Question about RTO Amertac TEO5W Decorative Indoor Weekly Digital Timer, White
Westtek digital wal switch timer. when I hook it up per the wiriing diagram it casues the lights to flash quickly,. Three wires on old wall switch ground, white and BLack. four wires on New timer Whte, black, green and red. How do I wire it up ?
You are connecting red and white wire together.
Open following links for clear description of single-pole timer wiring:
http://waterheatertimer.org/Programmable.html#wire
http://waterheatertimer.org/Program-wire-Utilitec-0141224.html
Posted on Oct 03, 2011
I'm looking for help. Installing a Woods 59007 timer. It has 4 wires, red, black, green, white. My current electrical setup is a black, white, and ground wire in the box. How do I hook this up? T
Hook all the white wires together.
Hook all the greens or bare copper wires together.
Hook your hot black to the timer black.
Hook your black wire that goes to your light to the red switch wire.
then try the switch if the light doesn't work switch the red and black switch wires around black to light red to black power.
Oct 19, 2014 | Woods In-Wall Digital 5-10-15-30-Minute...
Is it possible to connect a digital timer(4 wires) to lite fixture with two switches? The switch I am trying to connect to is three pole and a ground
If I understand correctly, your switch has 3 poles, which makes it a 3-way switch.
You confirm this by saying light fixture has two switches.
There are two brands of in-wall timers that will work in 3-way situation. Intermatic and Aube. But only specific models of these timers work for 3-way.
The Intermatic EJ500 and ST01C battery-operated timers can work with 3-way switch. But wiring is tricky to impossible in some cases without extra wiring.
http://waterheatertimer.org/ST01C-program.html#ST01C
The easiest timer to wire for 3-way switch is Aube model T1032 which is a 500 watt timer.
http://waterheatertimer.org/Aube-timers.html
T1032 manual:
http://waterheatertimer.org/Aube-T1032-timer.pdf
Look at the wiring diagrams carefully.
Note that you are replacing one switch with the timer.
The second switch needs additional jumper wire added to circuit between dark-colored screw and the brass-colored screw that connects back to #1 wire from the timer.
Add a comment if you have this timer, or buy this timer, and need help with wiring.
Dec 06, 2010 | RTO Intermatic Digital 7 Day Wall Switch...
15265 In-Wall Digital Timer - I am replacing an Aube with this new timer. Timer is to operate a wall plug (outdoor soffit). Timer is inside. The old switch had 3 wires - only two were connected (I think...
GE -15265 manual
http://waterheatertimer.org/pdf/GE-15265-manual.pdf
Ah, the usual how to connect 4 wires to the old 'was-3-wire and now-2-wire' problem.
I tested and wired these timers.
Aube timer has internal rechargeable battery, and therefore does not need another wire to run internal clock.
GE timer has extra wire to run internal electronic clock, just like alarm clock is plugged in.
Heres what to do in simple format
1) Timer-green-wire connects to bare ground wire.
2) Old timer has 2 wires. Take both wires and connect them to timer-black-wire and timer-red-wire. Choose either one for now.
3) In back of electric box are white wires twisted together and covered with wire nut. Connect timer-white to these wires. This action will complete circuit to internal clock.
4) If electric box does not have white wires described above, then connect timer-white to bare ground. This works because bare ground and white neutral both connect to neutral busbar inside breaker box.
5) Turn on electricity, push in timer door for manual override. If lights come on, timer is wired correctly. If lights do not come on, then reverse timer-red and timer-black wires.
If light does not come on, double check that outdoor bulb is good, and that breaker not tripped.
Timer can also be reset in event of short. Reversing red and black wires will not short timer.
Add a comment of you need more help
http://waterheatertimer.org/See-inside-main-breaker-box.html
Nov 30, 2010 | Intermatic Inc. EJ500C Digital Wall Switch...
Installing a 7 day digital wall timer
Swylite LST100 timer has 4 wires. Red, Blue, Black, White
Timer has more wires than wall switch because timer has electric clock inside. And with + series Swylite timer, it also has led bulb that needs power.
Timer can replace ordinary on-off switch
-On-off switch has 2 screws, so 2 wires (plus ground wire) connect to on-off switch
-Three of the four timer wires are used when replacing on-off switch
-Red wire is not used, it is capped off
Timer can replace 3-way switch
-Three way switch has 3 screws, so 3 wires (plus ground wire) connect to 3-way switch
-One of the screws on 3-way switch is colored dark (it is crucial to identify the wire that comes off dark screw so timer can be wired correctly)
Lets replace on-off switch see diagram
Timer black goes to Hot wire
Timer blue goes to Load (light, fan, motor)
Timer white goes to Neutral
Timer red is capped off.
