Question about Westinghouse SK-26H520S 26 in. LCD HDTV
My display is black. If I hold a flashlight up to the screen, I can barely see the picture. What is wrong? What can I do to fix it?
  • Westinghouse Master
  • 5,427 Answers
The backlights have probably failed. You should also check the inverter that drives the backlights (it's like a ballast for a fluorescent light).
The backlights are sandwiched on the perimeter of the TV (usually under some tape that holds the lamp, reflector and other parts together. You need to order by length and width and get ones for your TV size. Most TVs have more than one backlight. Open up the tv, remove the shielding and carefully separate the screen from the bezel. Remove the tape, and separate the reflector (make a note of how things are put together) then you have to Dremel (or use another rotary tool) to remove the plastic to get the backlight out. (They are often molded into the frame.) Then put in the new backlight and reassemble everything. (http://www.lcdparts.net/howto/default.aspx) but for an overview: http://www.inventgeek.com/Projects/BacklightFix/overview.aspx Then push the new backlights into place, reconnect the wires and close up the sandwich of tape and other parts around the screen. Then replace it in the bezel.
To check the inverter, open up the tv and remove the shielding. Then use a high-end multimeter (able to measure high frequencies - 50 kHz) or an oscilloscope, hold the multimeter probes a fraction of an inch apart about an inch above the board and power up the TV. If you see a 1 or an actual value, you have a good inverter. If you see a reading near 0, the board is bad or the multimeter can't resolve the frequency. While you are looking at the board, check for any scorch marks or bulging or damaged capacitors. (Sometimes other parts will fail on this part but these can be spotted easily. Capacitors look like cylinders on a tripod.)
In either case, you can buy a replacement inverter for $50-150 and just do a simple swap. Disconnect all of the wires (connections are similar to molex and ribbon cables in a computer) and remove board (a few screws usually). Connect the cables to the new inverter. (If you google backlight inverter replacement, you'll find videos and text descriptions.) Note the part number on the board, including the Rev number, and order the exact one (shopjimmy.com or lcdparts.net are good starting points). Universal inverters do exist but can result in reversed controls (up to lower the brightness). Replacing individual parts on the board is cheaper but more prone to not tracking down all of the bad parts.
With a good spare backlight, you can test an inverter for condition (plug together and turn on the tv while the box is open). Similarly a good inverter can test the backlight.
I hope this helps.
Posted on Sep 15, 2010
Everything works except the screen doesn't show images.
Try pressing the "display" button slowly but repeatedly.
Jul 05, 2016 | Nikon COOLPIX L20 Digital Camera
Why is screen black?
It's most likely faulty or wrong inverter part. Make sure you have the exact inverter part. Also, check your connections just in case loose connection.
Feb 01, 2016 | Televison & Video
How can I fix black screen on Philips 42" LCD TV?
chances are it is cracked solder joint on internal board,
check link below, press the helpful button
http://www.repairfaq.org/samnew/tvfaq/tvtmmqcs.htm
Jan 24, 2016 | Philips 42PFL7422D 42 in. LCD TV
Gateway m280 notebook black screen.
Why did you replace the lcd inverter? Were you able to barely see icons on the desktop which is an indication that the lcd inverter is bad? If not, then you need to replace the lcd screen. If you could barely see the icons and you replaced the lcd inverter, then the inverter is bad. Just because the inverter is new does not mean it works. If the video shows on the external monitor, but you can't see anything on the laptop's screen even when you shine a flashlight on it then the lcd screen is bad.
Shine a flashlight on the dark screen to see if you barelysee the icons on the desktop. If so, then the LCD Inverter is bad.
Plug in an external monitor and see if the display shows up on it. It can beany kind of monitor even the old big fat crt monitors as long as it has a vgacable to connect to your computer's vga port. If so that proves yourvideo card is ok. The video will show on most systems when you rebootwithout you having to do anything. Some systems will require you to hit the FN(Function key) + F1 thru F12. Hold down the FN key then hit the correctkey for displaying on the monitor (F1 thru F12). The correct key willnormally have CRT/LCD on it or it will have the icon of a display.
If you see no icons by shinning a flash light and the external monitor works,then your screen is bad.
If you see no icons by shinning the flash lightand nothing shows on the external monitor, then most likely your video card isbad.
May 24, 2012 | Gateway Computers & Internet
How to fix my black screen
Do you hear fans running, the hard drive spinning?
