Question about Kenmore Dryers
Kenmore dryer mod. no.110.64972301
Dryer stays on as long as on button is pushed in,when released it shuts off.
  • 413 Answers
Before replacing the motor, check under the console for a motor relay. If a motor relay is present replace it. On some models the relay is part of the start switch. The relay will be a black,square device with 3 to 4 wires on it. There may also be a relay for the heater. If so, replace it too as it may be ready to fail soon.
Posted on May 29, 2008
    Genius:
  • 1,073 Answers
Replace the motor the start winding is staying in and the run winding is not kicking in
Posted on May 17, 2008
5 Suggested Answers
watugot
  • 290 Answers
SOURCE: GE dryer starts but..... stops
What you describe is either a failed evenheat board or a failed motor relay.
Please post the complete model number from the machine and I can help you narrow it down. There should be a wiring diagram inside the console with voltage checks also.
Thanks/Mike
Posted on Nov 25, 2007
TheMobilian
  • 8220 Answers
SOURCE: will not stay activated
Either there is a problema with the centrifugal switch moving to the run position or the run windings are shot.
Posted on Dec 16, 2008
  • 50 Answers
SOURCE: Dryer shuts off after releasing "push to start"
this problem sounds like it can only be 1 of 2 problems. the start button or the motor is not going into run winding. i found over the years that the blue wire i believe is burnt at the motor. this can be repaired quite easily .cut the wire and strip it putting a new connector on. if you need to you can buy an assortment at a hardware store. if every thing is good check the start button for burnt wire if ok then you most likely have a bad motor. i'm pretty sure though that a wire is burnt off at the motor
Posted on Jan 30, 2009
  • 415 Answers
SOURCE: kenmore mod 110 87870110 gas dryer- at first push
the vent could be plugged and unit is going into thermal overheat if it works in timed dry properly then the moistier sensor is faulty.
Posted on Dec 01, 2009
Our Kenmore Front loader Dryer Mod # 110.61402310 i put our clothes in the Dryer and powered it on and then Nothing wont Power on
Electric dryer no start does nothing
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage.
CHECK THERMAL SHUT OFF THERMOSTAT USUALLY LOCATED ON THE BLOWER. for OHMS or resistance with a meter. Should show a closed circuit. Ohms WHEN THIS FUSE BLOWS IT WILL SHUT DOWN EVERYTHING.
NEXT Test the PUSH start switch with meter for OHMS. Should show OHMS when pushed in or on start, and no ohms or infinity when in off position.
If you hear a humming sound from motor area you more than likely have a bad motor.
Try this test out to see if u have weak windings on motor.
Open the dryer door and turn by hand the drum while machine is on ON position. And you or someone else presses the door engagement switch in. If it starts up then u have bad windings
Another thing to check is the belt safety switch. With a multi meter.
Especially if u just replaced the belt. The belt safety switch is attached to the Tensioner and motor. IT LOOKS LIKE A DOOR SWITCH SOMEWHAT a little black pc of plastic with 2 prongs going into it. Sits at bottom of motor. Under the Tensioner. Attach meter clips to the 2 prongs on switch, Then when the little white push button is pressed in it should show continuity and none when released. hope it helps
Feb 13, 2015 | Kenmore Dryers
Dryer will not stay running
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
May 10, 2010 | Kenmore 63942 Dryer
CHECK THERMAL FUSE #3392519 @ $15.00...RDS
Apr 21, 2010 | Kenmore 63942 Dryer
Kenmore heavy Duty Series Dryer (Elec) Model 96576200 has power to on switch dryer starts to run but wont stay on when you release the start switch it shuts off????
The switch is probably bad or the door switch isn't being made by the door pin some machines will start with the button pushed and the door switch open.
Mar 05, 2010 | Dryers
Dryer will not stay on after pushing start button
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
heatman101
Dec 21, 2009 | Kenmore 63942 Dryer
Jan 30, 2009 | Kenmore 67082 Electric Dryer
Kenmore Dryer stop running when release the start button
I have whirlpool dryer, when i push the start button it will start but only stay on for part of the drying time. no the start button make noise when push and after keep trying it stop.
Dec 30, 2008 | Whirlpool LEQ9858P Electric Dryer
Dryer stpped working
with power disconnected
if any wire disconnected before any test, reconnect & test dryer, reconnect wires after each test
disconnect wires from start button and test, conduct when pushed, no conduct when release
if fail replace start button test dryer
disconnect wires from door switch and test, conduct when pushed, no conduct when release
if fail replace door switch test dryer
follow leads from start button to relay(relay is first device connected to start button), and make sure all wires connected at both ends. If any wires disconnected, test dryer
locate thermostats and thermal fuses on fan housing and ducts
individually disconnect wires from each and test. conduct good, no conduct fail
replace any failed thermal fuse or thermostat test dryer
if all prior test OK
replace relay, test dryer
Oct 10, 2008 | Magic Chef CYE4000AWW Electric Dryer
Dryers Logo
299 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
