Question about Porter Cable 7812 Wet/Dry Vacuum
How do i change the switch on porter cable vacum # 7812
I have the porter cable 10 gallon tool trigger drywall vac why is it that the bags keep braking. Have had it for years and it's only been about the last two years they rip open way before they are half...
Need some more information, are you vacuuming dry wall dust or wet dust or saw dust ? The reason I ask is sometime their are "upgrades" available for the newer models of vacs you may not be aware of, when I worked at the Big Box H D tool rental center the vac we rented out used a water filtration set up instead of bags U might wont to check newer model for any changes, like you ,I had Craftsman for over 15 yrs. and when it died the replacement vac had a new mod for the filter that I always thought was needed. Good luck , Bret
Sep 28, 2014 | Porter Cable 7812 Wet/Dry Vacuum
VACUUM FAILED TO AUTOMATICALLY START AFTER PUTTING ON A NOTHER POWER TOOL
did it start and run for a second before you tryed pluging the power tool in
Feb 18, 2013 | Porter Cable 7812 Wet/Dry Vacuum
Why does the motor start, then shut off?
Check for a stuck or binding float switch
Jan 31, 2013 | Porter Cable 7812 Wet/Dry Vacuum
Hi My Electrolux Oxygen Z5530 stopped working from one second to another. No lights - nothing - totally dead. What can I do? Is there any fuse? Sincerely Eva
I have same problem and I check it out.
The special requrement of Electrolux for his vacum cleaner motors is that they working with high reliably approx 800 hours working time and no more!!! (it should stop safe with no danger for users...)
7 years has past (2 h/week x 52 x 7 = 708 working hours) so it is time for us consumers to buy new vacum cleaner...
Jan 05, 2011 | Electrolux Vacuums
Where can I buy replacement bags ?
Porter Cable is a professional tool store product. Look at a Porter Cable dealer,or online nowhere else
Oct 27, 2009 | Porter Cable 7812 Wet/Dry Vacuum
When I hit the power switch it turns on, but it will not stay on.
If this were mine I would take the old switch off and put a toggle switch from Home Depot in it. Make sure it's rated for 110 volts and the wattage of your machine or at least 100 watts. It should cost no more than 2-3 dinero or about 1/200th the cost of a new one.
May 04, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Porter Cable 7814 vacuum
Possibly a faulty power cord, replace the power lead to the machine or check for damage to the cable.
Check that machine is not blocked, motor may be overheating due to blockage, if you have good suction this indicates machine is not blocked.
Nov 09, 2008 | Vacuums
Craftsman compressor
They put this under vacuums, relist it in the right place.
Dec 16, 2007 | Porter Cable 7812 Wet/Dry Vacuum
Porter Cable Roofing nailer rn175a
Replace the O Rings and the trigger valve assembly. 9/10 sticking rods on the Porter Cable guns is caused by a faulty TVA.
Nov 08, 2007 | Vacuums
Porter Cable 7812 Wet/Dry Vacuum Logo
74 people viewed this question
Top Porter Cable Vacuums Experts
JoeVacs
Are you a Porter Cable Vacuum Expert? Answer questions, earn points and help others
