Question about Zebra 140Xi II Thermal Printer
Zebra 140XiII - cannot print via Ethernet cable - Windows status monitor shows status as offline. I Installed correct drivers? what is the secret for connectivity!? Greg
    Champion:
  • Zebra Expert
  • 285 Answers
Check if IP adress, subnet mask and the gateway are correct on the printer setings.
Try to ping the IP address from the START-Run...(write CMD) and write ping IP adress.???.???.???.???
check if had responce.
Posted on Nov 13, 2010
Set static IP for Zebra 140XiII printer
Ethernet cable Must be plugged in and the printer must be ready for about 60 seconds before you enter the menu or the Ethernet settings will not show up.
Jan 18, 2016 | Zebra Office Equipment & Supplies
Cannot connect to printer anymore
make sure you have the current drivers for this printer are loaded. and select the wired set up configuration type. go to control panel select printers and see if the printer is visable to your pc. if not start over and reconfigure a new printer. and
follow the prompts. and may i also suggest going to there web site and check for the latest and the greatest on your model.
Apr 09, 2017 | Zebra QL 420 Thermal Label Printer
Zebra 105sl can't connect to new windows 7 pc
What motherboard is in the computer? USB to serial drivers can be chipset specific.
Apr 01, 2017 | Office Equipment & Supplies
The printer will not print any documents from any of the computers and its not saying anything under the job status
- if connected via usb ,check cable and usb port
- check in properties if printer status is enabled and use printer with connection or use printer offline is selected
- if connected via ethernet ping the ip adress and check cable
-if connected right on the copier without a switch in between you need a reversed ethernet cable else you need a straight one through the switch
Jul 17, 2012 | Toshiba E-studio 281c Copier
I have Zebra LP2844 printer and Windows Vista OS. I have installed Zebra LP2844 and ZDesigner LP 2844 drivers and I want to use ELP to print text, barcode etc. Printer is connected to computer via USB. How...
To send text to printer in dos command you should first install a driver from
www.seagullscientific.com
then in the properties you can use send file to printer.
To send the files from command :
Check if the program ssdal.exe has been correctly installed.
to have help use ssdel help send at dos prompt
to send the file
ssdal send filename printername should do the trick
hope it helps
Aug 01, 2011 | Zebra LP 2844 Thermal Printer
BrotherMFC-235C status monitor shows ink is empty,but its new ink,and wont print
we called asus and we had to delete a filter in the main program.problem now solved.
Sep 26, 2008 | Brother Office Equipment & Supplies
Zebra Z4MPlus doesnt communicate with PC
Ok,
This machine has a parallel port. Try to print via parallel cable. If it works, consider staying with it. Serial ports are a pain to manage.
If you absolutely have to do it via rs232 though....
Question 1. Has it ever printed?
If yes, Go into Windows Printers and Faxes control and select the Zebra or whatever printer that you are using. Right click on it and you should get a menu that at the bottom say "Properties", select that, then you should get a new window with tabs at the top. You want the tab for "Ports". Select it and you will see all of the different output ports that you can direct your printing. RS232 is a COM port. So start at COM1, check it and try to print. If that doesn't work, go to COM2, etc.
Last resort, If you can't get control via the printer driver program, you will have to try redirecting the print manually (now you will understand why I said to stay with parallel output).
What you have to do is redirect your printing via the dos "mode" command.
Under "Start Menu" goto "Run" and put in "CMD" and click "OK".
This opens a black square window with a cursor blinking. Type in this:
mode com1:9600,n,8,1 (enter)
mode lpt2=com1 (enter)
Tell your program to use LPT2 if you can and see if it works.
By now a parallel cable instead of RS232 should be looking really good.
Mar 12, 2008 | Zebra Z4Mplus Label Printer
Problem printing to wireless print server
I have a lexmark z715 printer that won't work my pc is a emachine windows xp please contact me at noahmackey@bellsouth.net
Jan 15, 2008 | IBM Lexmark Z715 InkJet Printer
Zebra 140Xi II Thermal Printer Logo
401 people viewed this question
Top Zebra Office Equipment & Supplies Experts
pkwc
CheckitRight
CheckitRight
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
