Question about Frigidaire Refrigerators
Ice Maker My Frigidaire GLHS269ZDQ1 ice is made , but ice will not drop into bin. How can I solve thi problem
  • thughes0 Jan 20, 2009
    Can the heater be replaced?
  • 828 Answers
More than likely a gear is stripped out for the harvest. (IF) you are capable disconnect and remove the ice maker from the freezer compartment. Take it to your work bench ( kitchen table) and remove the cover, you should be able to see the gears and the problem. You can order the part and replace the gear. There is also a heater that comes on before the ice is harvested which frees the ice in the tray so it can be harvested . With an OHM meter you can check the heater for continuity.
Posted on May 17, 2008
I have a Frigidaire French door refrigerator model FGHB2866PF. Had ice jam dispenser. Display error code dl SP (dl SP). Cleared jam and emptied ice maker bin.
If you wish to get some details about refrigerator repair then check the following link ; visit the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
Jan 22, 2017 | Frigidaire Refrigerators
My Frigidaire side-by-side refrigirator is not making ice
Here is a simple tip that may help you decide what is causing this problem. If the ice maker has no ice cubes in the slots fill with tap water and allow water to freeze. If the ice maker cycles and drops the ice into the ice bin and then does not refill with water the problem is the 241734302 Water Inlet Valve (providing that the model number above your post is correct) If the ice maker only sits there with ice in the slots and does nothing the ice maker is the problem 5303918277 Ice Maker Assembly Testing the water control valve is as follows. I will be here to answer any questions you may have, Thanks Sea Breeze
Apr 26, 2013 | Frigidaire FRS26H5AS Side by Side...
Changing ice maker for fridadire part # FrS26zrg
Can you add water to the ice maker from tap water, Allow the water to freeze and if the ice maker drops the ice into the ice bin and then does not refill with water will point to your as the problem=> 218658000 Water Inlet Valve
If the ice maker sits there with ice and does nothing the problem will be the ice maker=> 5303918277 Ice Maker Assembly
I will be here should you have questions, Thanks Sea Breeze
Dec 08, 2012 | Frigidaire FRS26ZSG
Not making ice
There are a few simple test you can do that will answer what the problem is. First look inside of your ice maker and see if there are cubes remaining and if yes just check the switch to be in the on position. Look and see that the ice bin full feeler arm works freely. If the ice make still has cubes the problem is most likely the ice maker. If the ice slots are empty the most likely reason is your triple water control valve=> 241734301-2 Triple Water Control Valve You can test that by filling the ice maker with tap water and if after the water freezes the ice maker drops the ice into ice bin and then does not refill with water replace the water valve. If have any question please feel free to ask, Thanks Sea Breeze
Click Here=> FRS3R5EMB_Ice_Maker_Components
Click Here=> FRS3R5EMB_User_Manual.
Ice Maker=> 5304458371 Ice Maker
May 07, 2011 | Frigidaire FRS3R5EMB Side by Side...
Frigidaire ice maker always crushes the ice
Solenoid that switches blades from crushed to cubes is most likely not working and should be replaced
Sep 05, 2017 | Refrigerators
Kenmore refridgerator 19 porcelian plus. ice maker is making ice but not dispensing into the bin to make more ice. how do i solve this
It's possible that your ice maker heater has gone out and therefore can't allow the ice to break away from the unit to drop it. If this is the case, you'll need a new ice maker. We hope this helps and we hope to be able to assist you again soon if you have any more appliance issues.
Sep 17, 2009 | Refrigerators
Ice maker frozen on "crushed" ice mode
Check the bar below the icemaker bin. There is a gold color metal bar that goes from the front of the bin to the back and goes into a lever at the back of the freezer. If the bar gets on the wrong side of the lever it will be stuck in crushed mode.
Jul 06, 2009 | Frigidaire FRS23H7CS Side by Side...
Frigidaire Ice Maker not working
sounds like you got a water valve problem. it will be found at the lower back side of fridge where the water hook up is at.
Mar 14, 2008 | Frigidaire FRS6R5EMB Side by Side...
Refrigerators Logo
94 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