Does it seem like your laptop is booting up all the way except the screen is black? If so try the steps below:
Shine a flashlight on the dark screen to see if you barely see the icons on the desktop. If so, then the LCD Inverter is bad.
Plug in an external monitor and see if the display shows up on it. It can be any kind of monitor even the old big fat crt monitors as long as it has a vga cable to connect to your computer's vga port. If so that proves your video card is ok. The video will show on most systems when you reboot without you having to do anything. Some systems will require you to hit the FN (Function key) + F1 thru F12. Hold down the FN key then hit the correct key for displaying on the monitor (F1 thru F12). The correct key will normally have CRT/LCD on it or it will have the icon of a display.
If you see no icons by shinning a flash light and the external monitor works, then your screen is bad. If you see no icons by shinning the flash light and nothing shows on the external monitor, then most likely your video card is bad.
Apr 25, 2012 | Computers & Internet
Gateway ZX4000 all in one - the screen is black
Sounds like the Video Card is bad. Try plugging an external monitor into the laptop and see if it works. Any monitor will do, even the big fat old crt monitors. Look at your keyboard and normally there will be a sequence of keys you will have to hit to get the video on the external monitor. Normally you would bress the FN (Function Key) and hold it while pressing some other key such as F4 or F8. The key to press will probably have a picture of a monitor display on it or the wording crt/lcd
If it displays on the external monitor that means your video card is ok and your screen on the laptop is the problem and either needs to be replaced or it could be that the cables have come loose in which case the lcd monitor needs to be disassembled and the cables reseated.
One other thing, take a flashlight and shine it on the lcd screen to make sure that the icons are not there but are too dark to see. If you can barely see the icons with the flashlight that means the LCD Inverter is bad and needs to be replaced. The guys at: http://www.generalsystemsconsulting.com can help and they are very reasonable. They will fix it and ship it back to you by Fedex or UPS. Get a quote from a local source then try them.
Mar 10, 2012 | Computers & Internet
Samsung LNS 325 1D-the screen is blue-no picture but perfect sound-what is wrong? Thanks
Hi m5720,
Power on the unit in the dark room then shine with the flashlight directly in the screen, you will barely see the images. This is because your backlight is not functioning. The following reason is the caused.
1. Power supply - missing B+(supply voltage) coming from this board feeding the inverter board. This is caused by faulty transistor, dried/leaky electrolytic capacitor, open fusible resistor.
2. Inverter board - even the B+ is good from the power supply, if the fuse, driver transistor, driver transformer is faulty no output to the backlight resulting to black picture.
3. Busted backlight - even inverter board is good but if this is busted resulting to black picture also.
Diagnosing the fault is technical and if you don't have necessary tools and test instrument and can't fix it yourself, I would advice you to look for an experienced technician to isolate the problem.
Hope I helped you.
Thanks for using Fixya.
Jdvillanueva
Jun 04, 2011 | Samsung LN-S3251D 32 in. LCD HDTV
My proview 19 in turn on but then it goes black is it a capasitor and how to fix it or is ther a reset on it
It may be the internal backlight that is failing. You can take a flashlight and hold it close to the screen, move the flashlight all around the screen and check if you can see anything. The display will be dark, but you should be able to make out the image that is there with the flashlight technique. If you can see an image on-screen, then your backlight has failed and you will need to replace the monitor. Weather or not you see an image is not a critical issue, but a tool to verify if the backlight is off or some other issue is causing the problem.
Note, it may be difficult to detect an image on the un-light display, for example if you have a dark image as your desktop background. So make sure to fully scan your display (top to bottom, and left to right covering the entire screen) with the flashlight technique in order to see any image on-screen.
Mar 22, 2011 | Proview PL926WBi 19" LCD Monitor
Sound yes, but no picture on tv
If you have sound on the stations this is a problem in the display. Take bright flashlight and hold it against the screen. Look for an image around the edge of the flashlight. If you see an image then it's one of three problems;
1) The inverter board is bad.
2) The CCFT (cold cathode fluoresent light) are bad.
3) The power supply to the inverter board is bad.
Someone knowledgeable in electronics can replace the bad part(s).
Dec 21, 2008 | Samsung LN-S2641D 26 in. LCD HDTV
Westinghouse SK-26H520S 26 in. LCD HDTV Logo
436 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