How to check which wire is Hot, Neutral and Load
Switch you are replacing has 2 wires > one is Hot, the other goes to Load
Remove these two wires. Separate wires so you can test. Turn on power. Tape tester leads to wood sticks so hands are away from power. Test each wire to bare copper wire.
When tester lights up >> that is Hot wire >> please connect this wire to Timer black wire
The other wire goes to Load >> please connect this wire to Timer blue wire.
Now test for Neutral. Test Hot wire to other wires inside box. Neutral should be white. When tester lights up, that is Neutral. Please connect Timer white wire to neutral. IF YOU DO NOT have a neutral, you can connect Timer white to bare ground wire until you have time to drop a Neutral into the box.
Replace a 3-way switch see diagram
Three-way switch has 3 wires.
Identify which wire connects to Dark screw on switch >> and then please connect this wire to Timer Black wire.
Timer white wire connects to Neutral
Timer blue and red wires connect to other two wires that came off switch ... they connect to either one.
Oct 01, 2010 | Solar Ivory Swylite Lst100+ Back-lit...
I bought Utilitech #0141224 7 day digital in wall timer. I have just 2 wires at the junction box both of which are painted over but assume one could be black and other white. The 7 day digital timer...
Hello, I bought an in door smart digital timer (G.E.) or Jasco product for my front porch light. I hooked all the wires as instructed and programmed according to instructions. I have a two wire system, so i left the green wire unattached. The light comes on but flashes very fast. What's up with that? This is the second one i've replaced, the first one did the same thing!. Whats wrong?
Thanks,...
M Jones
Sacramento, CA.
Aug 16, 2010 | Intermatic Inc. ST01C Digital In-Wall...
Bought an intermatic model EI600 wall switch timer to use with gfl outsidelights. black green, blue and red wires from the back. Went black to black, green to ground, red tored and blue to white in...
That is a three way timer. There is no wire that the white wire gets hooked to. The black is the hot, the blue sends power to the device, and the red goes to a switch that connects it to the blue wire essentially. Here is a PDF of the directions, including wiring diagrams.
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/ei600c%20-%20english.ashx
Mar 06, 2010 | Intermatic EI600WC - In-Wall Decorator...
GE Digital Time Switch (15132) for basic landscape lighting
Leave the breaker off, remove the wires from the timer and just connect them. then turn the power on. Unless you have a short somewhere, the lights should come on. What you have just done is made the breaker your switch. If the breaker kicks you know to keep looking for a short as it is not the timer. Regards, Joe
Jan 04, 2010 | Intermatic Inc. EJ500C Digital Wall Switch...
I have a GE in-wall digital timer that I want to use to replace a light switch The light swithc has 2 wires, the timer has 3 which does not make sense. What do I do
Now you need to know a few things before you trying this, #1 Where the Circuit breaker for the lighting you are working on is located. #2 which wire is your power/hot wire going in to your switch. #3 which wire is going directly to the light. #4 what a neutral/return wire is. #5 some general electronic terms.
If you do not understand or if you cannot understand the above paragraph Please seek the help of a qualified/licensed election.
Well the reason the wall timer has 4 wires, is that it IS NOT just a Switch. It is in fact an election device. It requires Power (your Black Wire), a Return (your White wire), and a Ground (your Green wire). It also has a Output (your Red wire), this output wire controls your light (turns it on or off).
IF you’re still with me?
#1 turn OFF the Circuit breaker for the lighting you are working
#2 Take a part the light switch box for the light you are working on (only disassemble as far as necessary)
#3 Take your Ground wire and hook it up to the ground within the same location.
#4 Take your Return wire and hook-it-up to the nearest return wire within the same location.
#5 Take the black wire on the wall timer and hook-it-up to the Hot/Power wire.
#6 Take your Output wire and hook-it-up to the wire going directly to the light.
#7 Inspect your work to make sure there are no shorts, no unconnected/terminated wires in your light switch box.
#8 Before placing everything back tougher turn ON the Circuit breaker for the lighting you are working then run a test.
#9 OFF the Circuit breaker, then inspect your work to make sure there are no shorts, no unconnected/terminated wires in your light switch box.
#10 If everything is working then place everything back tougher. Then turn ON the Circuit breaker.
#11 If you did not have your Circuit breaker pop/turn off the lighting you were working, your dun.
Dec 18, 2009 | Intermatic Inc. ST01C Digital In-Wall...
RTO Amertac TEO5W Decorative Indoor Weekly Digital Timer, White Logo
458 people viewed this question
Top RTO Hardware & Accessories Experts
Craig Butler
Craig Butler
Gene Haynes
Are you a RTO Hardware and Accessory Expert? Answer questions, earn points and help others
