Question about Fuji FinePix S5000 Digital Camera
Silly problem I just can't figure out how to turn the side bar with the different shooting options off and use a regular shooting mode that's not night or outdoors, or some other option--I can't seem to click out of it, and I also don't have the option of using close-up, which I think is because I can't get rid of the menu sidebar. I don't have a manual to look this up in...
  • 111 Answers
Everything you ever wanted to know about your camera:
http://www.fuji.fi/documents/12/5000_manual.pdf
Posted on May 16, 2008
I can't enable the flash on the hs-25
I had the same problem. If you have silence mode on, your flash button will not work. Really silly.
Aug 14, 2012 | Fujifilm Finepix Hs25exr black Digital...
On the bottom ther is two Zz what is it and what dose it do also how do i turn it off fn + f1 is not working
The zz mean that the computer is in sleep mode. Pressing the fn+F1 keys actually induces the sleep mode for your pc. To turn off sleep mode,follow these instructions.
1. Go to the task bar in the lower right corner of your screen.
2. Right -click on the battery icon and select Power Options.
3. This will bring up the Control Panel\Hardware and Sound\Power Options window.
4. On the left hand side of the window, select "Change when the Computer Sleeps"
5. This will bring up the Control Panel\Hardware and Sound\Power Options\Edit Plan Settings window with options for different settings on the battery and plugged in.
6. Click on the arrow for the drop down menu next to Put the Computer to Sleep>Select Never (last option) do this for both plugged in and battery mode if this is your choice.
7. Click on Save Changes.
Apr 26, 2011 | ASUS Computers & Internet
Inadvertanly set delay and can't figure out how to get it back to the original setting.
Repeatedly press the shooting mode button on the upper-right side of the camera (marked with overlapping rectangles) to select the desired shooting mode. If that doesn't work, hold down the button and turn the main command dial (on the back) to cycle through the modes.
The available modes are Single frame (letter "S" in a rectangle), Continuous (overlapping rectangles), Self-timer (one-armed clock), Delayed remote (self-timer above remote), and Quick-response remote (remote).
Jul 30, 2010 | Nikon D80 Digital Camera with 18-135mm...
Cannon 400 error message 99
Error 99 is a NONSPECIFIC error message. It may be a lens problem. It may be a shutter problem. It may be a battery problem. It's Canon's way of saying "Something happened, and we don't know exactly what, but we know it isn't right".
You're going to have to try to narrow it down by using fresh batteries, trying different lenses, trying different shooting modes, shooting wide open in Av, manually focussing, turning off IS if you have it. In short, if it happens regularly, try to identify what you're doing when it happens and how that differs from when it doesn't.
But don't expect somebody else's solution to work for you. Their camera may have a different problem.
Apr 10, 2010 | Canon Cameras
Trying to switch my symphonic tv back to cable mode
under menu their should be a CA/TV option.
May 12, 2009 | Symphonic WF104
Cant get back to regular printing (portatrait)
go into printer options and change back to landscape
Mar 29, 2009 | HP Deskjet D2430 Printer
Please help!
Try going into the M(anual) mode on the selector dial and then turn off the flash (press the right side of the controller button until you see the lightning bolt with a bar through it). The macro shooting option should still be available in the manual mode.
Apr 17, 2008 | Canon PowerShot A460 Digital Camera
Black side bars on hd channels
You may have to refer to the instruction manual for details.
There should be in the menu set-up an option to set the aspect ratio for the different broadcast modes. Normaly, when viewing a 4:3 picture on an HD 16:9 set, the sides will be cut off, otherwise the picture will be stretched or compensated.
Jerry G.
Apr 11, 2008 | Hitachi 42HDS69 42 in. Plasma Television
Fuji FinePix S5000 Digital Camera Logo
20 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
