Question about Rheem 266K to 399K BTU Swimming Pool Natural Gas Heater ()
When I turn on my Rheem Pool Heater, I get a code SP5. What is it telling me?
    Top Expert:
  • Rheem Master
  • 8,163 Answers
Check gas pressure or see if on if ok check ignitor and safety circuit
Posted on Dec 31, 2017
4 Suggested Answers
SOURCE: Pool heater leakage
Chances are that the header or manifold is cracked. usually the heat exchanger themselves are not damaged from freeze, but either the rear manifold (header) or the front header (the one that pipes go in and out of). Sometimes both. Replacing the entire heater is not necessary, about $200 in parts usually. We have a schematic diagram of the LJ heater here: http://www.poolcenter.com/parts_heaters_lite2_lj_2003-present_pg1.htm
Rob Cox
POOLCENTER.com
Posted on Jan 28, 2009
  • 11 Answers
SOURCE: Pool heater sparks but does not light up
coud be several things, Do you have Gas and is gas toruned on. Is valve on. The Pilot could be dirty and need cleaned. $350+ sounds reallly pricy for a pilot assembly. Call your Gas Company and get an Estimate and a Qualifed Service tech. You may try turning Off the Power to the Heater Unit and turning it back on , and then trying to turn on heater again, So times after several atemps the valve will lock out and the power needs reset on Propane units.
Posted on Jun 29, 2010
  • 760 Answers
SOURCE: rheem digital gas pool heater fan code
The Fan code would indicate a problem with the combustion air blower. The is a pressure switch to indicate there is sufficent combustion air, and if not then unit shuts down. Either the fan isn't running, or there is an obsturction in the fan or exhaust piping, preventing enough air flow.
cfh would be call for heat, which would be a normal display when water temp is below setpoint
See the link below for a manual. Once you open the page look on lower right side for documents, then install manual
http://www.rheem.com/product.aspx?id=2388EEB7-3DEC-4601-AE76-EC7A07F17630
Posted on Jul 05, 2010
Rheem pool heater code ifault
check gas pressure if ok then turn up by calibration
Jun 30, 2014 | Pool & Spa
Heater shuts down and message says "Fan Lockout".
Shut off the breaker to the heater and turn it back on to reset heater and clear error code.
Oct 16, 2013 | Rheem 266K to 399K BTU Swimming Pool...
RHEEM POOL HEATER HL2 ERROR CODE
high limit bad replace and check gas pressure
Mar 12, 2012 | Rheem 266K to 399K BTU Swimming Pool...
My pool heater rheem said clean filter and strainer. not turning on heat what should i do..to solve the problem and tell me how do i clean the strainer where it is location...
They are referring to the strainer basket inside the filtration pump, and the pool filter system itself. The indication is either this basket is full of debris or the pool filter is so dirty you do not have enough water flowing through the heater. A safety device in the heater is shutting down the heater to prevent damage. None of the parts you named are inside the heater.
Jul 18, 2011 | Raypak RP2100 DIGITAL POOL HEATER R206...
Rheem digital gas pool heater fan code
Jul 04, 2010 | Solar Rheem Gas Fired Pool & Spa Heater...
Rheem 266K to 399K BTU Swimming Pool Natural Gas Heater () Logo
54 people viewed this question
Top Rheem Pool & Spa Experts
Steve Slater
Gene Haynes
Tom Chichester
Are you a Rheem Pool and Spa Expert? Answer questions, earn points and help others
