't spin on wash cycle.
I would suggest washing the clothes without soap until they rinse clear. If you have hard water, the soap will not easily rinse out of clothes, or off of you when you use soap to wash or shower.
Reduce the amount of soap you use in each wash if this is the case. It sounds like your washing machine is working right.
Jan 26, 2009 | GE WBSR3140DW Top Load Washer
Agitator does not move but activates high pitch buzz
genaral electric washing machine fills won,t spin but throws out water as if it did, goes to next cycle same thing, but sounds as if it is spinning but isn,t, hose not clocgged i checked, what else can be the problem,sounds ok but not spinning
Jan 26, 2009 | Roper RAS8445KQ Top Load Washer
Water pumps in timer cycles but machine will not agitate or spin
Hii!! yo check your washer belt.if on the you have a tranny problem.good luck
Jan 16, 2009 | Frigidaire FWS833A Top Load Washer
Roper(whirlpool) washer will not spin model # ras7133kq1
check the motor coupler between the motor and the transmission
Mar 17, 2008 | Roper RAS8445KQ Top Load Washer
Roper RAB2121KW Top Load Washer Logo
50 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
