Question about Maytag Washing Machines
My tub won't drain correctly, we followed the maual and still not draining fully from tub. I have a maytag front loader.
  • Maytag Master
  • 43,501 Answers
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Posted on Sep 15, 2010
Model 5000 front loader. Why doesn't pump work?
Whirlpool washing machine drain pump replacement and ...
? 17:45
www.youtube.com/watch?v=2abTptUYXH8
Feb 5, 2012 - Uploaded by HandySavesMoney The drain pump replacement procedure will apply to kenmore, whirlpool, maytag and other front-loading washing machines. ...does anybody knows about front loader whirlpool that won¨t start? i could use some help tx.
Oct 07, 2015 | Whirlpool Washing Machines
Maytag 2011 maxima water not draining fully from front seal. And water is leaking down the right side. What can be wrong?
The bellows is clogged that can e cleared by opening the door and checking the area just outside the tub at the bottom for debris. Clean this area and should drain normally into outer tub.
Oct 20, 2013 | Maytag MHW6000XW - MaximaTM...
Can anything go down the drain
most likely it would get stuck between tubs , if its a front loader you can get to the drain pump and check there. hope you find it
Feb 17, 2013 | Maytag Neptune Washing Machines
Maf 1375 AAW front loader washing mahcine - water wont drain out???
Remove the back access panel. On the bottom of the tub you will see the drain boot. Remove the boot from the tub and check for any blockage. Also, while you have the boot removed, check up in the tub for any small pieces of clothing that may be hung up in there.
Feb 09, 2011 | Maytag MAH6700AWW Neptune Front-Load...
F21 and Locked Door.
If this is a Whirlpool manufactured front loader (such, Whirlpool Duet, Kenmore Elite, or Maytag Epic), and the washer halted during the wash cycle, the first step in troubleshooting this problem should be to UNPLUG the washer for AT LEAST 30 minutes. This will reset the Central Control Unit (CCU) and often correct momentary glitches in the operation program. If the problem(s) persist, "F21" is a Long Drain error code. This is usually an indication that you may have an obstruction somewhere in the drainage system. Most commonly, this is an indication something is lodged in the drain pump or the inlet line running from the wash tub to the pump. There is a white screw off cap on the drain pump that you can remove to inspect the pump impeller and clean. The following link explains:
http://www.fixya.com/support/r3608588-f21_error_code
Included is a follow-on link that explains how to check the drain pump to clean. You may also have to remove the inlet hose that runs from the bottom of the wash tub to the inlet side of the drain pump. Debris and small articles of clothing such as socks or under garments can become lodged in this area as well causing the drain cycle to fail.
NOTE: A "SUD" error code can also often occur in conjunction with the "F21" error code. This is due to air being detected in the drainage system, which can occur if the pump is not running, or if you have an obstruction BEFORE the pump. You need to remove the inlet hose from the pump to ensure it is also not blocked. Correct your drainage system fault, and the SUD error (if displayed) should go away.
NOTE: If these preliminary measures do not correct your problem, you may have to replace the drain pump. It does not take much to damage the pump impeller or motor. Since the error code is generated if the drain cycle exceeds 8 minutes, if the pump is damaged and can't pump at the required volume, the error code will continue to appear until the pump is replaced. If the pump requires replacement, the following link explains how:
http://www.fixya.com/support/r3574350-replacing_the_drain_pump_in_a_front_load
These are very simple repairs that you can perform yourself without the assistance of a repairman.
If the washer door remains locked and you still cannot open it, there is a manual release you can use to retrieve items left in the wash tub. The following link explains: http://www.fixya.com/support/r3576511-door_jam_on_kenmore_elite_and_whirlpool_ If the wash tub is full of water, you may want to use a wet/dry shop vac to pull a vacuum on the drain line and drain the wash tub. This will minimize any potential mess you may have to clean up. NOTE: The error codes are not listed in the owner's manual. For an explanation of all the error codes, each one of these washers comes with a technical data sheet inside.
To access, you will need to remove the lower toe panel under the door. The access screws are located under the bottom front edge of the panel. You may have to prop the two front feet of the washer up for better access ( a 2x4 works well for this). With the screws removed, the panel should drop down, then come off. If the tech sheet isn't directly behind the panel, it will be affixed to one of the interior cabinet walls.
The tech sheet lists all error code definitions, troubleshooting data, diagnostics procedures and wiring diagrams. I mention the tech sheet because you may need it to troubleshoot this error code.
Read through the information provided and if you have questions, please post back and let me know. I hope you find this information helpful.
Jun 16, 2010 | Maytag MAH8700A Front Load Washer
Where?s the filter on my GE WSXH208A Front Loader? Thank you beltronic205 (GE WSXH208A Front Loader won?t drain). I drained the tub by lowering the drain hose as suggested. But where is the filter, what...
There is no acutal filter on this unit...You cab remove the back panel to access the drain pump ...Or tilt the washer back and access it from the bottom...Remove the drain hose from tub to drain pump...(careful of flow of water from tub)...Check the hose for any blockage...If no blockage then your pump is bad..
Apr 20, 2010 | GE WSXH208A Front Load Washer
I have front loader MFW9700 Maytag washer. Water
Check the door seal for tears and the drain boot from tub to drain boot for anything that might have put a hole in like a piece of metal from an under wire bra which front loads will spin so fast that the wires come out of the bras.
Feb 01, 2010 | Maytag EPIC MFW9700S Front Load Washer
Maytag Neptune won't drain
your pump is clogged with matt mud...
the pump will be right on the left
two hose clazmps
you will loose a gal water
1/4 turn on the pump it will now come out
disconnect the two wires...
clean the pump out and try to clean out sump hose and drain hose
sump from tub to pump
darin pump to drain
reassemble your done
Oct 04, 2009 | Maytag Neptune MAH5500B Front Load Washer
Stackable Neptune Front Loader Washer Leak.
check that the door seals correctly on the rubber boot, check the boot for holes or rips, check the drain hose, tub to pump hose and pump.
Jul 08, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Washing Machines Logo
67 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
