Question about Microsoft Office Visio Professional 2007 for PC
I have an object that will not preserve Arial as font type. Steps to recreate: 1. Pull object from stencil 2. Type in text 3. Type shows up as wingding 4. Select object 5. Select Type --> Arial 6. Text becomes Arial 7. Copy object 8. Paste object 9. Text is now wingding, again 10. Alternatively, paste object with Arial text to an MS Word document - object type becomes wingding, again. 11. Alternatively, "paste special" object with Arial text to an MS Word document - regardless of "paste special" options (tried all of them) the object pastes with wingding text. HELP!!!
5 Suggested Answers
SOURCE: every time i try to copy/paste something to word
hi,
try to reduce the font size of the copied content and paste in to the word processor,
or break the pages i, e copy part by part of the application and then paste it.
Posted on Mar 04, 2009
  • 205 Answers
SOURCE: Font & Line Spacing Change (not to default) when pasting text
Try pasting using ,paste special option from edit > Paste special
Posted on Apr 12, 2009
  • 66 Answers
SOURCE: Cut and Paste MS Word to Mail Crashes
This could happen if some of the dll files are corrupted go to the below link download the tool for vista .
when the program opens up .. from the drop down choose email and browser realled issue and click fix
https://account.live.com/autocare.aspx
Posted on May 09, 2009
  • 6 Answers
SOURCE: Similar problem
Hi, turn of aoto format from the manu.
Posted on Jun 22, 2009
Change the font style on a Bee3 label maker
1. Press "Style." The screen shows "lines." Press "Return." 2. Use arrow key to select "1 Line" (or "2 lines" of text, etc.). Press "Return." 3. Use arrow key to select "1a," "1b", "1c," or "1d" (text). Press "Return." 4. The screen says "vertical." Arrow down to "END?" Press "Return." Then the screen shows "AREA Label." Press "Return." 5. Type your text. Preview and Print. Call 1-800-622-6312 fmi or a manual! Changing the font on your Sun BEE3 BEE3 label printers
Apr 10, 2014 | K-Sun Corporation BEE3FB - BEE3 LABELShop...
Tip
Water damage
Hello, If your device has a water contact, please follow the instruction :1. Remove Battery immediately.2. If you have a tools to dis assembly (if you don't know how to open device search on goggle.com or you tube), do it and then clean main board with alcohol and let it dry completely also clean housing and small parts, then dry the board (re hot) with hair dryer or hot gun station for 15 min. Then Check if your device working properly, if yes then use for 3 days to check if any problem notice then show some official repairer. if no please don't try anything else, show some official repairer.
on Jul 06, 2012 | Nokia Lands Phones
Tip
TOSHIBA DVD REGION FREE HACK METHOD.
1. Power on.
2. Open tray.
3. Push the info on remote once (with supplied remote). You will see numbers.
4. Press 9 for multi-region. Keep trying until you see the number 9 appear in upper left corner.
5. Power off.
Power on.
on May 21, 2012 | Toshiba Televison & Video
Need to change the pass word
p.p1 {margin: 0.0px 0.0px 0.0px 0.0px; font: 13.0px Arial} p.p2 {margin: 0.0px 0.0px 0.0px 0.0px; font: 13.0px Arial; min-height: 15.0px} p.p3 {margin: 0.0px 0.0px 0.0px 0.0px; line-height: 16.0px; font: 13.0px Arial} p.p6 {margin: 0.0px 0.0px 0.0px 0.0px; line-height: 16.0px; font: 12.0px Helvetica; min-height: 14.0px} li.li3 {margin: 0.0px 0.0px 0.0px 0.0px; line-height: 16.0px; font: 13.0px Arial} li.li4 {margin: 0.0px 0.0px 4.0px 0.0px; line-height: 18.0px; font: 13.0px Arial} li.li5 {margin: 0.0px 0.0px 4.0px 0.0px; line-height: 15.0px; font: 13.0px Arial} span.s1 {font: 13.0px 'Lucida Grande'} span.s2 {font: 11.0px Arial} ul.ul1 {list-style-type: none}
the only way to change the password is to either login to the router and
All Belkin Router's ship without an admin password. If you require an admin password then follow the below instructions.
Setup steps:
  • Connect the computer to one of the four LAN ports on the router.
  • Open a web browser on the computer.
  • In the address bar of the web browser, type http://192.168.2.1
  • Click Login in the upper right-hand corner of the page. The router does not ship with a password, so just click Submit.
  • Click on System Settings under Utilities on the left-hand side of the opened page.
  • You will see a feature called, "Administrator Password". Type in your current password (default leave blank).
