Question about Sentry Fireproof Safe
I have S3803. I would like to know how to use a key override to open the unit (just in case the electronic lock fails, or I lose the code). I tried to follow the key override instruction in the manual, but could not find a key hole for the skeleton key inside the opening for the battery . Could you help? Mira
dmathwizard
  • 113 Answers
SOURCE: small floor safe Sentry Model 3877 electronic lock and key
This manual will answer both of your questions.
http://www.sentrysafe.com/pdfs/OwnersManuals/501664.pdf
Posted on Mar 05, 2008
SOURCE: factory code will not open model # DA3831 safe
I figured it out by pressing the program/enter button after putting in the code, does not say in manual, light never turns green tho, like it states in manual a small lock appears on the screen and then it opens.other than turning key and pressing code all the other stuff I had to figure out on my own. The manual had none of it. I hope its right I tried it several times will put my stuff in today so I hope it will open when I need it to.
Posted on Nov 24, 2008
SOURCE: Sentry Safe (DSW3607 Model) Won't Open
I finally ignored the poorly-written instructions for programming a personal code and simply entered the factory code first and then pressed the prog/enter code button.  The safe opened.  The instructions tell you to push the prog/enter code first and then enter the factory code or personal code to open the safe.  Wrong!  Do it my way should this problem happen to you.
Posted on Mar 23, 2009
  • 80 Answers
SOURCE: I HAVE A SENTRY SAFE A3860 I NEED TO OVERRIDE THE ELECTRONIC CO
the instructions are located link above.
mj
Posted on Sep 07, 2009
SOURCE: Can't open my Protocol Home Safe - Electronic Keypad Entry
Hi I have a Sure Safe electronic key pad safe, i have owned for about 5 years we have moved house and it was placed in storage.
For the life of me i can not remember the code i have tried endless times !! is there a way to get in or do i take it to a professional.
Posted on May 29, 2010
Tip
How To Open Your Kingavon Electronic Safe 28
<ol> <li>The original factory code is 1-5-9 A (or B) to open the safe. There is usually an override key for your safe in case you have lost your code.</li> <li> Once the unit is open, you can reset the combination by pressing the red button, the yellow light will come on. Input a new code 3-8 numbers and then either the A or B button to finish the code.</li> <li> Test your new code several times before locking.</li> <li> If you don't have an over ride key, the first three digits of the serial number should be the key code.</li></ol>
on Feb 21, 2011 | Kitchen Appliances - Others
We don't remember the code please help with the axample
You must be having the manual override keys. Just open the safe with those keys and reset the passcode.
Jul 14, 2014 | Safe International Digital Electronic Safe...
Kingavon electronic safe 28
  1. The original factory code is 1-5-9 A (or B) to open the safe. There is usually an override key for your safe in case you have lost your code.
  2. Once the unit is open, you can reset the combination by pressing the red button, the yellow light will come on. Input a new code 3-8 numbers and then either the A or B button to finish the code.
  3. Test your new code several times before locking.
  4. If you don't have an over ride key, the first three digits of the serial number should be the key code.
Feb 24, 2010 | Safe International Digital Electronic Safe...
How to unlock a cathedral electronic safe ea25
After opening the electronic safe (with the pre-set factory code of 159B) locate the small red button on the
inside of the door near the hinge.
2. Press the red button and then release it, you will hear a beep. DO NOT SHUT THE DOOR UNTIL YOU HAVE CONFIRMED THAT YOUR NEW SECURITY CODE HAS BEEN ENTERED CORRECTLY.
3. With the door open, enter your own personal security code, which can be 3- 8 digits long, and confirm your new code by pressing the letter “B” on the electronic touch pad. Before you close the door, try the new security code to make sure the lock release the knob so you can turn it and retract the live action locking bolts.
If the code fails, go through steps 1-3 again. If the code works successfully, then you should lock the safe. When you open the safe in the future enter the security code you have set followed by the letter “B” and turn the knob.
If the incorrect security code is entered 3 times you will have an automatic lockout for 20 seconds before you can try your code again. If the incorrect security code is entered 3 additional times there will be a 5- minute lockout before the code can be tried again.
BATTERY REPLACEMENT
This safe uses 4- AA batteries. Under normal use, batteries will last about 1 year. When the battery is low, a red light will come on warning you that the battery is low. To test the batteries, enter your security code. If the batteries are low the red light located in the middle of the top of the keypad will start to flash.
To replace the batteries, open the safe door with your security code and turn the knob. Push the batteries cover plate, which is located on the back of the door, and replace the old batteries.
YOU MUST PROGRAME YOUR SECURITY CODE AFTER YOU REPLACE THE BATTERIES. SEE STEPS 1- 3 UNDER “ENTERING YOUR SECURITY CODE”.
TROUBLE KEY
A “Trouble key” has been provided in case you forget or lose your security code. Remove the small central panel from the front of the faceplate. Insert the key and turn it counter clockwise. Then turn the knob on the door towards the right. This will manually open your safe. If you lose your key, you may purchase a replacement key by referencing the serial number located under the central panel by the lock.
MAINTENANCE FOR KEY AND ELECTRONIC SAFE
If the door of the safe starts to rub on the door frame, open the door per the instructions above. By the door hinges you will find a threaded stem. Use an Allen wrench to tighten the threaded stem. This will help realign the door and give you trouble free access to the contents of your safe.
Nov 01, 2009 | Home Security
I cannot open safe with the usual code.Safeguard electronic digit
To open a Safe International Digital Electronic Safe
User override key to open safe
Then:
a. Inside the open door you would find hidden a red button press this button, the yellow light will be on, input the user code in 30 seconds try 1,5,9 then press A or B to finish
b. If the yellow light keeps flashing with beeps the code is wrong( revere to user manual)
c. To change code repeat step a.
Test your new code before closing safe.
Apr 27, 2009 | Safe International Digital Electronic Safe...
Have a Sentry V260 safe. The #1 button will not register when pressed. All other buttons register except for the #1. And the #1 button is in the combo. How else can I open it or how can I fix this button?
You can do a Key override
If your electronic lock fails or you do not have any codes
available, you may use a key override to access this unit.
1. Remove the battery cover, disconnect and remove the
battery holder.
2. Insert the skeleton key (second set of keys provided)
into the key hole inside the opening for the battery.
3. Turn the key to the right.
4. Turn the four-bitted key to the right.
5. Open the door.
You can download the user manual here:
http://www.sentrysafe.com/pdfs/OwnersManuals/172967.pdf
Dec 25, 2008 | Sentry Fireproof Safe
The number 1 button will not press
Key override
battery holder.
5. Open the door.
Dec 24, 2008 | Sentry Fireproof Safe
Forgot pin code to unlock my hardline digital safe
I have pin code but batteries went flat while I was on holiday, how do I unlock my Hardline digital safe? I do not have override key
Dec 09, 2008 | Safe International Digital Electronic Safe...
Sentry Fireproof Safe Logo
504 people viewed this question
Top Sentry Home Security Experts
Jim London
Jim London
Computer Repairing
Computer Repairing
Joseph Vernice
Joseph Vernice
Are you a Sentry Home Security Expert? Answer questions, earn points and help others
