Question about RCA Televison & Video
My rca tv will turn on for about 20 mins then turn off model num is r52wh74
The boards need to be resoldered .the larger leads do not get a proper heat because of their mass and the wave technique used to solder them on the factory does mot give a good connection so what is happening is the TV warms up and expands and then the connections disconnect
Posted on Sep 23, 2010
R52wh74 fades to one color then dark, then black
awewryte,
I have the same TV and now have the identical problem that you described. Did you ever get it fixed or find out what the problem was? If so, will you please pass the information on?
Thanks.
Aug 08, 2009 | RCA Televison & Video
Rca r52wh74 - no auto convergance
The model number of your TV probably falls under the ITC-222 chassis design. Do a search based on that criteria and it should point you in the right direction. If I remember right, you need to replace FL231 on the deflector board though. Good luck
Dave.
Jun 03, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Where is a the fuse in a rca model r52wh74
On the main power supply board. To get to it you will need to remove the back of the case and locate the power supply board ( follow the power cord to the board ) and it is next to the connector.
BUT, I doubt that is your problem because if the fuse is blown then there would be no lights.
Mar 07, 2009 | RCA HD52W58 52" TV
Go to menu then setup look for convergence if it is missing on menu then you have a open FUSE/ FL231, But if you have convergence on menu then go into service mode turnTV off then PRESS and hold at same time ch- and vol- wait for set to come on then release TV should now be in Factory settings.
Feb 20, 2009 | RCA D52W23 52" HDTV CRT TV
RCA Model # R52WH74
ALL of you have a problem in power supply/deflection board 3 capacitors open located cp150 2200uf 16volt and two 220uf 35 volt, check them first then resolder around FBT other wise order new deflection board 125.00
Jul 02, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
you need to replace chemical type fuse marked FL231 part number 259213, it`s located next to the flyback transformer, theres 3 of them there but 231 is the only one I`ve seen cause your problem, replace it and you`ll be all set.Happy Holidays !
Nov 29, 2007 | Televison & Video
Televison & Video Logo
130 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