  • Click "Apply Changes". Your new password is now active.
if you dont know your password then you have to reset the router to factory settings
Setup steps:
  • Locate the reset hole on the router. The button will be on the back or side of the router.
    See images below:
  • Leave the router powered on.
  • Use a paperclip (or similar) to press and hold in the reset button for 10 seconds.
  • Remove the paperclip.
  • Wait approximately one minute for the router to restart.
Mar 06, 2011 | Belkin (F5D5231-4) Router
I m not able to operate the webcam and i don't know thw procedure.
Normal 0 Try disconnecting the Camera from the USB port and reinstall the software program. When the program asks you to connect the camera to the USB port, do so and it should work.
Then to use it on the Web do this.
Web Camera’s have to be setup on the program they are to be used with. Just installing the camera on your computer does not set it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order for the Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype (http://www.skype.com/intl/en-gb/download/skype/windows/beta/downloading/ ) set it up as follows:
  1. Go to Tools, then Options, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
  2. Then click on the Video Settings.
  3. The camera if Installed Properly will come up and show a video picture.
  4. Then, on the bottom of the page click on Save.
The camera and audio should function properly. Your friends and Family will now be able to see and her to you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger (http://www.soft32.com/download_30.html ) set it up as follows:
  1. Go to Messenger at the top left and click on it.
  2. Next go down to Preferences and click on it.
  3. Next Calling and Devices on the right and set the Microphone and Speakers to the computer Audio Card.
  4. Next go to the Test Audio section and (in blue writing) click on “Open the call setup assistant” and follow the instructions on the left window.
C. Windows Live Messenger:
  1. After you start Windows Live Messenger, expand the view by clicking on the square on top left next to the red X.
  2. Then on the Windows Live messenger window on the right side, click on “ “Show Menus.” And then click on “Show the Menu Bar”.
  3. Next go to the Menu Bar on right side, click on “ “Action.”
  4. Go to “TOOLS” and click “Audio and Video Setting” and follow the instructions.
NOTE: You audio and video should work. Enjoy.
When done both the Audio and Video will function properly so you can chat and see family or friends you are connected to.
Hope this helps. Bud
Jan 26, 2009 | Computers & Internet
Tip
How to Unlock a 16GB iPod Touch
Apple's iPod Touch comes with a screen lock feature that allows you to set a four-digit security code to prevent others from using your iPod. Every time the iPod locks, you must enter this code to unlock the screen and access the user interface. Entering the wrong code too many times, or simply forgetting your security code, can cause you to be completely locked out. When this happens, you can quickly
Instructions
1Connect your iPod Touch to the computer you usually sync it with. When you disconnect your iPod, it should now be unlocked.
2 If Step 1 does not work, you have to restore your iPod Touch. Be advised that restoring your iPod Touch returns it to the original factory settings. This means that all your songs and files will be deleted and lost. You can resync your files to your iPod from iTunes once you have finished restoration. Connect your iPod to your computer and open iTunes. Make sure you have the latest version of iTunes before proceeding.
3 In the left navigation panel in iTunes, select your iPod under the "Devices" section. Click the "Summary" tab and select "Restore."
4 When iTunes prompts you about backing up your data, click "Back Up." In the following window, click "Restore."
5 After the restore process completes, you will see the Apple logo on the screen of your iPod. Leave your iPod connected to your computer until it shows up again on the iTunes navigation panel.
6 Your iPod touch is now unlocked. In iTunes you will be able to setup your iPod. Select the backup you made in the drop-down menu to restore your data files. Click "Continue" to finish the restoration.
Tips & Warnings
Apple notes that the company will not be able to help you unlock your iPod if you forget the security combination. Your only choice is to restore the device to the original factory settings.
on Dec 16, 2011 | Apple Computers & Internet
Text is blurred
The problem is with text font size and image resolution. These two are married together. In other words one supports or hinders what the look of the end result will be. Increase the pixel depth of the image and then insert your text with a larger font size and the result should be clearer. As you may know, when you enter text it becomes another layer in your image. Once the object in this layer is created it can be resized. And, resizing may be the answer to get the font size you actually want and a crisp, no pixelated, edge for your type face.
Can you exchange messages with me over the next 12-24 hours as I give you a tutorial with your current project?
I have a business to run myself and just so happens that today and tomorrow I'm pretty busy. But, I've taught this software in version 7 at our community college a few years ago and help local clients all the time with PSP.
Regards,
Worldvet
May 21, 2008 | Corel Paint Shop Pro 9
Microsoft Office Visio Professional 2007 for PC Logo
73 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
