Question about Apple iPhone 3G
My I phone will not ring and it is turned up as high as it will go ringtones will play in ringtone section
  • Apple Master
  • 6,993 Answers
there must be some mix up in the settings of your iphone. To solve this problem, you might need to reset your iphone. Follow the procedures below to reset your iphone:
  1. Press-hold the Home button (big circle below the screen) and the Sleep/Wake button (on top of the iPhone) simultaneously.
  2. Continue holding both buttons (Ignore the "Slide to power off") until the iPhone shuts off and begins to restart.
  3. You may let go when you see the silver Apple logo.
  4. You have completed a hard reset successfully.
I hope this helps.
Good luck.
Posted on Sep 15, 2010
My iPhone 5c won't ring
Does the phone plays music without any problem? If you play music to hear it on the loud speaker, and there is no sound, then you probably have a hardware failure, (bad speaker). But if you get to listen to the music, then try this next steps to see if it can be fix.
  • From the iPhone's home screen, tap the Settings app.
  • In Settings, tap Sounds in the third group of options.
  • In Sounds, swipe down to the Sounds and Vibration Patterns section. In that section, look forRingtone. That displays what you have set as your current iPhone ringtone. Tap it to change that.
  • This menu shows you the list of all the ringtones available on your iPhone.
    To get new ringtones, tap the Store button in the top right corner. This will take you to the ringtone section of the iTunes Store where you can stock up on new ringtones.
  • If you choose not to buy new ringtones, but instead use the ones loaded on your phone, the first set of options in the Ringtones section are ones that you bought from the iTunes Store or created using another app and have synced to your iPhone. The ones below the divider came pre-installed on the iPhone.
    Alert Tones, farther down the screen, aren't ringtones exactly. They're alert sounds normally used for alarms and other notifications, but they can be used as ringtones, too.
  • When you tap on a ringtone, it will play so you can preview it and decide if it's what you want. When you've chosen the ringtone you want to use as your default, make sure it has the checkmark next to it. Then tap the Sounds button in the top left corner or click the Home button to go back to the home screen. Your choice is saved automatically.
  • Now, whenever a call comes in, the ringtone you just selected will play (unless you've assigned individual ringtones to callers, that is. If you have, those ringtones take precedence). Just remember to listen for that sound, and not a ringing phone, so you don't miss any calls.
  • Mar 13, 2014 | Cell Phones
    Change ring tone
    How to Change the Ring on a Motorola V360
    When you change the ring on your Motorola V360 from the standard ring to another of your choice, you give the phone a personal touch. Rings, or ringtones, are included with your phone. You can also download and install ringtones from a mobile content provider or your mobile service provider. The ring you select sounds anytime you receive an incoming call. You can change the ring at anytime through the Motorola V360's settings menu.
    Instructions
    1.Press the "Menu" key on your Motorola V360 and click "Settings."
    2.Click "Ring Styles" and select "Style Detail."
    3.Highlight "Calls" and press the "Change" soft key.
    4.Highlight the ring you want to use on your Motorola V360. When highlighted, a brief preview of the ringtone will play.
    5.Press the "Select" soft key to choose the ringtone.
    6.Press the "Back" key to set the ringtone on the Motorola V360
    Read more: How to Change the Ring on a Motorola V360 ' eHow.com http://www.ehow.com/how_8468915_change-ring-motorola-v360.html#ixzz1XEda3gRH
    ---a score of 4 is highly appreciated----- ---if you think this resolution is helpful kindly click on "YES"---- ---you may also leave testimonial-----
    Thank you for choosing fixya
    Roger
    Sep 07, 2011 | Motorola Mobility V360 Cellular Phone
    Ringtone
    it should be as simple a going into profile select customize then edit pick the song you want and save,,,,,,but hope your changing your voice ringtone,, and not the one that say video ringtone there are right below each other if your changing a ringtone for a specific person ofcourse you must be in contacts,, edit,,, then scroll down and change the default ringtone and save,,,hope it helps.
    Jul 29, 2009 | LG KU990 Viewty
    Different ring tones
    To assign individual ring tones:
    1) you must go to the phone book, highlight the wanted contact, click on options and then edit.
    2) scroll down until you see the section "ringtone" and click on it.
    3) Then choose audio, then ringtones. click on the ringtone you want, you must listen to it first, and then click on "select".
    4) if you want a ringtone to be something you've recorded, click on "my voice" rather than "ringtones"
    May 25, 2009 | Pantech C610 Cell Phone
    Pantech matrix
    yes, try to convert them to .MID format if it didnt work. go and see what format the original ringtones on the phone are and convert the ring tone you want to that format (some phones are .acc)
    Dec 29, 2008 | Pantech Matrix Cell Phone
    Ringtone problem
    You settings are not activated so please refer your phone user manual do the steps by step then it will work fine
    1) First save the specific number
    2) Select the ring tone
    3) Assign the this ring tone for that number
    This information help to you othere wise refer your phone user manuals
    Jun 11, 2008 | LG VX8300 Cellular Phone
    Ringing Tone
    Just copy the ringtone in phone memory which you want to set. It will give you option to set it as ringtone.
    Jan 17, 2008 | Nokia 6600
    Ringtone will not work
    Even though I've reset the master volume, etc. the ringtones will not work, I can't play them and the phone will not ring. In tools, sounds setting, call sounds, call ringtone: help
    Jan 03, 2008 | Motorola Mobility RAZR V3m Cellular Phone
    Ringtones
    Did you create a folder for the Ringtones? if you did, make sure you have it on 2 (sounds)...go to Menu, Press 7 (my stuff), press 2(sounds) open your Ringtone folder and Voila!!! der they r...press d options (dont play the song, just highlight d ones u want to set as a ringtone) press 2...n der u go.
    Reps are appreciated :)
    Nov 28, 2007 | LG Shine KE970 Cellular Phone
    No sound when phone rings
    I called Verizon Wireless and the said, if you go to “My Sounds” or “My Ringtones” select the song that you want to hear and press the play button. While the ringtone is playing press the button on the side of the phone to raise the volume…you should be able to hear the ringtone. Hope this helps!
    Jul 29, 2007 | Motorola Mobility MOTOKRZR K1 Cellular...
    Apple iPhone 3G Logo
    Top Apple Cell Phones Experts
    Computer Repairing
    Computer Repairing
    Lesley Cameron
    Lesley Cameron
    Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
