Question about Canon imageRUNNER 3225 Black and White Copier
My Canon ImageRUNNER 3225 does not print correctly aligned when sent through the feeder? When feeding paper, I have tried Landscape and the resulting copy is cut off from the top and bottom and the left portion is gone. In portrait the resulting copy is the image about a 4 inch top margin and the rest of the image is lost.
  • Canon Contributor
  • 185 Answers
Is it ok when you just put the document on the glass? If so, the Document feeder needs a whole set of rollers.
Otherwise the document scanner may be bad. This needs to be changed out by a technician.
Whit
Item, Inc
Posted on Sep 17, 2010
How do I fix Canon IR2200 not printing whole page. Large margins on top and cutting off bottom of page.
It sound like the paper tray is not set correctly. Probably set to landscape and trying to print portrait.
Jun 12, 2014 | Canon imageRUNNER 2200
Off of alignment
Check the paper in the cassette as the side brackets that hold it can shift and not allign the paper correctly.
Mar 23, 2010 | Canon imageRUNNER 3225 Black and White...
The feeder does not feed correctly. Always jammed up
look for debris in the feeder i.e. paper clips, staples them take some windex on a paper towel and wipe all tires you can see and the lil white or grey pad{when you open the top of the feeder}
Jan 26, 2010 | Canon imageRUNNER 2200
Canon IR 105 Will Print from Network and Fiery but won't copy
So, the feeder will not pull in the paper, If this is the case, check the throat of the document feeder for foreign objects, (staples, paperclips, post it notes, or signature flags). you can clean the rollers with alcohol, and blow out the document feeder with compressed air. (Computer Duster)
Hope this is of some help.
Ed
May 06, 2009 | Canon imageRUNNER C3200 Copier
Copy of documents misaligned vertically on Canon Imagerunner 3045
Hello sir; When you feed originals in portrait, the paper tray have to set by portrait direction too.
Mar 30, 2009 | Canon Office Equipment & Supplies
When I print on my Canon MP730, it always prints out a blank page after every print job. How can I fix this?
SOLUTION(S): Reset the Sheet Feeder Gears
If the power fails while the paper is feeding or during a print job, the paper feed gears will lose their proper
alignment. The reason is that after the power is restored the paper feed gears will attempt to return to the
home position, which may not be possible if the paper stop cam is not in the correct position.
PROCEDURES
1. Remove the sheet feeder from the unit.
2. Remove the sheet feeder motor from the sheet feeder assembly.
3. Remove the drive gear from its spindle.
4. Realign the lifting tray gear and paper stop cam gear.
5. Reinstall the drive gear and sheet feeder motor.
6. Reattach the sheet feeder to the print unit.
7. Reassemble the unit.
Jan 11, 2009 | Canon MultiPASS MP730 All-In-One InkJet...
Canon imageRunner 5055 copying in landscape instead of portrait
Double check paper orientation when you put paper into the feeder and how the paper is loaded.
The orientation of the page in the feeder and the page in the drawer should match.
Dec 16, 2008 | Canon imageRUNNER 5000 Copier
Legal Sized 2-sided Copies through Automatic Feed
Does the copier print correctly when copying off the glass? I suspect that the document feeder has been set up to feed other paper sizes eg A4, A4R. Because of the conflict between sizes the copier adjust the image.
Oct 05, 2007 | Canon imageRUNNER 5000 Copier
Canon imageRUNNER 3225 Black and White Copier Logo
316 people viewed this question
old marine
old marine
