Question about Motorola Mobility RAZR V3
V3 razor screen is locked
My razor is only 2 days old and the screen is locked up by itself. you can not use the side keys, display menu,dail out, answer is the open is opened...can if closed. what can i do?
  • Anonymous May 19, 2008
    my razor is only 1 days old and the screen is locked up by itself. you can not use the side keys, display menu,dail out. Please, help.
  • Anonymous Jul 09, 2008
    After heavy storms through our area, my razor's keys are not functioning. The SIM card works fine in another phone. What could have happened?
My keys don't work except for the on & off - but every now & then they do - this started after a strom passed here - but phone was not on - was thinking tower trouble or something cause of all the damage from strom - just weird - never had this problem before - phone is about 2 yrs old - thx - glen
Posted on May 18, 2008
    Novelist:
  • 124 Answers
Describe ur problem briefly for help!!!!
My motorola razor v3 has a white screen?
Hi, White screen on motorola razor phones can be caused by either the LCD or the flex of the screen.
First, you will need to check for the flex by replacing the flex of the phone. the flex controls the display of the phone and the keys on the keypads of the phone.
The LCD also can cause a white screen display. After replacing the flex and if it's still has white display,you will need to replace the screen.
Have a nice day.
Sep 16, 2010 | Motorola Mobility RAZR V3
Lost unlock code
Depending on how many modifications, hacks, or customizations that you perform on your Motorola RAZR V3 phone, there may be situations where the phone becomes unusable or completely locks up. I have had visitors to the site report not being able to delete ring tones, text messages, or have other strange behaviors with their Motorola RAZR V3 phone.
If this is you situation, then you may be interested in performing a master reset (or “hard reset”) on your phone. The master reset will effectively restore your phone back to the factory condition, inclusive of all settings. Be warned, any data that you have not backed up, photos you have not transferred, calendar settings, or messages you have not saved will be lost! Make sure you do this first, if possible!
Here is how you perform a Master Reset on the Motorola RAZR V3:
1. Open your phone up and go to “Settings”
2. Next go to the selection for “Initial Setup”
3. Next go to the selection for “Master Clear”
4. Then select to confirm the option.
5. Now enter the security code which should be “000000”
6. Finally press select or ok and the phone will reset itself to the factory condition
Congratulation you have performed a “hard reset”, “hard reboot”, or “master reset” on your Motorola V3 RAZR and it should return to normal operating mode!
Trackbacks that led to this post:
hard reset motorolla razr v3
hard reset razr phone
wii master reset
hard reboot motorazr
how to hard reset a razor v3
master reset code for motorola v3
master reset code razr v3
master reset for v3 via pc
master reset motorola razr 2
master reset v3 razr with white screen
motorola v3m master reset
p2k commander
razor master reset
razr 3 and how to reset
razr master reset ebay
razr master reset password
razr master restart
razr screen master reset
reset razr
reset razr to factory
reset razr v3 to factory
v3 hard reset razr
v3 razr reset hard boot
Jun 14, 2009 | Motorola Mobility RAZR V3
Motorola razor v3
  1. From the main screen, press the Menu key.
  2. Select Settings.
  3. Select Security.
  4. Select New Passwords.
  5. Select Unlock Code and press Change.
  6. Enter the default unlock code and select OK.
    • The default code is 1234.
  7. Enter the new unlock code and select OK.
  8. Enter the new code again to verify and select OK.
  9. Press the red End key to exit.
Dec 09, 2008 | Motorola Mobility RAZR V3
V3 razor phone
how did you lock a v3 razr keypad try pressing the menu key and then *
Oct 26, 2008 | Motorola Mobility RAZR V3
Razor v3
You need to take the phone to a mobile service center and have them unlock it for you...or you can try online at mobile2mobile.net or unlockitnow.com.
Sep 22, 2008 | Motorola Mobility RAZR V3
Motorola Razor v3 clock setting problem dilema
Disable the "Automatic update" feature and set the clock manually.
To do this go to Menu, settings, initial setup, time and date, Autoupdate>Off, then set the clock and date.
May 01, 2008 | Motorola Mobility RAZR V3
Screen out side
I hope this anser helps you: First, Press the center select key to open the menu, then scroll to SETTINGS & TOOLS and then go to Display Settings, and press the center select key to select it, nou you should go to "Clock Format" and press the menu key. Scroll to Front Clock (for the external display) and press the center select key THAT IS!
May 24, 2007 | Motorola Mobility RAZR V3
No display screen Razor
I lost my display on 30th april 2007 without a hint. Have been using the phone for nearly 1 1/2 years without any problem. The battery seems to be not so strong, shall try with the battery cleaning etc. Is this a standard problem with the MOTOROLLA V3? Cheers Bevanie
Mar 30, 2007 | Motorola Mobility RAZR V3
Has your Razor screen shut down?
It's possible that your sensor that connects to your screen has become dislodged. (if you're brave) check out the do-it-yourself repair guide: http://www.lovehopefaith.com/V3.files/V3-repair.pdf
Nov 26, 2006 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
161 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
